Hey
https://i.postimg.cc/cHwcYTfd/image.png
From the image we can see the top bar of my website. But it is a little messy.
First how do I create the same space above the logo, as below. (Red arrows)
Also how do I remove the empty space between the top bar and logo header. (pink line)
Can you link us to the page in question?
You can use the private information field.
done. Thanks
Your site ins under maintenance mode, I didn’t see your site, can you disable it for now for me to check?
Hey
Sorry about that
Check now
Is this your CSS?
.site-header .inside-header { padding: px 1% 4px 6.2%; }
if so, the CSS is invalid, remove it.
then go to customizer > layout > header, and set up the Header paddings there.
Hey
thank you for padding help but there is still a gap between the top bar and the navigator menu
Pink line
How do i fix that
Edit the Top Bar Element and remove the empty paragraph block below it. See here:
https://cln.sh/N6vQQSrs -
hey
https://i.postimg.cc/QdDHzFnk/image.png
I cant see the empty paragraph. Do i have to remove it somewhere else?
Open the block list view, you can remove the paragraph from there.
You can also type some words, then select them and remove them.
