Unable to Set Max Width for Container
    I can’t seem to be able to set the max width property for container block on pages.
    The option is greyed out.
    I’m currently setting the width to 75% but this is not an ideal situation. I want to set max width to 800px to deal with content wrapping issues.
    I’ve included my site in the private area
    Can you make sure this is done so we can have a cleaner look at the code?
    https://www.screencast.com/t/ryak6tw7
  • Hi, I just did
    Deactivated AutoOptimize and Litespeed
  • The option is greyed out.
    Never heard of this issue, can you provide an admin login so we can take a look at the backend?
    Let me know where to see the container block with this issue.
  • Sure, you can login using the info in the private area.
  • Actually,
    I see the issue now.
    It was because the container was inside a grid block. But the grid block helps center the container. Now the container has a max-width but I can’t center it. How do I center the new container?
  • Set the container’s margin-left and margin-right to auto.
  • That fixed it thanks. Didn’t know that the field can take auto as input
  • Yes, it’s an upgrade of the new GB system 🙂
