When using Safari, and attempting to navigate through the website with the Tab key only, my website gets stuck on a loop going from the Search bar, to the menu dropdowns, and back to the search bar again.
I’ve pasted the URL in the private info.
This is an accessibility concern that I’m not sure if there’s a fix or known issue, but appreciate your help to diagnose!
Hi Adam,
That’s a known Safari-specific behavior. By default, Safari doesn’t allow tab focus on links and other non-form elements.
The fix needs to be done on the user’s side. In Safari, go to Settings > Advanced > Accesibility and enable Press Tab to highlight each item on a webpage option.
Good to know, thanks for the help!
No problem!
