megmarrs
Despite applying the full-width layout element to my page “enrichment 2.0”, I am unable to get the page to appear full-width. Can you help me figure out the issue?
Page in question: https://www.k9ofmine.com/enrichment-video-course/ -
The GB container’s width is set to 850px, it can not be full width with a fixed width set:
https://app.screencast.com/7xoYL5Ekzzfc4If you remove the width, it will be full width automatically.
megmarrs
Thank you Ying. I’m having a hard time seeing where I can edit or adjust that width. I see there is some kind of CSS styling, but not sure how to change or where to find that.
It’s in the sizing panel.
megmarrs
The sizing panel is showing blank for me when I’m selecting the container element. https://imgur.com/a/jOxysaX
You’re looking at the wrong container. It should be the nested one inside the current container you’re selecting.
megmarrs
There’s nothing for the sizing panel in the nested container either. https://imgur.com/a/adML1BP
You ar using a block element – content template for the page, the max-width is applied to the content template container.
But it’s a static page, why are you using a content template? Disable the content template should fix the issue.
