Unable to insert dynamic image
  • I have a Loop Template Element, and I am trying to display data dynamically from ACF. All of my text based fields display just fine, but I’m having trouble with my image field, which contains a logo. I have tried setting the return type to image array, image url, and image id with no luck.
    If I preview the post page, where the image should be displays "/> if the type is an image array and https://url/for/image.png"/> if the type is image url.
    What could be going wrong here?
    Can you confirm that the meta key name for the image field is entered correctly in the dynamic tag settings?
    If it is, and if possible, could you provide temporary admin access so we can take a closer look at the backend setup?
  • Yes, I selected it directly from the login.
    I will do so.
  • I see the username and password in the private info field. Could you also provide your site link?
  • My apologies – added it.
  • No worries.
    I logged in. Which page is it?
  • The Element is Business Loop Template, which should display on pages under the Business menu dropdown: ex. https://SITE_URL/business-type/beauty/. The ACF type I’m using is Business.
  • I removed the dynamic link from the dynamic panel for the image and re-linked it in the settings panel; it seems to fix the problem.
    Can you check and let me know?
  • Oh whoa that did it! I don’t understand why it didn’t work before, but thank you 🙂
  • You are welcome   🙂
