david.estan
I am trying to install a new template, but doesn’t appear, it appear the web charging but doesn’t appear the templates. What can I do?
Not sure if I fully understand the question but it sounds like a caching issue.
Can you disable all plugins and custom functions except GP Premium and GenerateBlocks to eliminate conflicts from other plugins?
Make sure to activate the parent theme if a child theme is used.
david.estan
I have tried it but it happens the same. When I try to choose another template, the screen don’t show anyone.
What can I do?
Sorry I still don’t fully understand the question.
Can you disable all plugins except GP Premium and link me to the page in question?
If the issue is at the backend then please provide the admin access.
david.estan
I would like to remove the template and install a new one form the list.
Could you review it?
Can you try this solution? https://docs.generatepress.com/article/site-library-unavailable/#constant-loading
david.estan
Thanks! it works.
No problem 🙂
