Unable to change Order in Grid?
  • Hi team,
    I am setting up responsiveness for 2 blocks within a Grid layout and despite setting the order for a content container and an Image, the order has no affect? As you will see, the Image is set to 1 and Text container to 2, but still the text is coming first when viewed on tablet or Mobile?
    The parent Container (.gb-element-618f8b47) needs to use either Display: Flex or Display: Grid for the Order setting to have any effect.
    If it’s using the default block layout, the Order property won’t be applied.
  • I cant find the container (.gb-element-618f8b47), but the parent container I can see is (.gb-element-8b11c9ba). I’ve tried changing that to flex and grid, but it still doesn’t change the order?
  • Sorry, I thought you were referring to the $55 Weekday Lunch section.
    The Container whose Display property needs to be changed is .gb-element-5289d0c3. It’s the inner Container inside .gb-element-8b11c9ba.
  • I tried Flex under the tablet settings and that just makes the text disappear all together. So I set it to Grid and while it isn’t too bad when viewed on a mobile, it still has the 2 containers side by side when viewed on a tablet, but has swapped sides and is very messy?
    Please see now.
  • Would changing the ‘Grid Template Columns’ to 1fr be the fix for this?
    Yes, that’s correct. You can set it to 1fr, or 100% will work as well.
