Unable to edit reusable blocks
  • I have a resusable block listing travel resources that I put into the end of almost all of my blog posts, I need to edit it (and have the change apply sitewide) but I cannot edit it. It seems to be locked (checked for that obvious option and it isn’t). I can edit everything else sitewide just fine, not sure what is causing the conflict.
    Is this issue occurring with just this specific pattern, or are you unable to edit any other patterns as well?
  • It happens with all my reusable blocks, where if I click “edit original” it makes it editable but in a VERY narrow space. If the block is longer than that narrow space I can’t see it to edit it, screenshot attached.
    screenshot
  • The issue is caused by WP removing the min-height for the content area, so the meta boxes move up and squeeze the content area.
    If you access the pattern from GenerateBlocks > local patterns, does the editor work better?
