obxbeachbum
I just upgraded to GBPro 2.1 and I noticed my Text Block was missing. Then I noticed it was showing QueryLoop instead of the new Query block. I’m going to delete them and go back to 2.0 to check after I post this here. I’m not familiar with the GBPro blocks enough to know what else is missing.
obxbeachbum
They are still missing after delete and reinstall of 2.0.
Check if the Use version 1 blocks option is enabled under GenerateBlocks > Settings in the admin menu. If it is enabled, simply disable it.
obxbeachbum
Thank you. I found that shortly after I posted. Apparently when I posted about it here, it didn’t go through. I do appreciate you helping me out though.
Glad to hear that!
