Two button elements show at the same time when using off canvas panel
    I have two block-hook elements, which are phone number buttons in the menu. However, the problem is that I use the off-canvas panel as my mobile navigation, and when I open the off-canvas panel on mobile, there is also displayed the other element (button) in the background:
    The website is https://zamecnikplzennonstop.cz/
    The logic for the elements is the following:
    – Appointment button – Menu | Block – Hook generate_after_primary_menu | Entire Site
    – Appointment button – Slideout navigation | Block – Hook generate_after_slideout_navigation | Entire Site
    So, I’d need to display only the off-canvas element when actually opening the off-canvas on mobile.
    Thank you very much.
    The strange behaviour is due to your custom CSS:
    #site-navigation.toggled .inside-navigation > .gb-button {
        display: block !important;
        order: 5;
    Removing the CSS should fix the issue.
