Study Generate Blocks
    My query is not related to any problem. I recently bought the Generate Blocks license and I would like to have a step-by-step guide to study Generate Blocks and start implementing it in my projects.
    I’d like to create a kind of tutorial for me and a junior designer who is also working in my team
    Where do I start?
    Thank you very much
    Silvina
  • Hi Silvina,
    I would recommend importing a site template from GP’s site library, and check how the site is built using GB.
    And here is the documentation of GB, you should be able to find info that you need to use GB:
    https://docs.generateblocks.com/
  • Hi Ying
    Thank you very much for your suggestion more practical than the one I’ve considered, starting from the documentation of the single blocks and go then on the implementation
    Best Regards
    SD
  • You are welcome   🙂
