aaronmckeon
Sorry, I’m having trouble finding documentation on this. Can you tell me how to arrange an archive as a grid of posts instead of each one being on their own line? Currently, I have the following:
— Layout element that disables sidebars for the post type archive
— Block element that formats the display of the individual post inside the archiveThe customer has requested we tile the archive (it will be a three-column grid with just the featured image hyperlinked to the post), but I cannot figure out how to make this setting. I can only modify the individual post item, not the archive page itself.
Thanks for any help.
1. go to Appearance > GeneratePress and activate the Blog modules
2. go to Customizer > Layout > Blog, and activate the Columns option. -
aaronmckeon
Thanks. Is there a way to do this only for one post type? I have a custom post type called “Sponsors” that I would like to have laid out in columns. Also, I noticed it makes the first post in the archive big and the rest in columns. Is there a way to make them all the same?
— Aaron
Hi Aaron,
Yes, it’s possible.
1. Keep the columns enabled in the Customizer.
2. Un-toggle “Make first post featured” in Customize > Layout > Blog.
3. Add this snippet:
add_filter( 'option_generate_blog_settings', function( $options ) { if ( !('CPT_SLUG' === get_post_type() && ! is_singular()) ) { $options['column_layout'] = false; } return $options; });
Replace
CPT_SLUG
in the code with the slug of your CPT.Adding PHP: https://docs.generatepress.com/article/adding-php/#code-snippets
aaronmckeon
Thanks. Something strange is happening now, though. Suddenly when I enable columns, it makes all archives EXCEPT the sponsors archive into a grid (even without adding the custom code snippet, so I know it’s not the custom code).
Is there any reason you can think of it would be doing this?
The GP Blog Columns only applies to the
Post
posttype by default.
So you can disable those.
And use this snippet to enable the columns just on the CPT ( make sure the slug is correct ):add_filter( 'option_generate_blog_settings', function( $options ) { if ( !('sponsors' === get_post_type() && ! is_singular()) ) { $options['column_layout'] = true; } return $options; });
aaronmckeon
Unfortunately it does not seem to be having the desired effect. It was actually causing all other post types except ‘sponsors’ to have a column format, so I revised the code as follows:
add_filter( 'option_generate_blog_settings', function( $options ) { if ( 'sponsors' === get_post_type() && ! is_singular() ) { $options['column_layout'] = true; } return $options; });
Now, none of the post types are displaying as columns, including the ‘sponsors’ post type. I’ve put test text inside the conditional section of the code and can see it’s running, but still no columns. Do we need to set the number of columns? Preferably, it would be set to 4. If so, can you let me know the code that’s used?
1. Disable the column set in the customizer > layout > blog.
2. Remove previous PHP code, add this one instead:
add_filter( 'generate_blog_columns', function( $columns ) { if ( 'sponsors' === get_post_type() && ! is_singular() ) { return true; } return $columns; } ); add_filter( 'generate_blog_get_column_count','tu_search_column_count' ); function tu_search_column_count( $count ) { if ( 'sponsors' === get_post_type() && ! is_singular() ) { return 25; } return $count; }
aaronmckeon
That did the trick! Thanks.
