Tooltips in GB?
  • Hi team,
    I’m looking for a way to create tooltips (for links or general for elements).
    Specifically, when I hover over a link that opens in a new tab, I need a tooltip to appear that says: “opens a new window”
    How can I implement this in GB?
    I have seen something similar on your GP Pricing page
    Is there a snippet for this?
    Thank you!
    You can create a :before selector for the link, and set it to display:none in normal state, and set it to display: block in hover state.
    You can position it by setting the position to absolute (the link/text main selector needs to be set to position: relative), and play with the left/right/bottom/top inset values.
  • Sorry, I can’t manage that.
    How can I set a :before selector to a hover state?
    Where can I save the text that should appear in the tooltip on hover?
  • How can I set a :before selector to a hover state?
    Create a selector .gb-element-xxxxxxx:hover:before.
    In the content field of the .gb-element-xxxxxxx:beforeselector.
  • Hi Ying,
    thanks for your hints, but unfortunately that doesn’t work at all.
    Can you tell me how it was done on your pricing page?
    link in private
  • Please consider voting for tooltips: https://feedback.generatepress.com/113.
    The tooltip used on the GeneratePress site is powered by a third-party library called Microtip.
    If you’d like to implement the same approach, you can follow the official documentation here:
    https://microtip.vercel.app/
  • Hi Alvind,
    thanks for the tip with the library! It works very well.
    There is just one last question:
    I would like to add a tooltip to individual links within a paragraph.
    Could you take a look at the page in the private field?
    Do you have any idea how I can add HTML attributes to the linked words in the text?
    Thank you!
  • I don’t think it’s possible to add attributes to the linked words, but you can target it with selector .gb-text-xxxxxx a.
    Below is a text block that made by the method I said, have a look 🙂
    <!-- wp:generateblocks/text {"uniqueId":"781a4e5d","tagName":"p","styles":{"a":{"color":"#ed1515","position":"relative"},"a::before":{"content":"\u0022test\u0022","position":"absolute","display":"none","bottom":"100%","left":"50%","transform":"translate3d(-50%, 0px, 0px)"},"a:hover::before":{"display":"block"}},"css":".gb-text-781a4e5d a{color:#ed1515;position:relative}.gb-text-781a4e5d a::before{content:\u0022test\u0022;position:absolute;display:none;bottom:100%;left:50%;transform:translate3d(-50%,0px,0px)}.gb-text-781a4e5d a:hover::before{display:block}"} -->
    <p class="gb-text gb-text-781a4e5d">This is a paragraph. Within this paragraph <a href="https://gp-one.carenda.de/tooltip/#"><strong><mark style="background-color:rgba(0, 0, 0, 0)" class="has-inline-color has-base-2-color">one or more words</mark></strong></a> should be linked.</p>
    <!-- /wp:generateblocks/text -->
  • Hi Ying,
    Unfortunately, that’s not what I mean.
    At Alvind’s suggestion, I have integrated the Microtip Tooltip Library.
    And it works well, as you can see on my page.
    The blue button is equipped with a tooltip from the Microtip Library.
    This works very well for the button because it is a block element.
    However, I need the tooltip for an inline element (in the middle of a paragraph).
    For the tooltip to work, the HTML must be equipped with certain attributes:
    https://prnt.sc/FJwSMg3zJWwz
    Usage: https://prnt.sc/KR3ZR2_xPvxu
    How can I get GB to set a <span> tag within the paragraph so that I can assign the HTML attributes to this span tag?
  • How can I get GB to set a <span> tag within the paragraph so that I can assign the HTML attributes to this span tag?
    You can use the WP highlight option in the floating toolbar, but it adds <mark> tag around the link, and the text block does not have the option for you to fill attributes for its child elements.
    So no, I don’t think you can do so. You might need to use a custom HTML block to manuuly add the text/link and attributes.
  • Ok, thanks for your help, Ying!
    Yes, I’ve done it this way now if need be.
    Thanks 🌷
  • You are welcome   🙂
Viewing 13 posts - 1 through 13 (of 13 total)
