Type Font
  • Hi: How do I get or find out what font is being used on http://www.PropertyLender.com where I can put in other wording with the same font?
    Also, I can I put my phone number in the middle from the upper right hand corner?
    Also, how do I center this portion?
    Thanks in advance.
    Is that your own site? You can check which font is being used by going to Customize > Typography
    You want ti to be aligned with the menu at the top?​
  • Yes. It is my site.
    Also, yes, I am trying to align the phone number to the middle.
    However, I would also like to move where it says “Today’s Rates” to the middle as well.
    Thanks again
  • Just to confirm, is the menu at the top using the secondary navigation?​
    I honestly do not know.
    The entire site (including the text at the top) is using “Montserrat”.
    This is set in Customize > Typography, and applied to the body of the site.
    To center the phone number, go to “Appearance > Elements” and choose the “Top Bar” Element.
    Select the Headline block, and go to the Typography section. Then choose the center option: https://www.screencast.com/t/WTMyc5uH
    Hope this helps!
  • Thank You.
    How do I center the middle that states “Today’s Rates”
    Thanks again
  • It looks like you’ve already changed the website layout. Do you still need help with this?
  • No Thanks.
  • Sure, no problem 🙂
