The size of the image featured on mobile
  • When I did a performance check of my site on mobile, among other errors was one related to the size of the image featured on mobile. I added these codes in CSS but I couldn’t fix them.
    https://imgur.com/a/8SsX07w
    “/* Settings for smaller sizes (mobile) */
    @media only screen and (max-width: 768px) {
    .featured-image img {
    width: 100%; /* Image takes up the full available width */
    max-width: 100%; /* Prevent container overflow */
    height: auto;
    /* Medium screen (tablet) settings */
    @media only screen and (min-width: 769px) and (max-width: 1200px) {
    width: calc(100% – 40px); /* Adjust for separation */
    max-width: 100%; /* Prevents container overflow */
    height: auto;
    /* Settings for desktop */
    @media only screen and (min-width: 1201px) {
    width: auto; /* Display image at full size */
    max-width: 1160px; /* Prevent container overflow */
    height: auto;
    margin-left: 0;
    margin-right: 0;
    What other CSS solutions could I add?
    Thank you in advance.
    so google is complaining that the images displayed in the latest posts blocks could be of a smaller file size.
    The reason:
    On the mobile device the image is being displayed at a width of 300px.
    And the simulated device google uses has a x2 HD resolution.
    Which means the browser would ideally want an image that is 600px wide and chooses the closest match available which is the medium large with a width of 768px.
    Which is larger than required. Hence the warning.
    Try this CSS:
    .wp-block-latest-posts__featured-image img {
        width: 100%;
        max-width: 384px;
    It will force those images to fill the container but no wider then 384px. Which on a mobile x2 HD device will be 768px for which there is an exact size image available to the browser.
    It should eliminate that issue.
  • Is the code shown in the first post still needed or can I use both? Thanks in advance.
  • The CSS you have as the start of the topic.
    That would only apply to single post featured images, and I am not sure it’s doing anything.
  • I added that code and saw an improvement. Currently after another check I have only one image but it is better than before. Thanks.
  • Glad to be of help
