Tag not passing through anymore (GBP 2.1)
  • Hello!
    I do have an issue with the latest update.
    The tags does not work inside the native blocks anymore.
    For example: html tags is not allowed inside GB text block. Solution was to create a custom html block, and write this inside:
    <span>Last updated <time datetime="{{post_date dateFormat:Y/m/d|type:modified}}">{{post_date dateFormat:Y/m/d|type:modified}}</time></span>
    I did this because I need to have the <time> element.
    This worked until this update. Is there any filter to allow the pass through the tag?
    yes, you can use the generateblocks_dynamic_tags_allowed_blocks filter hook. Here’s an example:
    add_filter( 'generateblocks_dynamic_tags_allowed_blocks', function( $blocks ) {
        $blocks[] = 'yourprefix/block-name';
        return $blocks;
  • Works perfect! Thank you!
  • You’re welcome
