daveporter
I am finishing off a site that another developer worked on.
They added the CSSe below to style blog posts – it was 700px wide, but I changed it to 800px (and reduced the padding).
But I also want to provide the client with a 2 column layout, but of course 800px is too narrow.
But there are existing posts that work fine at the 700/800 layout (a single column)What would you recommend to do to provide a flexible way to have both options for the client going forward for new posts?
TIA, Dave
.single-post .site-inner, .single-post .content-area, .single-post article, .single-post .entry-content, .single-post .gb-container, .single-post .gb-grid, .single-post .gb-inner-container, .single-post .comments-area, .single-post #comments, .single-post .comment-respond { background-color: #f7f4ee !important; padding-top: 5px !important; padding-bottom: 15px !important; padding-left: 0px !important; padding-right: 0px !important; margin: 0 auto !important; max-width: 800px !important; box-sizing: border-box !important; } -
Hi Dave,
If the goal is to provide two different layouts for single posts, this is the approach I would take:
First, move the CSS above into a Hook Element, then configure the Display Rules so it applies only to the posts that require the 800px width layout.
Next, create a separate Content Template Element for the alternative layout. In that template, design the content using a two-column structure, then assign it only to the posts that require that specific layout.
Hope that helps!
daveporter
Thansk Alvind,
I’ll work on that sound good!
Dave -
No problem! 🙂
