shamrick
I followed the instructions in this video (https://www.youtube.com/watch?v=tPOuWbz9Uek) and was able to use an svg as the list image but it didn’t go into any detail on how to style an SVG (video only demonstrated using a .png).
Unlike when the same SVG is used as an icon for either a headline or text block there’s the “Icon” tab available for separate styling. Can you tell me where and how to style those svg list images?
Thanks.
The list image option isn’t that flexible due to CSS limitations.
I would recommend just using an icon like you would for a normal headline/text block.
And you can set the headline/text’s HTML tag to
li
shamrick
Thanks Ying. Simple enough and less head-scratching.
You are welcome, that’s just how I would do 🙂
