I have tables on the below page:
https://zanzan.tw/web-design
Can I make the table center in the desktop view while full-width in the mobile view? -
You can try this CSS:
@media only screen and (max-width: 768px) { body.page-id-42215 .wp-block-table { margin-right: 0; margin-left: 0; } }
Thanks.
I often add some class to the custom additional CSS so that it can be used in the same object as the below image. Can I to this to the specific table element in the same way?
https://imgur.com/gOh0XBu -
looking at the page you shared. I see a layout like this for each of your tables:
Container Block #1
—- Container Block #2
—- —- Table BlockSelect Container Block #2
And set the blocks alignment to default:https://app.screencast.com/aMjgW2YEEfMVF
Then in Spacing > Margin Left & Right set it to
auto
Then in Sizing > Max Width set the max width of the container eg. 500px.What this will do is container the max width of the table and center it.
Hi there
Thanks for your recommendation.
I did just as what you suggested. But table didn’t show in full wide. It seems there is default margin or padding in the whole page? If so, how can I adjust this in the theme’s setting?Ps.I took the screenshot as you did with the screencast. If you can see them, just let me know.
Page:
https://zanzan.tw/blank
https://zanzan.tw/web-designScreenshot:
https://app.screencast.com/Vp1MH2ndm2hoU
https://app.screencast.com/n2SUUSixuMV4t -
a couple of options
Option A – remove the theme padding
In the page editor you can set the Layout > Content Container to Containedhttps://docs.generatepress.com/article/content-container/
This removes the Padding ( set in Customizer > Layout > Container ) from that page.
This means any content wide enough will span the width of the container.NOTE: Setting the Content Container to Full Width will make it so the page expands 100% the width of the browser on any screen size.
Option B – make a single block extra wide
Select a block eg. the image block and in the blocks toolbar set the alignment to Wide Width
This will force that block to overcome the themes padding. -
Thanks.
I make the theme’ default padding to be 0. Clear used CSS with Perfmatters and Clear cache with Kinsta.
However, I still see the padding space in the mobile view. Is anything wrong?https://app.screencast.com/9JLk4WEfwMp5N
https://app.screencast.com/F430sLwVD8j0R
https://app.screencast.com/ZqYnTFe0aqQok -
Can you disable your cache plugin so we can see the code?
In additional to Knista hosting cache, I use no cache plugin. Can you specify in more detail so I can do it for you? Thanks.
Are you referring to the content padding in the customizer?
https://docs.generatepress.com/article/content-padding/I’m still seeing the 40px of default padding on the
web-design
page.Let me know 🙂
Yes. That’s desktop view. In the wide screen mode, the padding is somewhat irrelevant.
I set the padding to be 0 in the mobile view. But I cannot see the effect. My wonder comes from mobile view. -
Can you disable any optimisation / cache plugins so we can take a closer look
Yes. I’d ready to do this. But I don’t know which plugin you mean. The only optimisation plugin I used should be Perfmatters. I don’t use any cache plugin. Should I disable perfmatters?
Yes, please. All plugins that are for performance, please disable them. And also the Kinsta cache.
You are right. I create a staging site. The site of of caching.
When I disabled the Perfmatters, the mobile page finally changed to full-width view.
Is this helpful to you?https://stg-zanzan-test.kinsta.cloud/web-design
https://app.screencast.com/CH1HO0X8VTVmN
https://app.screencast.com/vxcXXVlaYnUIl
https://app.screencast.com/ySyMud5KqE8Nj -
So it’s a cache problem, you will need to check the settings of the cache services (especially those related to CSS ) and make sure all cache is cleared 🙂
