Stefanie
Hi team,
In this Page Hero I used translateX to move the images to the left. Unfortunately, this creates a strip at the edge of the image. I wonder if there is a way to prevent this. Is there anything I can do to give the image more space on the side? Do you have any ideas?
Thank you!
I’m not sure if there’s a workaround for this, unless you use an image with a wide enough dimension to allow it to slide fully before being cut off.
Alternatively, I suggest using a different effect, like zoom in/out—or for something more fancy, like the Ken Burns effect.
Stefanie
thanks for your feedback!
I specifically don’t want to use the Ken Burns effect (zoom in/out).unless you use an image with a wide enough dimension
That’s exactly what I’m trying to do!
I uploaded a 3000px wide image, but (I don’t know why) it behaves exactly like the images I have in there now (these are 1920px wide).
Thank you!
If you are translate -15% in x direction, then you need to increase the width of the background image for 15%.
Currently, you have this CSS. Try changing the width to 115% instead of 100%.
.bg-fade { position: absolute; content: ''; width: 100%; height: 100%; inset: 0; background-size: cover; background-position: center center; opacity: 0; animation-name: fade-move; animation-duration: 33s; animation-iteration-count: infinite; } -
Stefanie
Wow, that’s such a good idea, Ying!
It works like a charm 🙂Thanks a bunch 🌷
