mht2024
I can’t update “GenerateBlocks Pro” plugin.
When I try to update the plugin, I get this notification:
Update Failed: Download Failed. Unauthorized.According to this page, I need to add a domain name into the list of authorized sites. https://docs.generatepress.com/article/authorizing-site-urls/
However, I already have a site URL in the list. I did that months ago.
What should I do?
Thank you!
Can you re-try the procedure shown in the article?
So remove the URL and then re-add it.
mht2024
Just confirming:
I should “deactivate site”? -
Yes 🙂
mht2024
Thank you!
It worked! Will I have to deactivate and activate the URL each time I want to update the plugin? -
No – it’s likely that the URL changed (maybe from staging to live?)
You would only need to do this if the URL has changed.
mht2024
Thank you!
No problem 🙂
