bearbully
Hi, I am on GeneratePress One but is unable to locate pattern 68 from /pattern-library/
For assistance please.
That particular pattern is available in the Pro version. Just to confirm, have you installed and activated GenerateBlocks Pro on your site?
Let me know.
bearbully
Yes, I have activated GenerateBlocks Pro.
Is your site still currently using Version 1 blocks? If so, try disabling Use Version 1 Blocks under GenerateBlocks > Settings in the admin dashboard, then save the settings.
After that, try importing the pattern again and see if it shows up correctly.
bearbully
There isn’t such a settings. I am using Version 2.5.0
That means you’re already using the V2 blocks version.
Would it be possible for you to provide temporary admin access so we can take a closer look at the backend?
bearbully
sure, as requested
The Pattern 68 is available to import in your site. If you search for 68 in the Pattern Library search box, it should appear.
Please refer to this short screen recording: https://cln.sh/GX6y4G2TqHFZnWMTrdkp
bearbully
thanks! I was using the “Block Inserter” and unable to locate it.
No problem!
