Submenu displaying in grid layout after GP Premium 2.5.5 update
  • Hi GeneratePress team,
    After updating GP Premium to version 2.5.5, my dropdown submenu is suddenly displaying in a grid layout instead of the normal vertical list.
    What’s happening:
    My submenu items under “Menu” are now displayed side-by-side in multiple columns
    Before the update, they displayed normally as a vertical dropdown list
    When I deactivate GP Premium, the submenu works correctly again (normal vertical dropdown)
    When I reactivate GP Premium 2.5.5, the grid layout returns
    What I’ve checked:
    Layout → Primary Navigation settings in the Customizer – no grid or column options visible
    Menu settings in the WordPress menu editor – everything looks normal
    No custom CSS that would cause this
    My setup:
    Theme: GeneratePress
    GP Premium: Version 2.5.5 (issue appeared after updating from previous version)
    The menu in question is assigned to “Primary Navigation”
    Could you please help me resolve this? It seems like the update introduced automatic grid styling to submenus that wasn’t there before.
    Thank you!
    The CSS of the menu looks normal. Can you try disablling your cache plugin to test?
    I can not log in to your site, as when I use wp-admin, it says contact the admin and would not show the login page.
  • Hey Ying,
    Excuse me. I have adjusted the login page but you should be able to login now!
  • I can not log in due to Invalid username or password.
    I tried twice, as it will lock me out if I try 3rd time.
    Can you check the password and username?
  • Excuse me, i don’t know why it happened but now you can login correctly
  • The issue is caused by a global style you created menu-item.
    https://app.screencast.com/TwfIrj07d2l2K
    This global style overrides the menu item styles in the navigation. You will need to change the global style class.
  • Thankyou so much, excuse me im working on it now and it’s for a restaurant menu. Guess i have to pick better classes for it ^^
    Anyway thanks for the quick fix.
  • No Problem 🙂
