Plamen PS
Can you tell me how to add my subscribe form here?
You’ll need to use a form plugin that integrates with your email marketing tool. Typically, these form plugins provide a shortcode that you can place in the desired section, which will then display the form on the frontend.
Plamen PS
Ok Done just the position is not in the center/middle.
Try adding this CSS:
.wp-block-sender-sender-forms.sender-form-field { text-align: center; }
Plamen PS
Thank you!
No Problem 🙂
