The template tag for the current slug
  • Hi support
    I use the GP premium and I like to use a template tag for the current slug of a post or page. Is there any tag for that like {{post_title}}?
    http://www.example.com/post/this-is-the-slug.
    Appreciated.
    Flaim
  • Hi Flaim,
    You’ll need to register a custom dynamic tag. Here’s the snippet to do that:
    add_action('init', function () {
        if (!class_exists('GenerateBlocks_Register_Dynamic_Tag')) {
            return;
        new GenerateBlocks_Register_Dynamic_Tag([
            'title'       => __('Post Slug', 'generatepress-child'),
            'tag'         => 'post_slug',
            'type'        => 'post',
            'supports'    => ['source', 'link'],
            'description' => __('Display the post slug for the current post.', 'generatepress-child'),
            'return' => function ($options, $block, $instance) {
                $id = GenerateBlocks_Dynamic_Tags::get_id($options, 'post', $instance);
                if (!$id) {
                    return '';
                $post_slug = get_post_field('post_name', $id);
                if (is_wp_error($post_slug) || empty($post_slug)) {
                    return '';
                return GenerateBlocks_Dynamic_Tag_Callbacks::output($post_slug, $options, $instance);
    Once added, you can use the {{post_slug}} dynamic tag to output the current post’s slug.
