Trying to change individual link colors
  • Where did the color palette go in the editor sidebar?(shot 1) My editor sidebar changed about a week ago due to me or something else. I finally figured out how to change an individual link color from the tiny little buttons at top of the new element editor sidebar.(shot2) When I try to change the hover color it changes the sentence, not the link on hover.
    So, if I want a red link with green hover this happens – On hover the link stays red, the underline disappears (ok), non linked sentence turns green instead of the link. (Shot 3)
    Color palette was so much easier.
    https://imgur.com/a/YLK68uG
    The UI shown in screenshot 1 is from a V1 block. You’ve likely updated to V2, and in V2 the block UI has changed, which is what you’re seeing in screenshot 2.
    In V2, to change the link hover color, open Manage Selectors and select the Hovered Links selector. You can refer to this short video for guidance: https://cln.sh/TJRJ5CKvMLMBXw2kVz1n
    If you prefer to continue using the V1 settings, you can roll back by following this documentation:
    https://learn.generatepress.com/blocks/block-guide/generateblocks-1-x-to-2-0/#how-to-return-to-version-1-0-blocks
