Unable to line up Footer containers
  • Hey team,
    I am having trouble getting the Privacy Policy and Cancellation Policy links, to sit neatly at the bottom of the footer. If I add space, it pushes down the copyright line, when what I want is the copyright and the 2 links to be inline with each other.
    Also, how do I remove the underline from the 2 links?
    Try adding this CSS:
    .gb-grid-wrapper-ab5bdd9e {
      p {
        margin-bottom: 0;
      a {
        text-decoration: none;
    It should fix both issues.
  • Hey Alvind,
    That worked perfectly, thank you. How can I remove the underline from all links?
  • If the links are in the content area, you can remove the underline globally by going to Customize > General > Underline Links and disabling it.
  • Thanks Alvind. Is that a new feature or have I just never noticed it?
  • You’re welcome!
    It’s not a new feature; it’s been available since an earlier version, though I’m not sure exactly which one.
