wum0302
On the editor screen, the title and the width of the content are different. I can’t find the reason for the sudden appearance.
It appears only on the editor screen, and when you publish a text, it is published normally with the same width.
does the issue persist if you temporarily disable all plugins ?
wum0302
yes..
Are you using any GP Layout Elements or custom CSS to modify the content width?
If no, could we get a temporarily admin login to take a look at the editor ?
wum0302
How can I give you my manager’s account?
Please edit your first post on this topic, and add the info into the private info field. It will only be seen by the support team.
wum0302
i did it!
Can you disable all plugins except GP Premium and GenerateBlocks to test?
wum0302
If you’re turning it off for a while for testing, you can do it.
Its the PostX Plugin that is setting the Editor Width in its Settings – see here:
