lenny4
I have just set up my WordPress site using the **Resolution** starter site.
I noticed that the background of the section with the class
.gb-element-0bdb0011is currently set to:`css
background:
radial-gradient(rgba(102, 70, 232, 0.2) 0%, rgba(255, 255, 255, 0) 50%),
radial-gradient(rgba(235, 236, 242, 0.94) 0%, var(–base-3) 80%),
url(https://egas-solutions.com/uploads/2025/08/pattern-1.png) center / 600px repeat fixed;
`Screenshot:
https://egas-unrestricted.s3.eu-west-3.amazonaws.com/resolution-background.pngI cannot find where this background is configured in GenerateBlocks:
* The **Hero section** has background settings, but only for
background-image.
* The **Inner container max-width** does not show any background configuration.However, I believe the Inner container max-width is the correct element because it uses the same class and seems to be the element receiving the background style.
Second screenshot:
https://egas-unrestricted.s3.eu-west-3.amazonaws.com/resolution-background-2.pngHow can I change this background color/background style from the GenerateBlocks editor?
The background images are set in the backgrounds panel of the 1st root container.
https://app.screencast.com/wrxwE13MN1zssLet me know if this helps!
lenny4
Nice thank you
No Problem 🙂
