TWarrior
We have a CPT with a custom field called ‘company_address’.
We display a field dynamically in a text block using {{post_meta key:company_address}} with the ‘required to render’ option enabled (because not everyone has this field filled in)
But we also have the text ‘Address:’ in another text block located above the previous one.
How can we ensure that the ‘Address:’ text block is also ‘required to render’ if ‘company_address’ does not exist?
You can use the Block Conditions feature for this. First, create a condition like the one shown here:
Then simply apply that condition to the Text block. If no company address is available, the entire block will be hidden automatically.
TWarrior
thanks
You’re welcome!
