Two column grid – width control
    I have a two column grid that is by default 50:50 width. I used to be able to change the size of the containers (eg 40% 60%) and that would work but now when I specify the size % it becomes 40% of the original 50%.
    How can I set the two column to a 40:60 ratio?
    Thanks.
    Set the container’s display to grid, and set grid-template-columns to 2fr 3fr.
  • Like in the attached.
    This didn’t do anything so maybe I did something wrong.
    You placed 2fr 3fr in the Grid Template Rows field — it should be in the Grid Template Columns field instead.
  • Oh, I see, right.
    Unfortunately, that hasn’t worked either. Actually, it worked in the page editor but hasn’t worked on the frontend, despite clearing every cache I can think of and trying multiple browsers and through a VPN.
  • Can you share the URL so we can inspect what might be causing the issue?
  • I had built the block as an element. I’ve found that if I copy and paste the block directly into the page (removing the element), it loads correctly but when I load into the page as an element it doesn’t respond to those updates.
    Is there some kind of caching related to Elements?
  • There isn’t any dedicated caching mechanism applied to Elements — they’re simply custom post types, just like regular pages.
    It’s possible that the block’s stylesheet isn’t being enqueued within the Element, but I can’t confirm that without inspecting the site directly.
