Trying to create 2 column block hook
    Trying to create a 2 column block hook like in screenshot att.
    Weirdly, when I set the 2 containers in the two colum grid that are set at 50% they align fine at 50PX but when I try to set them to 500 each they stack and the 500 width refreshes to 50.
    Main container I dont have a defined width as per other block hooks but if i change it makes no difference however the max width box I cant input.
    Thanks.
  • Hi Rob,
    When you say 50px, are you referring to height, width or something else? Can you let us know?
  • 50px width, I am trying to set them to maybe 450px width.\
    Thanks.
  • I’m not sure I understand still. Can you explain a bit more?
    The screenshot you shared seems to just be using a 50% width for both Columns/Containers.
  • The screenshot I shared is what trying to achieve. It is not my site.
  • I’m trying to recreate that screenshot.
    I am trying to set the width of each grid container to 500px – max width is blocked out. If I place 500px in top width box of each container they stack – the containers stack on top each other, the containers don’t align next to each other horizontally.
  • Give the Columns a 50% width.
    Then, insert the Grid inside a Grid Block that has a 1000px max-width. That should work to achieve the look you’re going for.
  • Dont understand mate sorry, I see nowehere to set the grid block to 1000px – do u mean the container it is inside?
    And secondly to clarify – I should place a grid in another grid?
    ss att
  • Do u mean the “editor width” under “block element” under “element”?
  • This is what I mean -> The setup should be something like this:
    -Container Block
        -Grid Block
            -Container Block
            -Container Block
    The parent Container Block should have a max-width of 1000px. It then has a Grid Block inside it which has 2 columns.
    The two Container Blocks under the Grid Block should have a width of 50%.
  • Thanks Fernando, that’s worked.
    For the social icons in the new ss, I’ve created 3 column grid in container, but the actual “share on facebook” etc icons – are they found in GB?
  • There’s no such feature in GB.
    You’ll need a third-party plugin or a custom code for such a share button.
    What’s there in GB is a regular link button to which you can add an icon to. Reference: https://docs.generateblocks.com/article/icon-overview/
  • No worries, thank for clarifying Fernando.
    Thanks for the link.
  • You’re welcome, Rob!
  • Hi, sorry, bit off track but:
    1. I have replicated social share image and text design – pls see ss att, i need specific code right for each social platform that generates the share link?
    Or,
    2. Would you know how to keep this shortcode’s social media icons on a flat level in a container. I’ve tried padding but no joy or adjusting the min or max height of the container to just a slighty greater px as the social icon image. Right now you can see they are not on a level surface.
    Thanks,
  • Can you share the link to where we can see you’ve implemented this?
Viewing 16 posts - 1 through 16 (of 20 total)
