Hi all,
i have a little problem in the editor. Text looks centered but should be left-aligned.
In the frontend it looks ok.
I will give you admin access; you will find the login details in the private area.
Regards
Michael -
Hi Michael,
Could you try replacing the core Paragraph block with the GenerateBlocks Text block?
It solves the problem. Unfortunately i prefer the paragraph block because paste/copy works easier.
George
Hi Michael,
Glad the GB Text block resolved it. The centered appearance in the editor is a known cosmetic quirk — when a core Paragraph block sits inside a flex container set to column direction, the editor’s default styles cause it to appear centered in the canvas. The frontend output isn’t affected.
If you’d prefer to stick with the core Paragraph block, there’s no functional issue — it’s purely a visual editor thing.
Alternatively, if you don’t need the flex functionality on the parent container you could remove it. Select the parent container and set DISPLAY to
Default.
