Unable to Change the Background Image
  • Hi, i am trying to Change the Background image which is Shown on Post Page but unable to Find the Image Changing Option please Help!!!
    Please Check out the pictureImage
    go to Appearance > Elements and edit the element titled: Single post header
    Select the top most Container Block.
    Check the block settings sidebar -> Background panel where you can set a different image.
    If you want to dynamically display the post featured image there, then in block settings enable the Dynamic Data and set it to show the featured image.
