Toggles with GenerateBlocks
  • Hi!
    I would like to further style toggles to create an expandable timeline similar to the one I am sending in the link below. Would it be possible?
    Thanks in advance and best regards!
    That is essentially an accordion. If you have GenerateBlocks Pro, you can use the Accordion block to create it. Regarding the styling, you might need to use custom CSS to achieve a similar effect.
  • Hi!
    Yes, I am using Accordion. Nevertheless, I am finding trouble of making it work with custom CSS.
  • If you can share what have you done so far, we will see what we can advise in regard to that.
