tthomson
When editing a page, clicking show options for all devices displays the content in a desktop view. However, clicking show options for tablet or mobile causes the content to disappear. I only see the Yoast SEO panel in the editor window along with a few others.
If I go to the 3 dots in the upper right corner, select preferences, go to the Advanced section and disable Yoast SEO premium, then I can see the content in tablet and preview mode. Something has recently changed causing this behavior. Not sure if it’s a WordPress issue or GenerateBlocks one.
If I want to see the SEO page settings, I have to reenable the the Yoast SEO Premium but then I can’t view tablet/mobile content.
This is a WP 6.6 issue. See David’s explanation here:
https://generate.support/topic/wp-6-6/#post-121210Thanks for your understanding 🙂
tthomson
Thank you! Hoping they will fix this soon.
No problem 🙂
corksandtacos
Curious if you had success in getting the issue resloved. I’m having the same problem. I’m on WP 6.6.1
Thanks in advance if you have any further info.
Kerry
This is something WP will need to fix.
You will need to use David’s workaround suggestion for now.
- The topic ‘tablet/mobile views not displaying in editor’ is closed to new replies.
