JunaidRaza
Hi, I am using a GP theme, and as I changed the categories, the posts aren’t being extracted from the categories.
You can check the homepage, just above this line “Reach out to suggest topics” I have also added the link where there was an option to add link when we click the image.
Secondly, I turned one element off, and the distance between the headline and the content on the blog post is too short. How can I make it default?
I’ll need to check the backend to investigate the first issue.
As for the second issue, I’m not sure what you mean by “make it default.” Are you referring to the theme’s default blog post layout?
JunaidRaza
Yes, I am referring to the default. You can also set this one but the featured images shouldn’t appear behind the title and the header width shouldn’t be too long. That wasn’t good.
I have shared the link to check backend.
Sorry for the delayed response. The login link you provided seems to have expired.
It looks like you’ve already fixed the post issue, as the posts are now appearing.
For the issue where the headline and content are too close, try adding this CSS:
.single-post .entry-meta { padding-bottom: 3rem; }
JunaidRaza
I have added a new link. It has a week’s expiry.
You can check out on the homepage behind the newsletter block, there are heading names, there I want to see its latest post from each one.
Secondly, I want to add the word Last updated on the date. I don’t know where the word ‘Published’ is gone.
Do you mean the Grid block under the newsletter section?
The category term you entered is IDS like 21, 22, however, I don’t find any categories with ID 21, 22. So try re-selecting the correct category for each of the query blocks.
https://app.screencast.com/FBunlvcEBv8TaFor the date, you can edit the text block directly, and add your static text before the dynamic tag:
https://app.screencast.com/EA6bArooAslbc -
JunaidRaza
I have added the right categories, but it’s only working on the first category and not on the others.
What can be the reason? Do you need access again?
Secondly, I am referring to the date available under each post title when you open the post. There is nothing like updated, published, I want to add Last updated.
Yes, it would be great if you could provide access again so we can take another look.
