Text under image
    is it possible to control text under image centrally?
    Thkx
    It should be possible. For reference, what Block are you using? Could you share a link to where this image is located on your site?
  • I am using the image block and I want to affect the font type under all images on my website.
  • Which Image Block is that? Is it from GenerateBlocks or WordPress? If it’s from GenerateBlocks, you should be able to alter the font from the Block Settings.
  • ok thanks. is there a way i can effect the font under the image at one go – make all the font under the image the same – that is change them from somewhere centrally?
  • We can use a custom CSS.
    If you can share a link on your site with an image with a caption, I can check what CSS is needed.
