Anonymous
When I style my tabs using Generate Block’s tab, it:
1. Would not allow me to click the different tab buttons
2. All the tab contents are open on defaultHere’s an example: https://share.cleanshot.com/wk4Pz4yV
It doesn’t seem to happen if I just use Generate Block’s tab without any styling.
Hi Hafiey,
Can you try a), and if that doesn’t work, try b) here?:
a) Regenerate your CSS files in Settings > GenerateBlocks.
a) Choose Inline Embedding for the CSS Print Method in Settings > GenerateBlocks.Reference: https://docs.generateblocks.com/article/unstyled-content/
Anonymous
Still no changes.
(There’s also no caching on the website atm)
I see. Can you try #1 here to debug: https://docs.generatepress.com/article/debugging-tips/
It’s recommended to backup your site before proceeding with this.
Anonymous
I’ve followed all the steps:
1. Deactivated all plugins except Generate Blocks
2. Deactivated Bricks Builder and used the default theme mentioned
3. I don’t see any errors (hosting error log & debug)
4. Memory is at 512 MBBut the issue is still there: https://share.cleanshot.com/GHsrHQqw
I see. Can you try to duplicate the Tabs Block and check if the duplicate will have the same issue? Example: https://share.zight.com/YEuzbAD6
Anonymous
I tried duplicating and it is still having the same issue.
Example: https://share.cleanshot.com/NrzqPF00
I should note that in the WordPress editor it doesn’t show this issue. Only on the frontend.
Yeah, it’s weird, even the script isn’t loading.
What if you try adding a different new Tabs Block inside this page, does that new Tabs Block work?
Anonymous
Here’s what I tried before (which still didn’t work):
1. Created a local pattern and tried using it on the post -still faced the same issue
2. I created a new tab from scratch on a blank new page (https://neurodigital.my/test-blocks/) -still faced the same issueYou can see here (https://share.cleanshot.com/5NmMGLn0) that the default tabs work.
When I inspected the HTML, I can see:
For the non working tab: https://share.cleanshot.com/qhHhNsCN
For the default working tab: https://share.cleanshot.com/9PjYV9x7 -
I see. That’s very odd. Can you try copying and pasting the Tab in question to a new Test Page(create a new page for this)?
Moreover, do you have a Staging/Test site where you can disable all plugins while we do some testing?
Anonymous
I tried copy and pasting to a new page, still the same result.
I’ve updated the staging details.
Can you disable all the non-GP/GB plugins on the staging site? I’ll try to see if there’s anything obvious causing the issue.
Anonymous
Done. I’ve deactivated all the non-GB plugins & theme.
Can you change the user you provided to an Admin account?
Anonymous
Okay done.
I tried creating a Test Post, and recreating your Tabs Block from scratch. It’s unfinished yet, but it’s working.
Can you check it out? I added the link in the Private Information field.
