Unable to Change Heading Sizes & Spaces in the content area
  • I’ve installed the Painter theme from the site library.
    But I’m not able to make changes to any of the headings, i.e sizes, bold/italic, etc. and also not able to put spaces between different parts of the content i.e between paragraphs/headings etc.
  • I got to find it out that the issue is with the html/css code I used for a portion in the article. Would like to know if you can provide any solution so that the CSS code doesn’t interfere with the website theme code.
    Yes, the issue is caused by another stylesheet defining the same selector, which overrides the settings and creates a conflict.
    It looks like you’re using the Tailwind CSS stylesheet. May I ask what you need it for? It overrides many of the settings that can be configured in the Customizer, so in most cases it isn’t necessary.
  • Hey, I’ve rewritten the code, and the issue has been resolved. Thanks 🙂
  • Glad to hear that 🙂
