Template stuck at “Importing content”
    as written, when choosing any site template, after downloading plugins, I am getting an eternal:
    “Importing content” with a spinning circle. Please troubleshoot.
    thanks
    server info:
    Server architecture	Linux 6.8.0-62-generic x86_64
    Web server	nginx/1.24.0
    PHP version	8.3.22 (Supports 64bit values)
    PHP SAPI	fpm-fcgi
    PHP max input variables	10000
    PHP time limit	600
    PHP memory limit	768M
    Max input time	600
    Upload max filesize	256M
    PHP post max size	512M
    cURL version	8.5.0 OpenSSL/3.0.13
    Is SUHOSIN installed?	No
    Is the Imagick library available?	Yes
    Are pretty permalinks supported?	Yes
    WP constants:
    ABSPATH	/var/www/clients/client0/web3/web/
    WP_HOME	Undefined
    WP_SITEURL	Undefined
    WP_CONTENT_DIR	/var/www/clients/client0/web3/web/wp-content
    WP_PLUGIN_DIR	/var/www/clients/client0/web3/web/wp-content/plugins
    WP_MEMORY_LIMIT	768M
    WP_MAX_MEMORY_LIMIT	768M
    WP_DEBUG	Enabled
    WP_DEBUG_DISPLAY	Enabled
    WP_DEBUG_LOG	Disabled
    SCRIPT_DEBUG	Disabled
    WP_CACHE	Disabled
    CONCATENATE_SCRIPTS	Undefined
    COMPRESS_SCRIPTS	Undefined
    COMPRESS_CSS	Undefined
    WP_ENVIRONMENT_TYPE	Undefined
    WP_DEVELOPMENT_MODE	Disabled
    DB_CHARSET	utf8
    DB_COLLATE	Empty value
    wp-config extras:
    define('WP_HTTP_TIMEOUT', 300);
    define('WP_MEMORY_LIMIT', '768M');
    define('DISABLE_WP_CRON', false);
    ini_set('default_socket_timeout', 300);
    php diretives:
    memory_limit = 768M
    max_execution_time = 600
    max_input_time = 600
    max_input_vars = 10000
    max_input_nesting_level = 64
    upload_max_filesize = 256M
    post_max_size = 512M
    max_file_uploads = 50
    max_multipart_body_parts = 10000
    opcache.enable = 1
    opcache.enable_cli = 1
    opcache.memory_consumption = 256
    opcache.max_accelerated_files = 10000
    opcache.max_wasted_percentage = 3
    opcache.validate_timestamps = 1
    opcache.revalidate_freq = 0
    opcache.save_comments = 0
    opcache.fast_shutdown = 1
    opcache.enable_file_override = 1
    opcache.interned_strings_buffer = 32
    opcache.jit = 1255
    opcache.jit_buffer_size = 128M
    opcache.jit_hot_func = 127
    opcache.jit_hot_loop = 64
    realpath_cache_size = 8192K
    realpath_cache_ttl = 1200
    output_buffering = 8192
    zlib.output_compression = Off
    zlib.output_compression_level = 6
    session.gc_probability = 1
    session.gc_divisor = 100
    session.gc_maxlifetime = 7200
    session.cookie_httponly = 1
    session.cookie_secure = 1
    session.cookie_samesite = Lax
    session.use_strict_mode = 1
    display_errors = Off
    log_errors = On
    ignore_repeated_errors = On
    expose_php = Off
    allow_url_include = Off
    allow_url_fopen = On
    default_socket_timeout = 300
    user_agent = ""
    auto_detect_line_endings = Off
    date.timezone = Europe/Berlin
    mysqli.allow_persistent = On
    mysqli.max_persistent = 50
    mysqli.max_links = 50
    mysqli.default_socket = /var/run/mysqld/mysqld.sock
    mysqli.allow_local_infile = Off
    mysqli.reconnect = Off
    pcre.jit = 1
    pcre.backtrack_limit = 5000000
    pcre.recursion_limit = 500000
    assert.active = Off
    auto_globals_jit = On
    error_reporting = 0
    log_errors_max_len = 2048
    mbstring.language = neutral
    mbstring.encoding_translation = Off
    mbstring.substitute_character = none
    user_ini.cache_ttl = 600
    variables_order = GPCS
    request_order = GP
    nginx directives:
    client_max_body_size 128M;
    # Security: Protect sensitive files
    location ~* wp-config\.php {
        deny all;
    location ~* /\.ht {
        deny all;
    # WordPress Admin AJAX - NO CACHING (fixes import stalling)
    location ~ ^/wp-admin/admin-ajax\.php$ {
        try_files $uri /index.php?$args;
        add_header Cache-Control "no-cache, no-store, must-revalidate" always;
        add_header Pragma "no-cache" always;
        expires -1;
    # WordPress REST API - NO caching for POST requests (fixes imports)
    location ~ ^/wp-json/ {
        try_files $uri $uri/ /index.php?$args;
        # Don't cache POST/PUT/DELETE requests (used by imports)
        set $no_cache 0;
        if ($request_method ~ ^(POST|PUT|DELETE|PATCH)$) {
            set $no_cache 1;
        add_header Cache-Control "no-cache, no-store, must-revalidate" always if ($no_cache = 1);
        add_header Cache-Control "public, max-age=300" always if ($no_cache = 0);
        expires -1 if ($no_cache = 1);
        expires 5m if ($no_cache = 0);
    # Static assets with aggressive long-term caching
    location ~* \.(css|js|png|jpg|jpeg|gif|ico|svg|woff|woff2|ttf|eot|webp|avif|pdf|mp4|webm|mp3|zip|tar|gz)$ {
        expires 1y;
        add_header Cache-Control "public, immutable, max-age=31536000" always;
        add_header X-Cache-Status "STATIC" always;
        access_log off;
    # WordPress uploads directory
    location ~* ^/wp-content/uploads/ {
        expires 1y;
        add_header Cache-Control "public, max-age=31536000" always;
        access_log off;
    # WordPress themes and plugins
    location ~* ^/wp-content/(themes|plugins)/ {
        expires 1y;
        access_log off;
    # All other requests (HTML pages, WordPress content)
    location / {
        add_header Cache-Control "public, max-age=1800" always;
        expires 30m;
    Can you try increasing your PHP time limit to 1200?
    And disable all plugins except GP Premium, GB and GB Pro (if you have it), then import the template.
    Let me know if this helps!
