Frank3011
Good evening,
I need to insert the subtitles right under the entry title. I carefully followed Leo’s suggestions in this post https://generatepress.com/forums/topic/how-to-add-subtitles/, but nothing happens; I don’t see the subtitle I typed in the article.
I know I could create the subtitles with Advanced Custom Fields and then insert the PHP code into Elements. I tested it last week, and it works flawlessly. However, in this case I definitely need to edit the typography and color because they’re so ugly.
Could you help me with one of these two solutions?
WordPress: latest version; theme: GeneratePress; plugin: Code Snippets, GenerateBlocks, GP Premium, Maintenance. -
Can you show me your backend setup for the custom fields/GP elements?
Or can you provide an admin login to your site and point me to the element you are referring to?
Frank3011
Hi, thank you.
I certainly can. I created an administrator account for you. When you no longer need it, let me know and I’ll delete it. You can find them in Private information. -
May I know where you’re storing the subtitles? I noticed you set the dynamic tag for the subtitle element to
{{post_meta key:Sottotitolo}}, but there doesn’t seem to be any custom field namedsottotitoloassigned to your posts. -
Frank3011
Hi,following Leo’s procedure
https://prnt.sc/PlzMusWBTJaN -
Okay, the field name is case-sensitive. Replace
{{post_meta key:Sottotitolo}}with{{post_meta key:sottotitolo}}. -
Frank3011
Thanks Alvind, this problem has been solved too. Thank you very much.
https://prnt.sc/zBIuDBrOQcbj -
Glad to hear that! 🙂
