gpetar
I know there are topics about this but I am unsure if the solution with the code is universal for all sites. So, I am getting this message. How do we locate the problem? Because I use generatepress in the similar configuration on other domains and there is no such message
thanks
where are you seeing the warning ?
The issue is with the Links in the Easy Table of Contents list.
Check in the TOC plugins settings and set the Font Size to a great value eg 100%. -
gpetar
thank you so much
You’re welcome
