Sub Category page
    Can you please guide me create a sub-categories page under the main category like this page https://www.expertreviews.co.uk/home-garden
    Under the sub-categories page, I want to show further the blogs like in the URL
    can you please let me know the steps I have to take to create a sub-categories page under the main category
  • Hello there,
    To clarify, are you referring to separating the Parent and child categories by section on a Category page?
    I am looking to create a parent category page like Home & Garden and under this page, I want to create multiple subcategories like BATHROOM, BEDROOM, BOOKS, ENERGY & PLANTS HEATING LIGHTING.
    I want to show a box image with little content under parent category page like this https://www.expertreviews.co.uk/home-garden
  • It’s just showing Home & Garden posts in general. Then, there’s this “filter”: https://share.getcloudapp.com/kpulPg40
    What you can do is create a Block Element – Content or Loop Template for the layout of the posts. Reference: https://docs.generatepress.com/article/block-element-content-template/
    Then, you’ll need a custom code for the filter.
    Thanks for your response. I am not very good on WP so can you please explain to me in bit of detail how can create a filter or that sub-category
    There’s no easy way for the filter section, it will require custom PHP coding and some CSS to style it.
    If you’d like to pursue this, here’re the steps:
    1. Go to appearance > elements, create a hook element, paste the below code:
    <?php
    $parent_cat_id = get_queried_object_id(); // Get the ID of the current parent category
    $child_categories = get_categories(array(
        'child_of' => $parent_cat_id, // Retrieve child categories of the parent category
        'hide_empty' => 0, // Show empty categories as well
    if ($child_categories) {
        echo '<ul class="sub-categories">';
        foreach ($child_categories as $category) {
            echo '<li><a href="' . get_category_link($category->term_id) . '">' . $category->name . '</a></li>';
        echo '</ul>';
    2. Make sure tick the Execute PHP box, choose generate_after_archive_title for the hook, and choose post category archive as the location.
    Thank you for that,
    I can not find option to choose post category archive and there is no box to tick the Execute PHP box
    This is shown at the bottom Unable to execute PHP as DISALLOW_FILE_EDIT is defined.
    I am using Info Template from Generate Library
  • This is shown at the bottom Unable to execute PHP as DISALLOW_FILE_EDIT is defined.
    Ah, in that case, you can not use PHP in hook elements due to your configuration.
    Let’s change the plan, here’s the updated code that you can add to a plugin like Code Snippet or functions.php of your child theme if you are using one.
    function list_of_child_categories() {
    if (is_category()){
        echo '</ul>';
    add_action('generate_after_archive_title','list_of_child_categories');
