Unable to Remove Author from Blog Posts
    Website – https://colombiaroadtrip.co.il/
    I’m having trouble removing the author from the blog posts
    https://imgur.com/aiHk3NR
    Here’s what I’ve already tried:
    Customizer Settings:
    Appearance > Customize > Layout > Blog > Posts
    I unchecked “Display post author” it still appears there
    Elements:
    I also went to Appearance > Elements and edited the following templates:
    Archive page hero
    Blog loop template
    Post page hero
    In the block editor for these elements, I checked the inner structure via the List View and made sure there are no author blocks present — only the image, post title, and post date.
    Despite all of this, the author still shows up on the front end.
    Is there something I’m missing or a conflict I should be aware of?
    Thanks in advance!
    Edit the Post Page Hero element and simply remove the Dynamic Image block: https://cln.sh/j6KYlfzB
  • Finally, that’s working 🙂
    Thank you!
  • Glad to hear that!
