please help me with set of colors.See here in a container “before-after-kickstartin” I don’t see text because the color is disappearing but there is a color when I edit the page.
Same with a text “Feeling like you need to explore it” as in edit mode the color is #0c4559 but on the page I see it different.
Hi Ustar,
Can you try a), and if that doesn’t work, try b) here?:
a) Choose Inline Embedding for the CSS Print Method in Settings > GenerateBlocks.
b) Regenerate your CSS files in Settings > GenerateBlocks.Reference: https://docs.generateblocks.com/article/unstyled-content/
hello, thanks
#1 didn’t work
#2 – sorry, i don’t see the option to “Regenerate your CSS files in Settings > GenerateBlocks.” can you describe how to do it?—
for now I highlighted all the text in a block “before-after-kickstartin” to make it visible but we still can if it works with a text “Feeling like you need to explore it” . -
That’s odd. Can you provide admin login credentials through the Private Information field? We’ll try to take a closer look at the issue.
ok
Hi there
the first block on that page is a core Cover Block… and every GB container after it is inside that cover block.
And that block has some really specific block styles for content inside it – including the color of the H2.
Why is everything inside that cover block?
As its going to cause you a lot of headaches 🙂 -
Because I wanted to set up a background picture that sometimes should be visible and sometimes is not (without extra money) and that what i found. If you have a suggestion how to make it different way i here to listen (bare in mind that photos are different on different pages).
( not only H2 not working, it is a “p” also in a container “before-after-kickstartin” )
Yeah that cover block is going to mess with a lot of the styles inside it, as WP writes really opinionated CSS thats going to override most block level styles within it. But to be fair i don’t think the block was intended for that kind of layout.
If you replace the Cover Block, with a GB Container Block, you can give the Container Block a Background Image, and set its Attachment to fixed. You can also add a Psuedo Gradient to act as an overlay if required.
If you add the gradient overlay then make sure to set the z-index of the inner containers
thanks a lot, I thought so, will try to change (see about page)
Before that,
1) what “the z-index” for the gradient overlay should be if I replace “cover” with “GB Container Block” and
2) how to do a “GB Container Block” for full width ?
Do you still need admin credentials? -
1. at least
1
– note when you set the z-index you will set it automatically sets theposition
torelative
and its important that setting is kept.2. on the page you linked to, the GP Content Container is already Full Width. So any Container Block you add to the top level of the page will be Full Width.
No – i don’t need the admin login thank you
thank you, redid all for a container.
Glad to be of help!
