aloenne
I am using a Tabs block with button type set to container, and a grey top, left and right color on the active button. For non-active I have a bottom border. However, when switching to a mobile view all the border colors in the tabs buttons dissappear. Is there a setting in the customizer I am missing here to control the mobile color? Many thanks in advance.
Best,
Alf -
Hi Alf,
Any chance you can copy the tab block, paste the code here and wrap it with the
<code>tag? -
aloenne
I feel like it’s a bug during the border color migration, you might’ve set a border color in the color panel of the last GB version and it gets migrated incorrectly to the new border module.
Any chance you can create a new tab and try the same setting and let us know if the issue happens for the new tab as well?
Thank you for your patience!
aloenne
Sure thing, will try that and report back. Thanks again for the help.
Best,
Alf -
aloenne
Creating a new fresh tabs block worked, thanks for the guidance! Now going over the styling of my other tabs using the fresh tabs block as a global style.
Best,
Alf(I removed the code block I pasted above)
Hi Alf,
Thank you very much for testing, and glad that the new tab block works 🙂
