Use course features with other theme?
    I’d like to use the course features of the Education theme with another theme of Generate press (mostly the archive as well as the single course presentation, eg https://sites.generatepress.com/education/courses/single-course/).
    Is it as easy as copying the needed layout from the course theme to the other theme or will I see problems?
    What would be the recommended way?
    Best,
    Thomas
  • Hi Thomas,
    The single course in the Education template is just a regular page.
    You can copy the blocks from the single course page and paste it to a new page editor on your site. You will see some differences between the Education template and your site, because the 2 sites have different customizer settings.
    Here’s the blocks:
    <!-- wp:generateblocks/element {"uniqueId":"212c8daf","tagName":"div","styles":{"position":"relative","@media (max-width:767px)":{"paddingBottom":"7.5rem"},"backgroundImage":"linear-gradient(180deg, var(\u002d\u002dbase-3) 0%, var(\u002d\u002dbase) 100%)","backgroundSize":"cover","backgroundRepeat":"no-repeat","backgroundPosition":"center","backgroundBlendMode":"normal","paddingTop":"2rem","paddingBottom":"14rem","textAlign":"center"},"css":".gb-element-212c8daf{background-blend-mode:normal;background-image:linear-gradient(180deg,var(\u002d\u002dbase-3) 0%,var(\u002d\u002dbase) 100%);background-position:center;background-repeat:no-repeat;background-size:cover;padding-bottom:14rem;padding-top:2rem;position:relative;text-align:center}@media (max-width:767px){.gb-element-212c8daf{padding-bottom:7.5rem}}","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <div class="gbp-section gb-element-212c8daf"><!-- wp:generateblocks/element {"uniqueId":"598b3487","tagName":"div","styles":{"justifyItems":"center"},"css":".gb-element-598b3487{justify-items:center}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container max-width"}} -->
    <div class="gbp-section__inner gb-element-598b3487"><!-- wp:generateblocks/text {"uniqueId":"485d6ca5","tagName":"h1","styles":[]} -->
    <h1 class="gb-text">Course name</h1>
    <!-- /wp:generateblocks/text -->
    <!-- wp:generateblocks/text {"uniqueId":"53dd6c63","tagName":"p","styles":{"maxWidth":"800px","marginLeft":"auto","marginRight":"auto"},"css":".gb-text-53dd6c63{margin-left:auto;margin-right:auto;max-width:800px}"} -->
    <p class="gb-text gb-text-53dd6c63">Use as many words as you need to describe the nature of the course and the potential that this course has for improving your client's skills.</p>
    <!-- wp:generateblocks/element {"uniqueId":"7271bed3","tagName":"div","styles":{"display":"flex","columnGap":"0.3em","rowGap":"0.3em","flexWrap":"wrap","marginBottom":"2rem","justifyContent":"center"},"css":".gb-element-7271bed3{column-gap:0.3em;display:flex;flex-wrap:wrap;justify-content:center;margin-bottom:2rem;row-gap:0.3em}"} -->
    <div class="gb-element-7271bed3"><!-- wp:generateblocks/element {"uniqueId":"edfc461a","tagName":"div","styles":{"display":"flex"},"css":".gb-element-edfc461a{display:flex}"} -->
    <div class="gb-element-edfc461a"><!-- wp:generateblocks/text {"uniqueId":"7dfc69a8","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-7dfc69a8{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-7dfc69a8 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-7dfc69a8"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"b1f517c9","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-b1f517c9{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-b1f517c9 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-b1f517c9"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"b51375d6","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-b51375d6{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-b51375d6 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-b51375d6"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"23730c7a","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-23730c7a{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-23730c7a .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-23730c7a"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"c128acf1","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0"},"css":".gb-text-c128acf1{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0}.gb-text-c128acf1 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-c128acf1"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- /wp:generateblocks/text --></div>
    <!-- /wp:generateblocks/element -->
    <!-- wp:generateblocks/text {"uniqueId":"18f6f58d","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","marginBottom":"0px","fontWeight":"600"},"css":".gb-text-18f6f58d{color:var(\u002d\u002daccent);font-weight:600;margin-bottom:0px}"} -->
    <p class="gb-text gb-text-18f6f58d">(121 Students)</p>
    <!-- wp:generateblocks/element {"uniqueId":"ab37447b","tagName":"div","styles":{"display":"flex","flexDirection":"row","alignItems":"center","justifyContent":"center","rowGap":"0.5rem","textAlign":"left","columnGap":"0.8em","marginBottom":"1em","paddingBottom":"0.8rem"},"css":".gb-element-ab37447b{align-items:center;column-gap:0.8em;display:flex;flex-direction:row;justify-content:center;margin-bottom:1em;padding-bottom:0.8rem;row-gap:0.5rem;text-align:left}","htmlAttributes":[],"metadata":{"name":"Meta Byline"}} -->
    <div class="gb-element-ab37447b"><!-- wp:generateblocks/media {"uniqueId":"40f5d21a","tagName":"img","styles":{"width":"50px","height":"50px","borderTopLeftRadius":"100%","borderTopRightRadius":"100%","borderBottomLeftRadius":"100%","borderBottomRightRadius":"100%","display":"block"},"css":".gb-media-40f5d21a{display:block;height:50px;width:50px;border-radius:100%}","globalClasses":["gbp\u002d\u002dborder"],"htmlAttributes":{"src":"https://patterns.generateblocks.com/wp-content/uploads/2023/08/placeholder600x.svg","title":"placeholder600x","alt":"User avatar placeholder"},"mediaId":4266,"linkHtmlAttributes":[],"metadata":[]} -->
    <img class="gbp--border gb-media-40f5d21a" src="https://patterns.generateblocks.com/wp-content/uploads/2023/08/placeholder600x.svg" title="placeholder600x" alt="User avatar placeholder"/>
    <!-- /wp:generateblocks/media -->
    <!-- wp:generateblocks/element {"uniqueId":"e3a9c07b","tagName":"div","styles":{"columnGap":"0.3rem","display":"flex"},"css":".gb-element-e3a9c07b{column-gap:0.3rem;display:flex}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-element-e3a9c07b"><!-- wp:generateblocks/text {"uniqueId":"50b6eacd","tagName":"div","styles":{"fontSize":"0.9rem"},"css":".gb-text-50b6eacd{font-size:0.9rem}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-text gb-text-50b6eacd">By</div>
    <!-- wp:generateblocks/text {"uniqueId":"a2d152d5","tagName":"div","styles":{"fontWeight":"700","fontSize":"0.9rem"},"css":".gb-text-a2d152d5{font-size:0.9rem;font-weight:700}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-text gb-text-a2d152d5">Instructor</div>
    <!-- /wp:generateblocks/element --></div>
    <!-- wp:generateblocks/element {"uniqueId":"6a60b6b3","tagName":"div","styles":{"position":"relative","@media (max-width:767px)":{"marginTop":"-5rem"},"paddingTop":"0rem","marginTop":"-12rem","zIndex":"1","paddingBottom":"3rem"},"css":".gb-element-6a60b6b3{margin-top:-12rem;padding-bottom:3rem;padding-top:0rem;position:relative;z-index:1}@media (max-width:767px){.gb-element-6a60b6b3{margin-top:-5rem}}","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <div class="gbp-section gb-element-6a60b6b3"><!-- wp:generateblocks/element {"uniqueId":"be57f5be","tagName":"div","styles":{"justifyItems":"center","textAlign":"center"},"css":".gb-element-be57f5be{justify-items:center;text-align:center}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container max-width"}} -->
    <div class="gbp-section__inner gb-element-be57f5be"><!-- wp:generateblocks/media {"uniqueId":"93ec0e9d","tagName":"img","styles":{"height":"600px","maxWidth":"100%","objectFit":"cover","width":"100%","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px"},"css":".gb-media-93ec0e9d{display:block;height:600px;max-width:100%;object-fit:cover;width:100%;border-radius:6px}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3-768x576.png","title":"image-4-3","alt":"Image placeholder"},"mediaId":46292} -->
    <img class="gb-media-93ec0e9d" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3-768x576.png" title="image-4-3" alt="Image placeholder"/>
    <!-- /wp:generateblocks/media --></div>
    <!-- wp:generateblocks/element {"uniqueId":"0291d84b","tagName":"div","styles":{"position":"relative","@media (max-width:767px)":{"paddingBottom":"7.5rem"},"zIndex":"1","paddingTop":"0rem","paddingBottom":"4rem"},"css":".gb-element-0291d84b{padding-bottom:4rem;padding-top:0rem;position:relative;z-index:1}@media (max-width:767px){.gb-element-0291d84b{padding-bottom:7.5rem}}","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <div class="gbp-section gb-element-0291d84b"><!-- wp:generateblocks/element {"uniqueId":"1c1434ab","tagName":"div","styles":{"textAlign":"center","display":"grid","gridTemplateColumns":"4fr 2fr","columnGap":"4rem","rowGap":"4rem","@media (max-width:1024px)":{"gridTemplateColumns":"1fr"}},"css":".gb-element-1c1434ab{column-gap:4rem;display:grid;grid-template-columns:4fr 2fr;row-gap:4rem;text-align:center}@media (max-width:1024px){.gb-element-1c1434ab{grid-template-columns:1fr}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container max-width"}} -->
    <div class="gbp-section__inner gb-element-1c1434ab"><!-- wp:generateblocks/element {"uniqueId":"aea6bb43","tagName":"div","styles":{"@media (max-width:1024px)":{"order":"1"}},"css":"@media (max-width:1024px){.gb-element-aea6bb43{order:1}}","metadata":{"name":"Content Container"}} -->
    <div class="gb-element-aea6bb43"><!-- wp:generateblocks-pro/tabs {"uniqueId":"43787cd9","tagName":"div","styles":{"display":"flex","columnGap":"20px","rowGap":"20px","flexDirection":"column"},"css":".gb-tabs-43787cd9{column-gap:20px;display:flex;flex-direction:column;row-gap:20px}","htmlAttributes":{"data-opened-tab":"1"}} -->
    <div class="gb-tabs gb-tabs-43787cd9" data-opened-tab="1"><!-- wp:generateblocks-pro/tabs-menu {"uniqueId":"5ea87850","tagName":"div","styles":{"display":"flex","columnGap":"10px","@media (max-width:767px)":{"overflowX":"auto","maxWidth":"100%"},"alignItems":"center","marginBottom":"2rem"},"css":".gb-tabs__menu-5ea87850{align-items:center;column-gap:10px;display:flex;margin-bottom:2rem}@media (max-width:767px){.gb-tabs__menu-5ea87850{max-width:100%;overflow-x:auto}}","htmlAttributes":{"role":"list"}} -->
    <div class="gb-tabs__menu gb-tabs__menu-5ea87850" role="list"><!-- wp:generateblocks-pro/tab-menu-item {"uniqueId":"1559a4a1","tagName":"div","styles":{"\u0026:is(:hover, :focus)":{"backgroundColor":"var(\u002d\u002daccent)","color":"var(\u002d\u002dbase-3)"},"\u0026:is(.gb-block-is-current, .gb-block-is-current:hover, .gb-block-is-current:focus)":{"backgroundColor":"var(\u002d\u002daccent)","color":"var(\u002d\u002dbase-3)"},"@media (max-width:767px)":{"flexGrow":"1","flexShrink":"0"},"borderTopLeftRadius":"9999px","borderTopRightRadius":"9999px","borderBottomLeftRadius":"9999px","borderBottomRightRadius":"9999px","color":"var(\u002d\u002dcontrast-3)","paddingLeft":"20px","paddingRight":"20px","display":"flex","alignItems":"center","justifyContent":"center","paddingTop":"10px","paddingBottom":"10px","backgroundColor":"var(\u002d\u002dbase-2)"},"css":".gb-tabs__menu-item-1559a4a1{align-items:center;background-color:var(\u002d\u002dbase-2);color:var(\u002d\u002dcontrast-3);display:flex;justify-content:center;border-radius:9999px;padding:10px 20px}.gb-tabs__menu-item-1559a4a1:is(.gb-block-is-current,.gb-block-is-current:hover,.gb-block-is-current:focus){background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-3)}.gb-tabs__menu-item-1559a4a1:is(:hover,:focus){background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-3)}@media (max-width:767px){.gb-tabs__menu-item-1559a4a1{flex-grow:1;flex-shrink:0}}","htmlAttributes":{"role":"tab","id":"gb-tab-menu-item-1559a4a1"},"tabItemOpen":true} -->
    <div class="gb-tabs__menu-item gb-tabs__menu-item-1559a4a1" role="tab" id="gb-tab-menu-item-1559a4a1"><!-- wp:generateblocks/text {"uniqueId":"2ca4eddf","tagName":"span","styles":{"fontWeight":"600"},"css":".gb-text-2ca4eddf{font-weight:600}"} -->
    <span class="gb-text gb-text-2ca4eddf">Course Info</span>
    <!-- /wp:generateblocks-pro/tab-menu-item -->
    <!-- wp:generateblocks-pro/tab-menu-item {"uniqueId":"b90bd565","tagName":"div","styles":{"color":"var(\u002d\u002dcontrast-3)","\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dbase-3)","backgroundColor":"var(\u002d\u002daccent)"},"\u0026:is(.gb-block-is-current, .gb-block-is-current:hover, .gb-block-is-current:focus)":{"backgroundColor":"var(\u002d\u002daccent)","color":"var(\u002d\u002dbase-3)"},"@media (max-width:767px)":{"flexGrow":"1","flexShrink":"0"},"borderTopLeftRadius":"9999px","borderTopRightRadius":"9999px","borderBottomLeftRadius":"9999px","borderBottomRightRadius":"9999px","display":"flex","alignItems":"center","justifyContent":"center","paddingTop":"10px","paddingBottom":"10px","paddingLeft":"20px","paddingRight":"20px","backgroundColor":"var(\u002d\u002dbase-2)"},"css":".gb-tabs__menu-item-b90bd565{align-items:center;background-color:var(\u002d\u002dbase-2);color:var(\u002d\u002dcontrast-3);display:flex;justify-content:center;border-radius:9999px;padding:10px 20px}.gb-tabs__menu-item-b90bd565:is(.gb-block-is-current,.gb-block-is-current:hover,.gb-block-is-current:focus){background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-3)}.gb-tabs__menu-item-b90bd565:is(:hover,:focus){color:var(\u002d\u002dbase-3);background-color:var(\u002d\u002daccent)}@media (max-width:767px){.gb-tabs__menu-item-b90bd565{flex-grow:1;flex-shrink:0}}","htmlAttributes":{"role":"tab","id":"gb-tab-menu-item-b90bd565"}} -->
    <div class="gb-tabs__menu-item gb-tabs__menu-item-b90bd565" role="tab" id="gb-tab-menu-item-b90bd565"><!-- wp:generateblocks/text {"uniqueId":"08656064","tagName":"span","styles":{"fontWeight":"600"},"css":".gb-text-08656064{font-weight:600}"} -->
    <span class="gb-text gb-text-08656064">Lessons</span>
    <!-- wp:generateblocks-pro/tab-menu-item {"uniqueId":"d3f5c2e1","tagName":"div","styles":{"color":"var(\u002d\u002dcontrast-3)","\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dbase-3)","backgroundColor":"var(\u002d\u002daccent)"},"\u0026:is(.gb-block-is-current, .gb-block-is-current:hover, .gb-block-is-current:focus)":{"backgroundColor":"var(\u002d\u002daccent)","color":"var(\u002d\u002dbase-3)"},"@media (max-width:767px)":{"flexGrow":"1","flexShrink":"0"},"borderTopLeftRadius":"9999px","borderTopRightRadius":"9999px","borderBottomLeftRadius":"9999px","borderBottomRightRadius":"9999px","display":"flex","alignItems":"center","justifyContent":"center","paddingTop":"10px","paddingBottom":"10px","paddingLeft":"20px","paddingRight":"20px","backgroundColor":"var(\u002d\u002dbase-2)"},"css":".gb-tabs__menu-item-d3f5c2e1{align-items:center;background-color:var(\u002d\u002dbase-2);color:var(\u002d\u002dcontrast-3);display:flex;justify-content:center;border-radius:9999px;padding:10px 20px}.gb-tabs__menu-item-d3f5c2e1:is(.gb-block-is-current,.gb-block-is-current:hover,.gb-block-is-current:focus){background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-3)}.gb-tabs__menu-item-d3f5c2e1:is(:hover,:focus){color:var(\u002d\u002dbase-3);background-color:var(\u002d\u002daccent)}@media (max-width:767px){.gb-tabs__menu-item-d3f5c2e1{flex-grow:1;flex-shrink:0}}","htmlAttributes":{"role":"tab","id":"gb-tab-menu-item-d3f5c2e1"}} -->
    <div class="gb-tabs__menu-item gb-tabs__menu-item-d3f5c2e1" role="tab" id="gb-tab-menu-item-d3f5c2e1"><!-- wp:generateblocks/text {"uniqueId":"710ac03d","tagName":"span","styles":{"fontWeight":"600"},"css":".gb-text-710ac03d{font-weight:600}"} -->
    <span class="gb-text gb-text-710ac03d">Instructor</span>
    <!-- /wp:generateblocks-pro/tab-menu-item --></div>
    <!-- /wp:generateblocks-pro/tabs-menu -->
    <!-- wp:generateblocks-pro/tab-items {"uniqueId":"44ceb7b0","tagName":"div","styles":[],"htmlAttributes":{"role":"tabpanel"}} -->
    <div class="gb-tabs__items" role="tabpanel"><!-- wp:generateblocks-pro/tab-item {"uniqueId":"019cb3b0","tagName":"div","styles":{"paddingTop":"2em","paddingLeft":"2em","paddingBottom":"2em","paddingRight":"2em","boxShadow":"0px 0px 14px 6px rgba(58, 58, 74, 0.1)"},"css":".gb-tabs__item-019cb3b0{box-shadow:0px 0px 14px 6px rgba(58,58,74,0.1);padding:2em}","htmlAttributes":{"id":"gb-tab-item-019cb3b0"},"tabItemOpen":true} -->
    <div class="gb-tabs__item gb-tabs__item-019cb3b0" id="gb-tab-item-019cb3b0"><!-- wp:generateblocks/text {"uniqueId":"9aff89ae","tagName":"h2","styles":{"fontSize":"2rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)","textAlign":"left","paddingBottom":"1rem"},"css":".gb-text-9aff89ae{font-size:2rem;padding-bottom:1rem;text-align:left;border-bottom:1px solid var(\u002d\u002dbase)}","globalClasses":["gbp-section__headline"]} -->
    <h2 class="gb-text gbp-section__headline gb-text-9aff89ae">About the course</h2>
    <!-- wp:paragraph {"align":"left"} -->
    <p class="has-text-align-left">Interdum et malesuada fames ac ante ipsum primis in faucibus. Donec eget tincidunt est. Nunc eget ante sed turpis egestas accumsan. Phasellus ac purus ac odio sagittis mattis ac quis dolor. Donec faucibus, turpis quis sollicitudin vehicula, nibh dui luctus libero, in vehicula dui justo ut neque. Aliquam imperdiet congue lacus, at dictum urna. Curabitur pharetra quis mi eget viverra. Donec vel mauris nibh. Integer magna risus, malesuada ut nunc non, viverra pharetra orci. Phasellus tristique commodo lorem vel euismod. Nunc at lectus ipsum. Morbi vitae hendrerit nunc, vitae rhoncus leo. Vivamus eget sodales ante. Cras quis odio diam. In quis justo eget odio maximus mattis ut ut nisi. Vivamus purus sapien, convallis ac mauris et, vehicula dictum nunc.</p>
    <!-- /wp:paragraph -->
    <p class="has-text-align-left">Duis ac rutrum mauris. Mauris et magna tellus. Mauris mollis et ante nec porta. Quisque volutpat, risus consectetur malesuada tristique, metus sem vehicula augue, ac fermentum orci ipsum in neque. Donec sollicitudin maximus consequat. Sed finibus quis metus in euismod. Sed tristique condimentum sem.</p>
    <!-- wp:generateblocks/text {"uniqueId":"ab544da9","tagName":"h3","styles":{"paddingBottom":"1rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)","textAlign":"left","paddingTop":"1em","fontSize":"1.4rem"},"css":".gb-text-ab544da9{font-size:1.4rem;padding-bottom:1rem;padding-top:1em;text-align:left;border-bottom:1px solid var(\u002d\u002dbase)}"} -->
    <h3 class="gb-text gb-text-ab544da9">Objectives</h3>
    <!-- wp:generateblocks/element {"uniqueId":"4c8b5973","tagName":"ul","styles":{"listStyleType":"decimal","display":"flex","flexDirection":"column","rowGap":"2rem","marginLeft":"1.5rem","paddingLeft":"0rem"},"css":".gb-element-4c8b5973{display:flex;flex-direction:column;list-style-type:decimal;margin-left:1.5rem;padding-left:0rem;row-gap:2rem}"} -->
    <ul class="gb-element-4c8b5973"><!-- wp:generateblocks/element {"uniqueId":"f6f01fac","tagName":"li"} -->
    <li><!-- wp:generateblocks/text {"uniqueId":"40df442f","tagName":"h4","styles":{"textAlign":"left","fontWeight":"700","marginBottom":"1rem"},"css":".gb-text-40df442f{font-weight:700;margin-bottom:1rem;text-align:left}"} -->
    <h4 class="gb-text gb-text-40df442f">Objective 1</h4>
    <!-- wp:generateblocks/element {"uniqueId":"2d8c6942","tagName":"ul"} -->
    <ul><!-- wp:generateblocks/text {"uniqueId":"4786cc95","tagName":"li","styles":{"textAlign":"left","marginBottom":"0.8rem","listStyleType":"disc"},"css":".gb-text-4786cc95{list-style-type:disc;margin-bottom:0.8rem;text-align:left}"} -->
    <li class="gb-text gb-text-4786cc95">Write something about objective 1</li>
    <!-- wp:generateblocks/text {"uniqueId":"45d7adbe","tagName":"li","styles":{"textAlign":"left","marginBottom":"0.8rem","listStyleType":"disc"},"css":".gb-text-45d7adbe{list-style-type:disc;margin-bottom:0.8rem;text-align:left}"} -->
    <li class="gb-text gb-text-45d7adbe">Write something about objective 1</li>
    <!-- wp:generateblocks/text {"uniqueId":"8cb520d1","tagName":"li","styles":{"textAlign":"left","listStyleType":"disc"},"css":".gb-text-8cb520d1{list-style-type:disc;text-align:left}"} -->
    <li class="gb-text gb-text-8cb520d1">Write something about objective 1</li>
    <!-- /wp:generateblocks/text --></ul>
    <!-- /wp:generateblocks/element --></li>
    <!-- wp:generateblocks/element {"uniqueId":"a06f2378","tagName":"li"} -->
    <li><!-- wp:generateblocks/text {"uniqueId":"2148ae53","tagName":"h4","styles":{"textAlign":"left","fontWeight":"700","marginBottom":"1rem"},"css":".gb-text-2148ae53{font-weight:700;margin-bottom:1rem;text-align:left}"} -->
    <h4 class="gb-text gb-text-2148ae53">Objective 2</h4>
    <!-- wp:generateblocks/element {"uniqueId":"a031c172","tagName":"ul"} -->
    <ul><!-- wp:generateblocks/text {"uniqueId":"ea47d927","tagName":"li","styles":{"textAlign":"left","marginBottom":"0.8rem","listStyleType":"disc"},"css":".gb-text-ea47d927{list-style-type:disc;margin-bottom:0.8rem;text-align:left}"} -->
    <li class="gb-text gb-text-ea47d927">Write something about objective 2</li>
    <!-- wp:generateblocks/text {"uniqueId":"dd78603c","tagName":"li","styles":{"textAlign":"left","marginBottom":"0.8rem","listStyleType":"disc"},"css":".gb-text-dd78603c{list-style-type:disc;margin-bottom:0.8rem;text-align:left}"} -->
    <li class="gb-text gb-text-dd78603c">Write something about objective 2</li>
    <!-- wp:generateblocks/text {"uniqueId":"482f3743","tagName":"li","styles":{"textAlign":"left","listStyleType":"disc"},"css":".gb-text-482f3743{list-style-type:disc;text-align:left}"} -->
    <li class="gb-text gb-text-482f3743">Write something about objective 2</li>
    <!-- wp:generateblocks/element {"uniqueId":"220c4e70","tagName":"li"} -->
    <li><!-- wp:generateblocks/text {"uniqueId":"f485ff5d","tagName":"h4","styles":{"textAlign":"left","fontWeight":"700","marginBottom":"1rem"},"css":".gb-text-f485ff5d{font-weight:700;margin-bottom:1rem;text-align:left}"} -->
    <h4 class="gb-text gb-text-f485ff5d">Objective 3</h4>
    <!-- wp:generateblocks/element {"uniqueId":"24dfda99","tagName":"ul"} -->
    <ul><!-- wp:generateblocks/text {"uniqueId":"f04ef4a3","tagName":"li","styles":{"textAlign":"left","marginBottom":"0.8rem","listStyleType":"disc"},"css":".gb-text-f04ef4a3{list-style-type:disc;margin-bottom:0.8rem;text-align:left}"} -->
    <li class="gb-text gb-text-f04ef4a3">Write something about objective 3</li>
    <!-- wp:generateblocks/text {"uniqueId":"bd2bb87d","tagName":"li","styles":{"textAlign":"left","marginBottom":"0.8rem","listStyleType":"disc"},"css":".gb-text-bd2bb87d{list-style-type:disc;margin-bottom:0.8rem;text-align:left}"} -->
    <li class="gb-text gb-text-bd2bb87d">Write something about objective 3</li>
    <!-- wp:generateblocks/text {"uniqueId":"b58cb63c","tagName":"li","styles":{"textAlign":"left","listStyleType":"disc"},"css":".gb-text-b58cb63c{list-style-type:disc;text-align:left}"} -->
    <li class="gb-text gb-text-b58cb63c">Write something about objective 3</li>
    <!-- wp:generateblocks/element {"uniqueId":"9bd44d72","tagName":"li"} -->
    <li><!-- wp:generateblocks/text {"uniqueId":"94f7f70d","tagName":"h4","styles":{"textAlign":"left","fontWeight":"700","marginBottom":"1rem"},"css":".gb-text-94f7f70d{font-weight:700;margin-bottom:1rem;text-align:left}"} -->
    <h4 class="gb-text gb-text-94f7f70d">Objective 4</h4>
    <!-- wp:generateblocks/element {"uniqueId":"dc2e19d5","tagName":"ul"} -->
    <ul><!-- wp:generateblocks/text {"uniqueId":"291e91e0","tagName":"li","styles":{"textAlign":"left","marginBottom":"0.8rem","listStyleType":"disc"},"css":".gb-text-291e91e0{list-style-type:disc;margin-bottom:0.8rem;text-align:left}"} -->
    <li class="gb-text gb-text-291e91e0">Write something about objective 4</li>
    <!-- wp:generateblocks/text {"uniqueId":"df7a9122","tagName":"li","styles":{"textAlign":"left","marginBottom":"0.8rem","listStyleType":"disc"},"css":".gb-text-df7a9122{list-style-type:disc;margin-bottom:0.8rem;text-align:left}"} -->
    <li class="gb-text gb-text-df7a9122">Write something about objective 4</li>
    <!-- wp:generateblocks/text {"uniqueId":"66328d35","tagName":"li","styles":{"textAlign":"left","listStyleType":"disc"},"css":".gb-text-66328d35{list-style-type:disc;text-align:left}"} -->
    <li class="gb-text gb-text-66328d35">Write something about objective 4</li>
    <!-- /wp:generateblocks/element --></ul>
    <!-- /wp:generateblocks-pro/tab-item -->
    <!-- wp:generateblocks-pro/tab-item {"uniqueId":"30eeb627","tagName":"div","styles":{"boxShadow":"0px 0px 14px 6px rgba(58, 58, 74, 0.1)","paddingTop":"2em","paddingLeft":"2em","paddingBottom":"2em","paddingRight":"2em"},"css":".gb-tabs__item-30eeb627{box-shadow:0px 0px 14px 6px rgba(58,58,74,0.1);padding:2em}","htmlAttributes":{"id":"gb-tab-item-30eeb627"}} -->
    <div class="gb-tabs__item gb-tabs__item-30eeb627" id="gb-tab-item-30eeb627"><!-- wp:generateblocks/text {"uniqueId":"8cdadedb","tagName":"h2","styles":{"fontSize":"2rem","paddingBottom":"1rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)","textAlign":"left"},"css":".gb-text-8cdadedb{font-size:2rem;padding-bottom:1rem;text-align:left;border-bottom:1px solid var(\u002d\u002dbase)}"} -->
    <h2 class="gb-text gb-text-8cdadedb">Course content</h2>
    <!-- wp:generateblocks-pro/accordion {"uniqueId":"aff85ad2","tagName":"div","htmlAttributes":{"data-accordion-multiple-open":true,"data-transition":"slide"}} -->
    <div class="gb-accordion" data-accordion-multiple-open="true" data-transition="slide"><!-- wp:generateblocks-pro/accordion-item {"uniqueId":"ff0b63df","tagName":"div","styles":{"paddingTop":"1em","paddingRight":"1em","paddingBottom":"1em","paddingLeft":"1em","marginBottom":"0.4rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)"},"css":".gb-accordion__item-ff0b63df{margin-bottom:0.4rem;border-bottom:1px solid var(\u002d\u002dbase);padding:1em}"} -->
    <div class="gb-accordion__item gb-accordion__item-ff0b63df"><!-- wp:generateblocks-pro/accordion-toggle {"uniqueId":"82df9701","tagName":"div","styles":{"display":"flex","justifyContent":"space-between","color":"#000000","textAlign":"left","columnGap":"1em","\u0026:is(:hover, :focus)":{"color":"currentColor"},"\u0026:is(.gb-block-is-current, .gb-block-is-current:hover, .gb-block-is-current:focus)":{"fontWeight":"600"},"alignItems":"center"},"css":".gb-accordion__toggle-82df9701{align-items:center;color:#000000;column-gap:1em;display:flex;justify-content:space-between;text-align:left}.gb-accordion__toggle-82df9701:is(.gb-block-is-current,.gb-block-is-current:hover,.gb-block-is-current:focus){font-weight:600}.gb-accordion__toggle-82df9701:is(:hover,:focus){color:currentColor}","htmlAttributes":{"id":"gb-accordion-toggle-82df9701"}} -->
    <div class="gb-accordion__toggle gb-accordion__toggle-82df9701" id="gb-accordion-toggle-82df9701"><!-- wp:generateblocks/text {"uniqueId":"8317a652","tagName":"h3","styles":{"fontSize":"1.4rem","marginBottom":"0.4rem"},"css":".gb-text-8317a652{font-size:1.4rem;margin-bottom:0.4rem}"} -->
    <h3 class="gb-text gb-text-8317a652">Module 1</h3>
    <!-- wp:generateblocks-pro/accordion-toggle-icon {"uniqueId":"0d7277c7","tagName":"span","styles":{"svg":{"width":"1em","height":"1em"}},"css":".gb-accordion__toggle-icon-0d7277c7 svg{width:1em;height:1em}"} -->
    <span class="gb-accordion__toggle-icon gb-accordion__toggle-icon-0d7277c7"><span class="gb-accordion__toggle-icon-open"><svg aria-hidden="true" viewBox="0 0 256 256"><rect width="256" height="256" fill="none"></rect><line x1="40" y1="128" x2="216" y2="128" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line><line x1="128" y1="40" x2="128" y2="216" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line></svg></span><span class="gb-accordion__toggle-icon-close"><svg aria-hidden="true" viewBox="0 0 256 256"><rect width="256" height="256" fill="none"></rect><line x1="40" y1="128" x2="216" y2="128" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line></svg></span></span>
    <!-- /wp:generateblocks-pro/accordion-toggle-icon --></div>
    <!-- /wp:generateblocks-pro/accordion-toggle -->
    <!-- wp:generateblocks-pro/accordion-content {"uniqueId":"4e13335f","tagName":"div","htmlAttributes":{"id":"gb-accordion-content-4e13335f"}} -->
    <div class="gb-accordion__content" id="gb-accordion-content-4e13335f"><!-- wp:generateblocks/element {"uniqueId":"54fe67f7","tagName":"div","styles":{"marginTop":"1em","textAlign":"left"},"css":".gb-element-54fe67f7{margin-top:1em;text-align:left}"} -->
    <div class="gb-element-54fe67f7"><!-- wp:generateblocks/element {"uniqueId":"9d2e2f9e","tagName":"div","styles":{"display":"flex","flexDirection":"column","rowGap":"0.8rem"},"css":".gb-element-9d2e2f9e{display:flex;flex-direction:column;row-gap:0.8rem}"} -->
    <div class="gb-element-9d2e2f9e"><!-- wp:generateblocks/element {"uniqueId":"baefca69","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-baefca69{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-baefca69"><!-- wp:generateblocks/text {"uniqueId":"aa4a4418","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-aa4a4418{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-aa4a4418 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-aa4a4418"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 1</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"d7c741a9","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-d7c741a9{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-d7c741a9 .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-d7c741a9"><span class="gb-text">12:34</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"3845e866","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-3845e866{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-3845e866"><!-- wp:generateblocks/text {"uniqueId":"4f47ffed","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-4f47ffed{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-4f47ffed .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-4f47ffed"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 2</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"9919250d","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-9919250d{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-9919250d .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-9919250d"><span class="gb-text">06:52</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"4f46e58e","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-4f46e58e{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-4f46e58e"><!-- wp:generateblocks/text {"uniqueId":"b07f83d6","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-b07f83d6{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-b07f83d6 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-b07f83d6"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 3</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"228be38f","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-228be38f{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-228be38f .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-228be38f"><span class="gb-text">11:14</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"405ce4b0","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-405ce4b0{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-405ce4b0"><!-- wp:generateblocks/text {"uniqueId":"8aff5e96","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-8aff5e96{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-8aff5e96 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-8aff5e96"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 4</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"c1820933","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-c1820933{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-c1820933 .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-c1820933"><span class="gb-text">08:36</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- /wp:generateblocks-pro/accordion-content --></div>
    <!-- /wp:generateblocks-pro/accordion-item -->
    <!-- wp:generateblocks-pro/accordion-item {"uniqueId":"2394c340","tagName":"div","styles":{"paddingTop":"1em","paddingRight":"1em","paddingBottom":"1em","paddingLeft":"1em","marginBottom":"0.4rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)"},"css":".gb-accordion__item-2394c340{margin-bottom:0.4rem;border-bottom:1px solid var(\u002d\u002dbase);padding:1em}"} -->
    <div class="gb-accordion__item gb-accordion__item-2394c340"><!-- wp:generateblocks-pro/accordion-toggle {"uniqueId":"57496e21","tagName":"div","styles":{"display":"flex","justifyContent":"space-between","color":"#000000","textAlign":"left","columnGap":"1em","\u0026:is(:hover, :focus)":{"color":"currentColor"},"\u0026:is(.gb-block-is-current, .gb-block-is-current:hover, .gb-block-is-current:focus)":{"fontWeight":"600"},"alignItems":"center"},"css":".gb-accordion__toggle-57496e21{align-items:center;color:#000000;column-gap:1em;display:flex;justify-content:space-between;text-align:left}.gb-accordion__toggle-57496e21:is(.gb-block-is-current,.gb-block-is-current:hover,.gb-block-is-current:focus){font-weight:600}.gb-accordion__toggle-57496e21:is(:hover,:focus){color:currentColor}","htmlAttributes":{"id":"gb-accordion-toggle-57496e21"}} -->
    <div class="gb-accordion__toggle gb-accordion__toggle-57496e21" id="gb-accordion-toggle-57496e21"><!-- wp:generateblocks/text {"uniqueId":"1a3c2d75","tagName":"h3","styles":{"fontSize":"1.4rem","marginBottom":"0.4rem"},"css":".gb-text-1a3c2d75{font-size:1.4rem;margin-bottom:0.4rem}"} -->
    <h3 class="gb-text gb-text-1a3c2d75">Module 2</h3>
    <!-- wp:generateblocks-pro/accordion-toggle-icon {"uniqueId":"49d947f3","tagName":"span","styles":{"svg":{"width":"1em","height":"1em"}},"css":".gb-accordion__toggle-icon-49d947f3 svg{width:1em;height:1em}"} -->
    <span class="gb-accordion__toggle-icon gb-accordion__toggle-icon-49d947f3"><span class="gb-accordion__toggle-icon-open"><svg aria-hidden="true" viewBox="0 0 256 256"><rect width="256" height="256" fill="none"></rect><line x1="40" y1="128" x2="216" y2="128" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line><line x1="128" y1="40" x2="128" y2="216" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line></svg></span><span class="gb-accordion__toggle-icon-close"><svg aria-hidden="true" viewBox="0 0 256 256"><rect width="256" height="256" fill="none"></rect><line x1="40" y1="128" x2="216" y2="128" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line></svg></span></span>
    <!-- wp:generateblocks-pro/accordion-content {"uniqueId":"0f66e918","tagName":"div","htmlAttributes":{"id":"gb-accordion-content-0f66e918"}} -->
    <div class="gb-accordion__content" id="gb-accordion-content-0f66e918"><!-- wp:generateblocks/element {"uniqueId":"cc6904d5","tagName":"div","styles":{"marginTop":"1em","textAlign":"left"},"css":".gb-element-cc6904d5{margin-top:1em;text-align:left}"} -->
    <div class="gb-element-cc6904d5"><!-- wp:generateblocks/element {"uniqueId":"4ef53a55","tagName":"div","styles":{"marginTop":"1em","textAlign":"left"},"css":".gb-element-4ef53a55{margin-top:1em;text-align:left}"} -->
    <div class="gb-element-4ef53a55"><!-- wp:generateblocks/element {"uniqueId":"d0b22719","tagName":"div","styles":{"display":"flex","flexDirection":"column","rowGap":"0.8rem"},"css":".gb-element-d0b22719{display:flex;flex-direction:column;row-gap:0.8rem}"} -->
    <div class="gb-element-d0b22719"><!-- wp:generateblocks/element {"uniqueId":"b88df90e","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-b88df90e{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-b88df90e"><!-- wp:generateblocks/text {"uniqueId":"e11987ab","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-e11987ab{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-e11987ab .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-e11987ab"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 1</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"148f12b1","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-148f12b1{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-148f12b1 .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-148f12b1"><span class="gb-text">14:58</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"6ee4c66c","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-6ee4c66c{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-6ee4c66c"><!-- wp:generateblocks/text {"uniqueId":"7c2362d8","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-7c2362d8{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-7c2362d8 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-7c2362d8"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 2</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"22735606","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-22735606{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-22735606 .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-22735606"><span class="gb-text">23:45</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"7320563f","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-7320563f{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-7320563f"><!-- wp:generateblocks/text {"uniqueId":"cfe29063","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-cfe29063{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-cfe29063 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-cfe29063"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 3</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"dd46fd68","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-dd46fd68{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-dd46fd68 .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-dd46fd68"><span class="gb-text">04:16</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"527ff89a","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-527ff89a{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-527ff89a"><!-- wp:generateblocks/text {"uniqueId":"847b7156","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-847b7156{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-847b7156 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-847b7156"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 4</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"a1d0ddb1","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-a1d0ddb1{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-a1d0ddb1 .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-a1d0ddb1"><span class="gb-text">13:39</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks-pro/accordion-item {"uniqueId":"e5c156ed","tagName":"div","styles":{"paddingTop":"1em","paddingRight":"1em","paddingBottom":"1em","paddingLeft":"1em","marginBottom":"0.4rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)"},"css":".gb-accordion__item-e5c156ed{margin-bottom:0.4rem;border-bottom:1px solid var(\u002d\u002dbase);padding:1em}"} -->
    <div class="gb-accordion__item gb-accordion__item-e5c156ed"><!-- wp:generateblocks-pro/accordion-toggle {"uniqueId":"bfdbf300","tagName":"div","styles":{"display":"flex","justifyContent":"space-between","color":"#000000","textAlign":"left","columnGap":"1em","\u0026:is(:hover, :focus)":{"color":"currentColor"},"\u0026:is(.gb-block-is-current, .gb-block-is-current:hover, .gb-block-is-current:focus)":{"fontWeight":"600"},"alignItems":"center"},"css":".gb-accordion__toggle-bfdbf300{align-items:center;color:#000000;column-gap:1em;display:flex;justify-content:space-between;text-align:left}.gb-accordion__toggle-bfdbf300:is(.gb-block-is-current,.gb-block-is-current:hover,.gb-block-is-current:focus){font-weight:600}.gb-accordion__toggle-bfdbf300:is(:hover,:focus){color:currentColor}","htmlAttributes":{"id":"gb-accordion-toggle-bfdbf300"}} -->
    <div class="gb-accordion__toggle gb-accordion__toggle-bfdbf300" id="gb-accordion-toggle-bfdbf300"><!-- wp:generateblocks/text {"uniqueId":"1c10ce2f","tagName":"h3","styles":{"fontSize":"1.4rem","marginBottom":"0.4rem"},"css":".gb-text-1c10ce2f{font-size:1.4rem;margin-bottom:0.4rem}"} -->
    <h3 class="gb-text gb-text-1c10ce2f">Module 3</h3>
    <!-- wp:generateblocks-pro/accordion-toggle-icon {"uniqueId":"6683b390","tagName":"span","styles":{"svg":{"width":"1em","height":"1em"}},"css":".gb-accordion__toggle-icon-6683b390 svg{width:1em;height:1em}"} -->
    <span class="gb-accordion__toggle-icon gb-accordion__toggle-icon-6683b390"><span class="gb-accordion__toggle-icon-open"><svg aria-hidden="true" viewBox="0 0 256 256"><rect width="256" height="256" fill="none"></rect><line x1="40" y1="128" x2="216" y2="128" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line><line x1="128" y1="40" x2="128" y2="216" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line></svg></span><span class="gb-accordion__toggle-icon-close"><svg aria-hidden="true" viewBox="0 0 256 256"><rect width="256" height="256" fill="none"></rect><line x1="40" y1="128" x2="216" y2="128" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line></svg></span></span>
    <!-- wp:generateblocks-pro/accordion-content {"uniqueId":"93d7edd7","tagName":"div","htmlAttributes":{"id":"gb-accordion-content-93d7edd7"}} -->
    <div class="gb-accordion__content" id="gb-accordion-content-93d7edd7"><!-- wp:generateblocks/element {"uniqueId":"09a32135","tagName":"div","styles":{"marginTop":"1em","textAlign":"left"},"css":".gb-element-09a32135{margin-top:1em;text-align:left}"} -->
    <div class="gb-element-09a32135"><!-- wp:generateblocks/element {"uniqueId":"7e07f788","tagName":"div","styles":{"display":"flex","flexDirection":"column","rowGap":"0.8rem"},"css":".gb-element-7e07f788{display:flex;flex-direction:column;row-gap:0.8rem}"} -->
    <div class="gb-element-7e07f788"><!-- wp:generateblocks/element {"uniqueId":"27092601","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-27092601{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-27092601"><!-- wp:generateblocks/text {"uniqueId":"7952ac4c","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-7952ac4c{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-7952ac4c .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-7952ac4c"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 1</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"8a9e0cca","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-8a9e0cca{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-8a9e0cca .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-8a9e0cca"><span class="gb-text">15:38</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"317886ff","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-317886ff{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-317886ff"><!-- wp:generateblocks/text {"uniqueId":"b64a7097","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-b64a7097{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-b64a7097 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-b64a7097"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 2</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"a5c5d6fe","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-a5c5d6fe{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-a5c5d6fe .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-a5c5d6fe"><span class="gb-text">15:34</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"a311e72d","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-a311e72d{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-a311e72d"><!-- wp:generateblocks/text {"uniqueId":"c1f266f8","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-c1f266f8{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-c1f266f8 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-c1f266f8"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 3</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"3d26e2f0","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-3d26e2f0{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-3d26e2f0 .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-3d26e2f0"><span class="gb-text">10:56</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"17263ea8","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-17263ea8{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-17263ea8"><!-- wp:generateblocks/text {"uniqueId":"50d0f91d","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-50d0f91d{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-50d0f91d .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-50d0f91d"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 4</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"9f676d7e","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-9f676d7e{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-9f676d7e .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-9f676d7e"><span class="gb-text">05:32</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- /wp:generateblocks/text --></div>
    <!-- wp:generateblocks-pro/accordion-item {"uniqueId":"36c75bc2","tagName":"div","styles":{"paddingTop":"1em","paddingRight":"1em","paddingBottom":"1em","paddingLeft":"1em","marginBottom":"0.4rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)"},"css":".gb-accordion__item-36c75bc2{margin-bottom:0.4rem;border-bottom:1px solid var(\u002d\u002dbase);padding:1em}"} -->
    <div class="gb-accordion__item gb-accordion__item-36c75bc2"><!-- wp:generateblocks-pro/accordion-toggle {"uniqueId":"5d8d183c","tagName":"div","styles":{"display":"flex","justifyContent":"space-between","color":"#000000","textAlign":"left","columnGap":"1em","\u0026:is(:hover, :focus)":{"color":"currentColor"},"\u0026:is(.gb-block-is-current, .gb-block-is-current:hover, .gb-block-is-current:focus)":{"fontWeight":"600"},"alignItems":"center"},"css":".gb-accordion__toggle-5d8d183c{align-items:center;color:#000000;column-gap:1em;display:flex;justify-content:space-between;text-align:left}.gb-accordion__toggle-5d8d183c:is(.gb-block-is-current,.gb-block-is-current:hover,.gb-block-is-current:focus){font-weight:600}.gb-accordion__toggle-5d8d183c:is(:hover,:focus){color:currentColor}","htmlAttributes":{"id":"gb-accordion-toggle-5d8d183c"}} -->
    <div class="gb-accordion__toggle gb-accordion__toggle-5d8d183c" id="gb-accordion-toggle-5d8d183c"><!-- wp:generateblocks/text {"uniqueId":"8c6f4a2f","tagName":"h3","styles":{"fontSize":"1.4rem","marginBottom":"0.4rem"},"css":".gb-text-8c6f4a2f{font-size:1.4rem;margin-bottom:0.4rem}"} -->
    <h3 class="gb-text gb-text-8c6f4a2f">Module 4</h3>
    <!-- wp:generateblocks-pro/accordion-toggle-icon {"uniqueId":"b54b35d8","tagName":"span","styles":{"svg":{"width":"1em","height":"1em"}},"css":".gb-accordion__toggle-icon-b54b35d8 svg{width:1em;height:1em}"} -->
    <span class="gb-accordion__toggle-icon gb-accordion__toggle-icon-b54b35d8"><span class="gb-accordion__toggle-icon-open"><svg aria-hidden="true" viewBox="0 0 256 256"><rect width="256" height="256" fill="none"></rect><line x1="40" y1="128" x2="216" y2="128" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line><line x1="128" y1="40" x2="128" y2="216" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line></svg></span><span class="gb-accordion__toggle-icon-close"><svg aria-hidden="true" viewBox="0 0 256 256"><rect width="256" height="256" fill="none"></rect><line x1="40" y1="128" x2="216" y2="128" fill="none" stroke="currentColor" stroke-linecap="round" stroke-linejoin="round" stroke-width="16"></line></svg></span></span>
    <!-- wp:generateblocks-pro/accordion-content {"uniqueId":"ab30b90f","tagName":"div","htmlAttributes":{"id":"gb-accordion-content-ab30b90f"}} -->
    <div class="gb-accordion__content" id="gb-accordion-content-ab30b90f"><!-- wp:generateblocks/element {"uniqueId":"4081b17e","tagName":"div","styles":{"marginTop":"1em","textAlign":"left"},"css":".gb-element-4081b17e{margin-top:1em;text-align:left}"} -->
    <div class="gb-element-4081b17e"><!-- wp:generateblocks/element {"uniqueId":"1a10c63a","tagName":"div","styles":{"marginTop":"1em","textAlign":"left"},"css":".gb-element-1a10c63a{margin-top:1em;text-align:left}"} -->
    <div class="gb-element-1a10c63a"><!-- wp:generateblocks/element {"uniqueId":"38afe501","tagName":"div","styles":{"display":"flex","flexDirection":"column","rowGap":"0.8rem"},"css":".gb-element-38afe501{display:flex;flex-direction:column;row-gap:0.8rem}"} -->
    <div class="gb-element-38afe501"><!-- wp:generateblocks/element {"uniqueId":"0186b5bd","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-0186b5bd{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-0186b5bd"><!-- wp:generateblocks/text {"uniqueId":"48ab69bd","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-48ab69bd{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-48ab69bd .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-48ab69bd"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 1</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"352adce8","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-352adce8{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-352adce8 .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-352adce8"><span class="gb-text">02:22</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"fed7bef0","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-fed7bef0{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-fed7bef0"><!-- wp:generateblocks/text {"uniqueId":"8402cf19","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-8402cf19{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-8402cf19 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-8402cf19"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 2</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"a36d475c","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-a36d475c{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-a36d475c .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-a36d475c"><span class="gb-text">21:12</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"cdeda016","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-cdeda016{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-cdeda016"><!-- wp:generateblocks/text {"uniqueId":"21231a3e","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-21231a3e{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-21231a3e .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-21231a3e"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 3</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"c9ff11fd","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-c9ff11fd{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-c9ff11fd .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-c9ff11fd"><span class="gb-text">26:55</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"a229dbd7","tagName":"div","styles":{"display":"flex","alignItems":"center","justifyContent":"space-between"},"css":".gb-element-a229dbd7{align-items:center;display:flex;justify-content:space-between}"} -->
    <div class="gb-element-a229dbd7"><!-- wp:generateblocks/text {"uniqueId":"b1f4d7e3","tagName":"p","styles":{"marginBottom":"0.6rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-b1f4d7e3{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0.6rem}.gb-text-b1f4d7e3 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-b1f4d7e3"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" viewBox="0 0 64 64"><g fill="none" stroke="currentColor" stroke-miterlimit="10" stroke-width="2"><path stroke-linejoin="bevel" d="m27 21 14 11-14 11z"></path><path d="M53.92 10.081c12.107 12.105 12.107 31.732 0 43.838-12.106 12.108-31.734 12.108-43.839 0-12.107-12.105-12.107-31.732 0-43.838 12.105-12.108 31.732-12.108 43.839 0z"></path></g></svg></span><span class="gb-text">Title 4</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"4c4efc21","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-4c4efc21{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-4c4efc21 .gb-shape svg{width:1em;height:1em;fill:currentColor}","iconLocation":"after"} -->
    <p class="gb-text-4c4efc21"><span class="gb-text">12:53</span><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M256 8C119 8 8 119 8 256s111 248 248 248 248-111 248-248S393 8 256 8zm0 448c-110.5 0-200-89.5-200-200S145.5 56 256 56s200 89.5 200 200-89.5 200-200 200zm61.8-104.4l-84.9-61.7c-3.1-2.3-4.9-5.9-4.9-9.7V116c0-6.6 5.4-12 12-12h32c6.6 0 12 5.4 12 12v141.7l66.8 48.6c5.4 3.9 6.5 11.4 2.6 16.8L334.6 349c-3.9 5.3-11.4 6.5-16.8 2.6z"></path></svg></span></p>
    <!-- /wp:generateblocks/element --></div>
    <!-- /wp:generateblocks-pro/accordion-item --></div>
    <!-- /wp:generateblocks-pro/accordion --></div>
    <!-- wp:generateblocks-pro/tab-item {"uniqueId":"cd5b789e","tagName":"div","styles":{"paddingTop":"2em","paddingLeft":"2em","paddingBottom":"2em","paddingRight":"2em","boxShadow":"0px 0px 14px 6px rgba(58, 58, 74, 0.1)"},"css":".gb-tabs__item-cd5b789e{box-shadow:0px 0px 14px 6px rgba(58,58,74,0.1);padding:2em}","htmlAttributes":{"id":"gb-tab-item-cd5b789e"}} -->
    <div class="gb-tabs__item gb-tabs__item-cd5b789e" id="gb-tab-item-cd5b789e"><!-- wp:generateblocks/text {"uniqueId":"df6263c3","tagName":"h2","styles":{"fontSize":"2rem","paddingBottom":"1rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)","textAlign":"left"},"css":".gb-text-df6263c3{font-size:2rem;padding-bottom:1rem;text-align:left;border-bottom:1px solid var(\u002d\u002dbase)}"} -->
    <h2 class="gb-text gb-text-df6263c3">Instructor</h2>
    <!-- wp:generateblocks/element {"uniqueId":"c93a3c3c","tagName":"div","styles":{"paddingTop":"0px","paddingRight":"0px","paddingBottom":"0px","paddingLeft":"0px"},"css":".gb-element-c93a3c3c{padding:0px}","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <div class="gbp-section gb-element-c93a3c3c"><!-- wp:generateblocks/element {"uniqueId":"b639a425","tagName":"div","styles":{"marginLeft":"auto","marginRight":"auto","display":"grid","gridTemplateColumns":"auto 1fr","columnGap":"2rem","@media (max-width:1024px)":{"gridTemplateColumns":"repeat(2, minmax(0, 1fr))","marginLeft":"auto","marginRight":"auto"},"alignItems":"center","rowGap":"2rem","@media (max-width:767px)":{"gridTemplateColumns":"1fr"}},"css":".gb-element-b639a425{align-items:center;column-gap:2rem;display:grid;grid-template-columns:auto 1fr;margin-left:auto;margin-right:auto;row-gap:2rem}@media (max-width:1024px){.gb-element-b639a425{grid-template-columns:repeat(2,minmax(0,1fr));margin-left:auto;margin-right:auto}}@media (max-width:767px){.gb-element-b639a425{grid-template-columns:1fr}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container max-width"}} -->
    <div class="gbp-section__inner gb-element-b639a425"><!-- wp:generateblocks/element {"uniqueId":"71420b45","tagName":"div","styles":{"textAlign":"left","@media (max-width:767px)":{"order":"1"}},"css":".gb-element-71420b45{text-align:left}@media (max-width:767px){.gb-element-71420b45{order:1}}","metadata":{"name":"Content container"}} -->
    <div class="gb-element-71420b45"><!-- wp:generateblocks/media {"uniqueId":"ec7f7f27","tagName":"img","styles":{"height":"auto","objectFit":"cover","display":"block","@media (max-width:767px)":{"width":"100%","maxWidth":"100%"},"width":"auto","maxWidth":"300px","borderTopLeftRadius":"100%","borderTopRightRadius":"100%","borderBottomLeftRadius":"100%","borderBottomRightRadius":"100%"},"css":".gb-media-ec7f7f27{display:block;height:auto;max-width:300px;object-fit:cover;width:auto;border-radius:100%}@media (max-width:767px){.gb-media-ec7f7f27{max-width:100%;width:100%}}","htmlAttributes":{"src":"https://patterns.generatepress.com/wp-content/uploads/2024/10/placeholder800x-768x768.png","title":"placeholder800x","alt":"User avatar placeholder"},"mediaId":4934} -->
    <img class="gb-media-ec7f7f27" src="https://patterns.generatepress.com/wp-content/uploads/2024/10/placeholder800x-768x768.png" title="placeholder800x" alt="User avatar placeholder"/>
    <!-- /wp:generateblocks/media --></div>
    <!-- wp:generateblocks/element {"uniqueId":"d73ca65d","tagName":"div","styles":{"@media (max-width:767px)":{"order":"2"},"textAlign":"left"},"css":".gb-element-d73ca65d{text-align:left}@media (max-width:767px){.gb-element-d73ca65d{order:2}}","metadata":{"name":"Content container"}} -->
    <div class="gb-element-d73ca65d"><!-- wp:generateblocks/text {"uniqueId":"c9e1e083","tagName":"h3","styles":{"fontWeight":"600","marginBottom":"0.5rem"},"css":".gb-text-c9e1e083{font-weight:600;margin-bottom:0.5rem}"} -->
    <h3 class="gb-text gb-text-c9e1e083">Name</h3>
    <!-- wp:generateblocks/text {"uniqueId":"db3c0c2e","tagName":"div","styles":{"marginBottom":"0.5rem","color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-db3c0c2e{color:var(\u002d\u002dcontrast-3);margin-bottom:0.5rem}"} -->
    <div class="gb-text gb-text-db3c0c2e">Job Title</div>
    <!-- wp:generateblocks/text {"uniqueId":"839a357f","tagName":"p","styles":{"marginBottom":"0px"},"css":".gb-text-839a357f{margin-bottom:0px}","globalClasses":["gbp-section__text"]} -->
    <p class="gb-text gbp-section__text gb-text-839a357f">Lorem ipsum dolor sit amet, consectetur adipiscing elit. Suspendisse varius enim in eros elementum tristique. Duis cursus, mi quis viverra ornare, eros dolor interdum nulla, ut commodo diam libero vitae erat.</p>
    <!-- wp:generateblocks/element {"uniqueId":"3a0ff211","tagName":"div","styles":{"display":"flex","columnGap":"1.2rem","@media (max-width:1024px)":{"justifyContent":"flex-start"},"marginTop":"2rem","rowGap":"1rem"},"css":".gb-element-3a0ff211{column-gap:1.2rem;display:flex;margin-top:2rem;row-gap:1rem}@media (max-width:1024px){.gb-element-3a0ff211{justify-content:flex-start}}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-3a0ff211"><!-- wp:generateblocks/text {"uniqueId":"67445367","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"fill":"currentColor","width":"1.2rem","height":"1.2rem","color":"var(\u002d\u002daccent)"},"color":"#000","\u0026:is(:hover, :focus) .gb-shape svg":{"color":"var(\u002d\u002daccent-2)"}},"css":".gb-text-67445367{align-items:center;color:#000;column-gap:0.5em;display:inline-flex}.gb-text-67445367:is(:hover,:focus) .gb-shape svg{color:var(\u002d\u002daccent-2)}.gb-text-67445367 .gb-shape svg{fill:currentColor;width:1.2rem;height:1.2rem;color:var(\u002d\u002daccent)}","htmlAttributes":{"href":"#","aria-label":"Follow instructor on Facebook"},"iconOnly":true} -->
    <a class="gb-text-67445367" href="#" aria-label="Follow instructor on Facebook"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 320 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M279.14 288l14.22-92.66h-88.91v-60.13c0-25.35 12.42-50.06 52.24-50.06h40.42V6.26S260.43 0 225.36 0c-73.22 0-121.08 44.38-121.08 124.72v70.62H22.89V288h81.39v224h100.17V288z"></path></svg></span></a>
    <!-- wp:generateblocks/text {"uniqueId":"754ded35","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"fill":"currentColor","width":"1.2rem","height":"1.2rem","color":"var(\u002d\u002daccent)"},"color":"#000","\u0026:is(:hover, :focus) .gb-shape svg":{"color":"var(\u002d\u002daccent-2)"}},"css":".gb-text-754ded35{align-items:center;color:#000;column-gap:0.5em;display:inline-flex}.gb-text-754ded35:is(:hover,:focus) .gb-shape svg{color:var(\u002d\u002daccent-2)}.gb-text-754ded35 .gb-shape svg{fill:currentColor;width:1.2rem;height:1.2rem;color:var(\u002d\u002daccent)}","htmlAttributes":{"href":"#","aria-label":"Follow instructor on Instagram"},"iconOnly":true} -->
    <a class="gb-text-754ded35" href="#" aria-label="Follow instructor on Instagram"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 448 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M224.1 141c-63.6 0-114.9 51.3-114.9 114.9s51.3 114.9 114.9 114.9S339 319.5 339 255.9 287.7 141 224.1 141zm0 189.6c-41.1 0-74.7-33.5-74.7-74.7s33.5-74.7 74.7-74.7 74.7 33.5 74.7 74.7-33.6 74.7-74.7 74.7zm146.4-194.3c0 14.9-12 26.8-26.8 26.8-14.9 0-26.8-12-26.8-26.8s12-26.8 26.8-26.8 26.8 12 26.8 26.8zm76.1 27.2c-1.7-35.9-9.9-67.7-36.2-93.9-26.2-26.2-58-34.4-93.9-36.2-37-2.1-147.9-2.1-184.9 0-35.8 1.7-67.6 9.9-93.9 36.1s-34.4 58-36.2 93.9c-2.1 37-2.1 147.9 0 184.9 1.7 35.9 9.9 67.7 36.2 93.9s58 34.4 93.9 36.2c37 2.1 147.9 2.1 184.9 0 35.9-1.7 67.7-9.9 93.9-36.2 26.2-26.2 34.4-58 36.2-93.9 2.1-37 2.1-147.8 0-184.8zM398.8 388c-7.8 19.6-22.9 34.7-42.6 42.6-29.5 11.7-99.5 9-132.1 9s-102.7 2.6-132.1-9c-19.6-7.8-34.7-22.9-42.6-42.6-11.7-29.5-9-99.5-9-132.1s-2.6-102.7 9-132.1c7.8-19.6 22.9-34.7 42.6-42.6 29.5-11.7 99.5-9 132.1-9s102.7-2.6 132.1 9c19.6 7.8 34.7 22.9 42.6 42.6 11.7 29.5 9 99.5 9 132.1s2.7 102.7-9 132.1z"></path></svg></span></a>
    <!-- wp:generateblocks/text {"uniqueId":"81383c73","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"fill":"currentColor","width":"1.2rem","height":"1.2rem","color":"var(\u002d\u002daccent)"},"color":"#000","\u0026:is(:hover, :focus) .gb-shape svg":{"color":"var(\u002d\u002daccent-2)"}},"css":".gb-text-81383c73{align-items:center;color:#000;column-gap:0.5em;display:inline-flex}.gb-text-81383c73:is(:hover,:focus) .gb-shape svg{color:var(\u002d\u002daccent-2)}.gb-text-81383c73 .gb-shape svg{fill:currentColor;width:1.2rem;height:1.2rem;color:var(\u002d\u002daccent)}","htmlAttributes":{"href":"#","aria-label":"Follow instructor on X"},"iconOnly":true} -->
    <a class="gb-text-81383c73" href="#" aria-label="Follow instructor on X"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M389.2 48h70.6L305.6 224.2 487 464H345L233.7 318.6 106.5 464H35.8L200.7 275.5 26.8 48H172.4L272.9 180.9 389.2 48zM364.4 421.8h39.1L151.1 88h-42L364.4 421.8z"></path></svg></span></a>
    <!-- wp:generateblocks/text {"uniqueId":"b83cb6ef","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"fill":"currentColor","width":"1.2rem","height":"1.2rem","color":"var(\u002d\u002daccent)"},"color":"#000","\u0026:is(:hover, :focus) .gb-shape svg":{"color":"var(\u002d\u002daccent-2)"}},"css":".gb-text-b83cb6ef{align-items:center;color:#000;column-gap:0.5em;display:inline-flex}.gb-text-b83cb6ef:is(:hover,:focus) .gb-shape svg{color:var(\u002d\u002daccent-2)}.gb-text-b83cb6ef .gb-shape svg{fill:currentColor;width:1.2rem;height:1.2rem;color:var(\u002d\u002daccent)}","htmlAttributes":{"href":"#","aria-label":"Follow instructor on LinkedIn"},"iconOnly":true} -->
    <a class="gb-text-b83cb6ef" href="#" aria-label="Follow instructor on LinkedIn"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 448 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M100.28 448H7.4V148.9h92.88zM53.79 108.1C24.09 108.1 0 83.5 0 53.8a53.79 53.79 0 0 1 107.58 0c0 29.7-24.1 54.3-53.79 54.3zM447.9 448h-92.68V302.4c0-34.7-.7-79.2-48.29-79.2-48.29 0-55.69 37.7-55.69 76.7V448h-92.78V148.9h89.08v40.8h1.3c12.4-23.5 42.69-48.3 87.88-48.3 94 0 111.28 61.9 111.28 142.3V448z"></path></svg></span></a>
    <!-- /wp:generateblocks-pro/tab-item --></div>
    <!-- /wp:generateblocks-pro/tab-items --></div>
    <!-- /wp:generateblocks-pro/tabs --></div>
    <!-- wp:generateblocks/element {"uniqueId":"4df78355","tagName":"div","styles":{"paddingTop":"2rem","paddingLeft":"2rem","paddingBottom":"2rem","paddingRight":"2rem","borderTopColor":"var(\u002d\u002dbase)","borderRightColor":"var(\u002d\u002dbase)","borderBottomColor":"var(\u002d\u002dbase)","borderLeftColor":"var(\u002d\u002dbase)","width":"100%","borderTopWidth":"1px","borderRightWidth":"1px","borderBottomWidth":"1px","borderLeftWidth":"1px","borderTopStyle":"solid","borderRightStyle":"solid","borderBottomStyle":"solid","borderLeftStyle":"solid","backgroundColor":"var(\u002d\u002dbase-2)","position":"sticky","top":"1rem","alignSelf":"start","@media (max-width:1024px)":{"position":"relative"}},"css":".gb-element-4df78355{align-self:start;background-color:var(\u002d\u002dbase-2);position:sticky;top:1rem;width:100%;border:1px solid var(\u002d\u002dbase);padding:2rem}@media (max-width:1024px){.gb-element-4df78355{position:relative}}","metadata":{"name":"Content Container"}} -->
    <div class="gb-element-4df78355"><!-- wp:generateblocks/text {"uniqueId":"81027fdc","tagName":"p","styles":{"fontSize":"1rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"color":"var(\u002d\u002dcontrast-3)","marginBottom":"1rem"},"css":".gb-text-81027fdc{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;font-size:1rem;margin-bottom:1rem}.gb-text-81027fdc .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-81027fdc"><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M176.49,95.51a12,12,0,0,1,0,17l-56,56a12,12,0,0,1-17,0l-24-24a12,12,0,1,1,17-17L112,143l47.51-47.52A12,12,0,0,1,176.49,95.51ZM236,128A108,108,0,1,1,128,20,108.12,108.12,0,0,1,236,128Zm-24,0a84,84,0,1,0-84,84A84.09,84.09,0,0,0,212,128Z"></path></svg></span><span class="gb-text">30-Day Money-Back Guarantee</span></p>
    <!-- wp:generateblocks/element {"uniqueId":"1494387e","tagName":"div","styles":{"display":"flex","columnGap":"1em","justifyContent":"space-between","alignItems":"center","paddingTop":"1.3rem","paddingBottom":"1.3rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)"},"css":".gb-element-1494387e{align-items:center;column-gap:1em;display:flex;justify-content:space-between;padding-bottom:1.3rem;padding-top:1.3rem;border-bottom:1px solid var(\u002d\u002dbase)}"} -->
    <div class="gb-element-1494387e"><!-- wp:generateblocks/text {"uniqueId":"8cfd0ecd","tagName":"span","styles":{"textAlign":"left"},"css":".gb-text-8cfd0ecd{text-align:left}"} -->
    <span class="gb-text gb-text-8cfd0ecd">Created:</span>
    <!-- wp:generateblocks/text {"uniqueId":"761e7b9a","tagName":"span","styles":{"fontSize":"0.85rem","paddingTop":"3px","paddingBottom":"3px","paddingLeft":"8px","paddingRight":"8px","borderTopLeftRadius":"4px","borderTopRightRadius":"4px","borderBottomLeftRadius":"4px","borderBottomRightRadius":"4px","backgroundColor":"var(\u002d\u002dbase)"},"css":".gb-text-761e7b9a{background-color:var(\u002d\u002dbase);font-size:0.85rem;border-radius:4px;padding:3px 8px}"} -->
    <span class="gb-text gb-text-761e7b9a">February 12, 2025</span>
    <!-- wp:generateblocks/element {"uniqueId":"79c59ca8","tagName":"div","styles":{"display":"flex","columnGap":"1em","justifyContent":"space-between","alignItems":"center","paddingTop":"1.3rem","paddingBottom":"1.3rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)"},"css":".gb-element-79c59ca8{align-items:center;column-gap:1em;display:flex;justify-content:space-between;padding-bottom:1.3rem;padding-top:1.3rem;border-bottom:1px solid var(\u002d\u002dbase)}"} -->
    <div class="gb-element-79c59ca8"><!-- wp:generateblocks/text {"uniqueId":"e6698c22","tagName":"span","styles":{"textAlign":"left"},"css":".gb-text-e6698c22{text-align:left}"} -->
    <span class="gb-text gb-text-e6698c22">Updated:</span>
    <!-- wp:generateblocks/text {"uniqueId":"ccf4c52d","tagName":"span","styles":{"fontSize":"0.85rem","paddingTop":"3px","paddingBottom":"3px","paddingLeft":"8px","paddingRight":"8px","borderTopLeftRadius":"4px","borderTopRightRadius":"4px","borderBottomLeftRadius":"4px","borderBottomRightRadius":"4px","backgroundColor":"var(\u002d\u002dbase)"},"css":".gb-text-ccf4c52d{background-color:var(\u002d\u002dbase);font-size:0.85rem;border-radius:4px;padding:3px 8px}"} -->
    <span class="gb-text gb-text-ccf4c52d">March 10, 2025</span>
    <!-- wp:generateblocks/element {"uniqueId":"5e7e9cf2","tagName":"div","styles":{"display":"flex","columnGap":"1em","justifyContent":"space-between","alignItems":"center","paddingTop":"1.3rem","paddingBottom":"1.3rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)"},"css":".gb-element-5e7e9cf2{align-items:center;column-gap:1em;display:flex;justify-content:space-between;padding-bottom:1.3rem;padding-top:1.3rem;border-bottom:1px solid var(\u002d\u002dbase)}"} -->
    <div class="gb-element-5e7e9cf2"><!-- wp:generateblocks/text {"uniqueId":"f1eb4abc","tagName":"span","styles":{"textAlign":"left"},"css":".gb-text-f1eb4abc{text-align:left}"} -->
    <span class="gb-text gb-text-f1eb4abc">Lessons:</span>
    <!-- wp:generateblocks/text {"uniqueId":"a974f038","tagName":"span","styles":{"fontSize":"0.85rem","paddingTop":"3px","paddingBottom":"3px","paddingLeft":"8px","paddingRight":"8px","borderTopLeftRadius":"4px","borderTopRightRadius":"4px","borderBottomLeftRadius":"4px","borderBottomRightRadius":"4px","backgroundColor":"var(\u002d\u002dbase)"},"css":".gb-text-a974f038{background-color:var(\u002d\u002dbase);font-size:0.85rem;border-radius:4px;padding:3px 8px}"} -->
    <span class="gb-text gb-text-a974f038">12</span>
    <!-- wp:generateblocks/element {"uniqueId":"56d15faf","tagName":"div","styles":{"display":"flex","columnGap":"1em","justifyContent":"space-between","alignItems":"center","paddingTop":"1.3rem","paddingBottom":"1.3rem","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase)"},"css":".gb-element-56d15faf{align-items:center;column-gap:1em;display:flex;justify-content:space-between;padding-bottom:1.3rem;padding-top:1.3rem;border-bottom:1px solid var(\u002d\u002dbase)}"} -->
    <div class="gb-element-56d15faf"><!-- wp:generateblocks/text {"uniqueId":"179651b0","tagName":"span","styles":{"textAlign":"left"},"css":".gb-text-179651b0{text-align:left}"} -->
    <span class="gb-text gb-text-179651b0">Skill Level:</span>
    <!-- wp:generateblocks/text {"uniqueId":"3084fb2f","tagName":"span","styles":{"fontSize":"0.85rem","paddingTop":"3px","paddingBottom":"3px","paddingLeft":"8px","paddingRight":"8px","borderTopLeftRadius":"4px","borderTopRightRadius":"4px","borderBottomLeftRadius":"4px","borderBottomRightRadius":"4px","backgroundColor":"var(\u002d\u002dbase)"},"css":".gb-text-3084fb2f{background-color:var(\u002d\u002dbase);font-size:0.85rem;border-radius:4px;padding:3px 8px}"} -->
    <span class="gb-text gb-text-3084fb2f">Beginner</span>
    <!-- wp:generateblocks/text {"uniqueId":"6a3b40f9","tagName":"h3","styles":{"textAlign":"left","fontSize":"1.4rem","marginBottom":"0.8rem","marginTop":"3rem"},"css":".gb-text-6a3b40f9{font-size:1.4rem;margin-bottom:0.8rem;margin-top:3rem;text-align:left}"} -->
    <h3 class="gb-text gb-text-6a3b40f9">Requirements</h3>
    <!-- wp:generateblocks/text {"uniqueId":"782dcf04","tagName":"p","styles":{"textAlign":"left","fontSize":"1rem"},"css":".gb-text-782dcf04{font-size:1rem;text-align:left}"} -->
    <p class="gb-text gb-text-782dcf04">Curabitur pharetra quis mi eget viverra. Donec vel mauris nibh. Integer magna risus, malesuada ut nunc non, viverra pharetra orci.</p>
    <!-- wp:generateblocks/text {"uniqueId":"44476862","tagName":"h3","styles":{"textAlign":"left","fontSize":"1.4rem","marginBottom":"0.8rem","marginTop":"3rem"},"css":".gb-text-44476862{font-size:1.4rem;margin-bottom:0.8rem;margin-top:3rem;text-align:left}"} -->
    <h3 class="gb-text gb-text-44476862">Who is it for</h3>
    <!-- wp:generateblocks/text {"uniqueId":"b9640601","tagName":"p","styles":{"textAlign":"left","display":"flex","columnGap":"1em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"fontSize":"1rem","marginBottom":"1rem","alignItems":"center"},"css":".gb-text-b9640601{align-items:center;column-gap:1em;display:flex;font-size:1rem;margin-bottom:1rem;text-align:left}.gb-text-b9640601 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}"} -->
    <p class="gb-text-b9640601"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M173.898 439.404l-166.4-166.4c-9.997-9.997-9.997-26.206 0-36.204l36.203-36.204c9.997-9.998 26.207-9.998 36.204 0L192 312.69 432.095 72.596c9.997-9.997 26.207-9.997 36.204 0l36.203 36.204c9.997 9.997 9.997 26.206 0 36.204l-294.4 294.401c-9.998 9.997-26.207 9.997-36.204-.001z"></path></svg></span><span class="gb-text">Curabitur pharetra quis mi eget viverra.</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"77c84df2","tagName":"p","styles":{"textAlign":"left","display":"flex","alignItems":"center","columnGap":"1em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"fontSize":"1rem","marginBottom":"1rem"},"css":".gb-text-77c84df2{align-items:center;column-gap:1em;display:flex;font-size:1rem;margin-bottom:1rem;text-align:left}.gb-text-77c84df2 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}"} -->
    <p class="gb-text-77c84df2"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M173.898 439.404l-166.4-166.4c-9.997-9.997-9.997-26.206 0-36.204l36.203-36.204c9.997-9.998 26.207-9.998 36.204 0L192 312.69 432.095 72.596c9.997-9.997 26.207-9.997 36.204 0l36.203 36.204c9.997 9.997 9.997 26.206 0 36.204l-294.4 294.401c-9.998 9.997-26.207 9.997-36.204-.001z"></path></svg></span><span class="gb-text">Curabitur pharetra quis mi eget viverra.</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"ec30d2f7","tagName":"p","styles":{"textAlign":"left","display":"flex","alignItems":"center","columnGap":"1em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"fontSize":"1rem","marginBottom":"1rem"},"css":".gb-text-ec30d2f7{align-items:center;column-gap:1em;display:flex;font-size:1rem;margin-bottom:1rem;text-align:left}.gb-text-ec30d2f7 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}"} -->
    <p class="gb-text-ec30d2f7"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M173.898 439.404l-166.4-166.4c-9.997-9.997-9.997-26.206 0-36.204l36.203-36.204c9.997-9.998 26.207-9.998 36.204 0L192 312.69 432.095 72.596c9.997-9.997 26.207-9.997 36.204 0l36.203 36.204c9.997 9.997 9.997 26.206 0 36.204l-294.4 294.401c-9.998 9.997-26.207 9.997-36.204-.001z"></path></svg></span><span class="gb-text">Curabitur pharetra quis mi eget viverra.</span></p>
    <!-- wp:generateblocks/element {"uniqueId":"462bb1eb","tagName":"div","styles":{"display":"flex","columnGap":"1.25rem","marginTop":"3rem","marginBottom":"3rem","alignItems":"center","justifyContent":"center"},"css":".gb-element-462bb1eb{align-items:center;column-gap:1.25rem;display:flex;justify-content:center;margin-bottom:3rem;margin-top:3rem}","metadata":{"name":"Social icons"}} -->
    <div class="gb-element-462bb1eb"><!-- wp:generateblocks/text {"uniqueId":"77c86b4b","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"fontSize":"1.15rem","\u0026:is(:hover, :focus) .gb-shape svg":{"color":"var(\u002d\u002daccent-2)"}},"css":".gb-text-77c86b4b{align-items:center;column-gap:0.5em;display:inline-flex;font-size:1.15rem}.gb-text-77c86b4b:is(:hover,:focus) .gb-shape svg{color:var(\u002d\u002daccent-2)}.gb-text-77c86b4b .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","htmlAttributes":{"href":"#","aria-label":"Facebook"},"iconOnly":true} -->
    <a class="gb-text-77c86b4b" href="#" aria-label="Facebook"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M504 256C504 119 393 8 256 8S8 119 8 256c0 123.78 90.69 226.38 209.25 245V327.69h-63V256h63v-54.64c0-62.15 37-96.48 93.67-96.48 27.14 0 55.52 4.84 55.52 4.84v61h-31.28c-30.8 0-40.41 19.12-40.41 38.73V256h68.78l-11 71.69h-57.78V501C413.31 482.38 504 379.78 504 256z"></path></svg></span></a>
    <!-- wp:generateblocks/text {"uniqueId":"e755142a","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"fontSize":"1.15rem","color":"var(\u002d\u002dbase-3)","\u0026:is(:hover, :focus) .gb-shape svg":{"color":"var(\u002d\u002daccent-2)"}},"css":".gb-text-e755142a{align-items:center;color:var(\u002d\u002dbase-3);column-gap:0.5em;display:inline-flex;font-size:1.15rem}.gb-text-e755142a:is(:hover,:focus) .gb-shape svg{color:var(\u002d\u002daccent-2)}.gb-text-e755142a .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","htmlAttributes":{"href":"#","aria-label":"Instagram"},"iconOnly":true} -->
    <a class="gb-text-e755142a" href="#" aria-label="Instagram"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 448 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M224.1 141c-63.6 0-114.9 51.3-114.9 114.9s51.3 114.9 114.9 114.9S339 319.5 339 255.9 287.7 141 224.1 141zm0 189.6c-41.1 0-74.7-33.5-74.7-74.7s33.5-74.7 74.7-74.7 74.7 33.5 74.7 74.7-33.6 74.7-74.7 74.7zm146.4-194.3c0 14.9-12 26.8-26.8 26.8-14.9 0-26.8-12-26.8-26.8s12-26.8 26.8-26.8 26.8 12 26.8 26.8zm76.1 27.2c-1.7-35.9-9.9-67.7-36.2-93.9-26.2-26.2-58-34.4-93.9-36.2-37-2.1-147.9-2.1-184.9 0-35.8 1.7-67.6 9.9-93.9 36.1s-34.4 58-36.2 93.9c-2.1 37-2.1 147.9 0 184.9 1.7 35.9 9.9 67.7 36.2 93.9s58 34.4 93.9 36.2c37 2.1 147.9 2.1 184.9 0 35.9-1.7 67.7-9.9 93.9-36.2 26.2-26.2 34.4-58 36.2-93.9 2.1-37 2.1-147.8 0-184.8zM398.8 388c-7.8 19.6-22.9 34.7-42.6 42.6-29.5 11.7-99.5 9-132.1 9s-102.7 2.6-132.1-9c-19.6-7.8-34.7-22.9-42.6-42.6-11.7-29.5-9-99.5-9-132.1s-2.6-102.7 9-132.1c7.8-19.6 22.9-34.7 42.6-42.6 29.5-11.7 99.5-9 132.1-9s102.7-2.6 132.1 9c19.6 7.8 34.7 22.9 42.6 42.6 11.7 29.5 9 99.5 9 132.1s2.7 102.7-9 132.1z"></path></svg></span></a>
    <!-- wp:generateblocks/text {"uniqueId":"3eef7f8d","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"fontSize":"1.15rem","color":"var(\u002d\u002dbase-3)","\u0026:is(:hover, :focus) .gb-shape svg":{"color":"var(\u002d\u002daccent-2)"}},"css":".gb-text-3eef7f8d{align-items:center;color:var(\u002d\u002dbase-3);column-gap:0.5em;display:inline-flex;font-size:1.15rem}.gb-text-3eef7f8d:is(:hover,:focus) .gb-shape svg{color:var(\u002d\u002daccent-2)}.gb-text-3eef7f8d .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","htmlAttributes":{"href":"#","aria-label":"LinkedIn"},"iconOnly":true} -->
    <a class="gb-text-3eef7f8d" href="#" aria-label="LinkedIn"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 448 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M100.28 448H7.4V148.9h92.88zM53.79 108.1C24.09 108.1 0 83.5 0 53.8a53.79 53.79 0 0 1 107.58 0c0 29.7-24.1 54.3-53.79 54.3zM447.9 448h-92.68V302.4c0-34.7-.7-79.2-48.29-79.2-48.29 0-55.69 37.7-55.69 76.7V448h-92.78V148.9h89.08v40.8h1.3c12.4-23.5 42.69-48.3 87.88-48.3 94 0 111.28 61.9 111.28 142.3V448z"></path></svg></span></a>
    <!-- wp:generateblocks/text {"uniqueId":"bf3b38a2","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"fontSize":"1.15rem","color":"var(\u002d\u002dbase-3)","\u0026:is(:hover, :focus) .gb-shape svg":{"color":"var(\u002d\u002daccent-2)"}},"css":".gb-text-bf3b38a2{align-items:center;color:var(\u002d\u002dbase-3);column-gap:0.5em;display:inline-flex;font-size:1.15rem}.gb-text-bf3b38a2:is(:hover,:focus) .gb-shape svg{color:var(\u002d\u002daccent-2)}.gb-text-bf3b38a2 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","htmlAttributes":{"href":"#","aria-label":"X"},"iconOnly":true} -->
    <a class="gb-text-bf3b38a2" href="#" aria-label="X"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M389.2 48h70.6L305.6 224.2 487 464H345L233.7 318.6 106.5 464H35.8L200.7 275.5 26.8 48H172.4L272.9 180.9 389.2 48zM364.4 421.8h39.1L151.1 88h-42L364.4 421.8z"></path></svg></span></a>
    <!-- wp:generateblocks/text {"uniqueId":"4cb8d938","tagName":"a","styles":{"display":"flex","paddingTop":"1rem","paddingRight":"2rem","paddingBottom":"1rem","paddingLeft":"2rem","textDecoration":"none","textTransform":"uppercase"},"css":".gb-text-4cb8d938{display:flex;text-decoration:none;text-transform:uppercase;padding:1rem 2rem}","globalClasses":["gbp-button\u002d\u002dprimary"],"htmlAttributes":{"href":"#"}} -->
    <a class="gb-text gbp-button--primary gb-text-4cb8d938" href="#">Sign up</a>
    <!-- wp:generateblocks/element {"uniqueId":"5b44323d","tagName":"section","styles":{"zIndex":"1","position":"relative","paddingTop":"4rem"},"css":".gb-element-5b44323d{padding-top:4rem;position:relative;z-index:1}","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <section class="gbp-section gb-element-5b44323d"><!-- wp:generateblocks/element {"uniqueId":"fc6fdc73","tagName":"div","styles":[],"globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container max-width"}} -->
    <div class="gbp-section__inner"><!-- wp:generateblocks/text {"uniqueId":"caba7a8f","tagName":"p","globalClasses":["gbp-section__tagline"]} -->
    <p class="gb-text gbp-section__tagline">Courses</p>
    <!-- wp:generateblocks/text {"uniqueId":"50de6661","tagName":"h2","styles":{"textTransform":"capitalize","marginBottom":"2.5rem"},"css":".gb-text-50de6661{margin-bottom:2.5rem;text-transform:capitalize}","globalClasses":["gbp-section__headline"]} -->
    <h2 class="gb-text gbp-section__headline gb-text-50de6661">Related courses</h2>
    <!-- wp:generateblocks/element {"uniqueId":"ad552217","tagName":"div","styles":{"marginLeft":"auto","marginRight":"auto","display":"grid","gridTemplateColumns":"repeat(3, minmax(0, 1fr))","columnGap":"2.25rem","rowGap":"3rem","@media (max-width:1024px)":{"gridTemplateColumns":"repeat(2, minmax(0, 1fr))"},"@media (max-width:767px)":{"gridTemplateColumns":"1fr"}},"css":".gb-element-ad552217{column-gap:2.25rem;display:grid;grid-template-columns:repeat(3,minmax(0,1fr));margin-left:auto;margin-right:auto;row-gap:3rem}@media (max-width:1024px){.gb-element-ad552217{grid-template-columns:repeat(2,minmax(0,1fr))}}@media (max-width:767px){.gb-element-ad552217{grid-template-columns:1fr}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container max-width"}} -->
    <div class="gbp-section__inner gb-element-ad552217"><!-- wp:generateblocks/element {"uniqueId":"5c27b723","tagName":"div","styles":{"\u0026:hover":{"transform":"scale(1.05)"}},"css":".gb-element-5c27b723:hover{transform:scale(1.05)}","globalClasses":["gbp-card"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-card gb-element-5c27b723"><!-- wp:generateblocks/element {"uniqueId":"ddcb08d3","tagName":"div","styles":{"position":"relative"},"css":".gb-element-ddcb08d3{position:relative}"} -->
    <div class="gb-element-ddcb08d3"><!-- wp:generateblocks/media {"uniqueId":"423ee86d","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","marginBottom":"1.6rem","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","@media (max-width:767px)":{"height":"auto"}},"css":".gb-media-423ee86d{display:block;height:250px;margin-bottom:1.6rem;max-width:100%;object-fit:cover;width:100%;border-radius:6px}@media (max-width:767px){.gb-media-423ee86d{height:auto}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3-768x576.png","title":"image-4-3"},"mediaId":46292} -->
    <img class="gb-media-423ee86d" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3-768x576.png" title="image-4-3"/>
    <!-- wp:generateblocks/text {"uniqueId":"d52bc1e5","tagName":"p","styles":{"fontSize":"0.9rem","position":"absolute","top":"1rem","left":"1rem","paddingTop":"2px","paddingBottom":"2px","paddingLeft":"10px","paddingRight":"10px","backgroundColor":"var(\u002d\u002daccent)","borderTopLeftRadius":"3px","borderTopRightRadius":"3px","borderBottomLeftRadius":"3px","borderBottomRightRadius":"3px","color":"var(\u002d\u002dbase-3)"},"css":".gb-text-d52bc1e5{background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-3);font-size:0.9rem;left:1rem;position:absolute;top:1rem;border-radius:3px;padding:2px 10px}"} -->
    <p class="gb-text gb-text-d52bc1e5">Program</p>
    <!-- wp:generateblocks/element {"uniqueId":"9adbd9e0","tagName":"div","styles":{"display":"flex","columnGap":"0.3em","rowGap":"0.3em","flexWrap":"wrap","marginBottom":"1rem"},"css":".gb-element-9adbd9e0{column-gap:0.3em;display:flex;flex-wrap:wrap;margin-bottom:1rem;row-gap:0.3em}"} -->
    <div class="gb-element-9adbd9e0"><!-- wp:generateblocks/element {"uniqueId":"e63e1606","tagName":"div","styles":{"display":"flex"},"css":".gb-element-e63e1606{display:flex}"} -->
    <div class="gb-element-e63e1606"><!-- wp:generateblocks/text {"uniqueId":"2fc4c97e","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-2fc4c97e{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-2fc4c97e .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-2fc4c97e"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"94b8f0ce","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-94b8f0ce{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-94b8f0ce .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-94b8f0ce"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"e14199a0","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-e14199a0{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-e14199a0 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-e14199a0"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"b707e487","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-b707e487{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-b707e487 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-b707e487"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"6899d317","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0"},"css":".gb-text-6899d317{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0}.gb-text-6899d317 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-6899d317"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"52a60414","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","marginBottom":"0px","fontWeight":"600"},"css":".gb-text-52a60414{color:var(\u002d\u002daccent);font-weight:600;margin-bottom:0px}"} -->
    <p class="gb-text gb-text-52a60414">(12 Reviews)</p>
    <!-- wp:generateblocks/text {"uniqueId":"fb52f664","tagName":"h3","styles":{"marginBottom":"0.2rem"},"css":".gb-text-fb52f664{margin-bottom:0.2rem}","globalClasses":["gbp-card__title"]} -->
    <h3 class="gb-text gbp-card__title gb-text-fb52f664">Course 1</h3>
    <!-- wp:generateblocks/text {"uniqueId":"5e22c4f1","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","fontWeight":"500","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"fontSize":"1rem","marginBottom":"0px"},"css":".gb-text-5e22c4f1{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:inline-flex;font-size:1rem;font-weight:500;margin-bottom:0px}.gb-text-5e22c4f1 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-5e22c4f1"><span class="gb-shape"><svg viewBox="0 0 685.7 645.8" xmlns="http://www.w3.org/2000/svg"><path style="fill:currentColor" d="M657.1 623.2c5.5 0 10.8-2.5 14.2-6.8 3.5-4.3 4.8-9.9 3.7-15.3l-11.6-54.7c6.6-6.4 10.7-15.2 10.7-25.1s-4.6-19.6-11.8-26V305.5L616 334.2v161.2c-7.2 6.4-11.8 15.6-11.8 26s4.1 18.8 10.7 25.1l-11.6 54.7c-1.1 5.4.2 11 3.7 15.3 3.5 4.3 8.7 6.8 14.2 6.8h35.7Zm15.7-428.6L371.5 8.2C362.7 2.8 352.7 0 342.8 0s-19.9 2.7-28.7 8.2L12.9 194.6c-8 5-12.9 13.8-12.9 23.2s4.9 18.3 12.9 23.2l301.2 186.5c8.8 5.4 18.7 8.2 28.7 8.2s19.9-2.7 28.7-8.2L672.7 241c8-5 12.9-13.8 12.9-23.2s-4.9-18.3-12.9-23.2ZM342.8 482c-18.8 0-37.1-5.2-53-15.1L114.1 358.1v187.3c0 55.4 102.5 100.3 228.8 100.3s228.8-44.9 228.8-100.3V358.1L396 466.9c-16 9.9-34.3 15.1-53.1 15.1Z"></path></svg></span><span class="gb-text">4 Lessons</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"26f2a649","tagName":"p","styles":[],"globalClasses":["gbp-card__text"]} -->
    <p class="gb-text gbp-card__text">Info about the course</p>
    <!-- wp:generateblocks/element {"uniqueId":"c53ec8de","tagName":"div","styles":{"display":"flex","flexDirection":"row","alignItems":"center","justifyContent":"flex-start","rowGap":"0.5rem","textAlign":"left","columnGap":"0.8em","marginBottom":"1em","paddingBottom":"0.8rem"},"css":".gb-element-c53ec8de{align-items:center;column-gap:0.8em;display:flex;flex-direction:row;justify-content:flex-start;margin-bottom:1em;padding-bottom:0.8rem;row-gap:0.5rem;text-align:left}","htmlAttributes":[],"metadata":{"name":"Meta Byline"}} -->
    <div class="gb-element-c53ec8de"><!-- wp:generateblocks/media {"uniqueId":"a10dcd80","tagName":"img","styles":{"width":"50px","height":"50px","borderTopLeftRadius":"100%","borderTopRightRadius":"100%","borderBottomLeftRadius":"100%","borderBottomRightRadius":"100%","display":"block"},"css":".gb-media-a10dcd80{display:block;height:50px;width:50px;border-radius:100%}","globalClasses":["gbp\u002d\u002dborder"],"htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/user-150x150.png","title":"user"},"mediaId":46293,"linkHtmlAttributes":[],"metadata":[]} -->
    <img class="gbp--border gb-media-a10dcd80" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/user-150x150.png" title="user"/>
    <!-- wp:generateblocks/text {"uniqueId":"cc1c5c51","tagName":"div","styles":[],"globalClasses":["gbp-card__meta-text"],"htmlAttributes":[],"metadata":[]} -->
    <div class="gb-text gbp-card__meta-text">By <strong>Instructor</strong></div>
    <!-- wp:generateblocks/element {"uniqueId":"dfbd0408","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem"},"css":".gb-element-dfbd0408{column-gap:1rem;display:flex;margin-top:2rem}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-dfbd0408"><!-- wp:generateblocks/text {"uniqueId":"4f881c3d","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-4f881c3d{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-4f881c3d:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-4f881c3d:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-4f881c3d .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-4f881c3d span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dtertiary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--tertiary gb-text-4f881c3d" href="#"><span class="gb-text">Discover course</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- wp:generateblocks/element {"uniqueId":"4a6d4d09","tagName":"div","styles":{"\u0026:hover":{"transform":"scale(1.05)"}},"css":".gb-element-4a6d4d09:hover{transform:scale(1.05)}","globalClasses":["gbp-card"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-card gb-element-4a6d4d09"><!-- wp:generateblocks/element {"uniqueId":"a2e7c543","tagName":"div","styles":{"position":"relative"},"css":".gb-element-a2e7c543{position:relative}"} -->
    <div class="gb-element-a2e7c543"><!-- wp:generateblocks/media {"uniqueId":"6c5f6b92","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","marginBottom":"1.6rem","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","@media (max-width:767px)":{"height":"auto"}},"css":".gb-media-6c5f6b92{display:block;height:250px;margin-bottom:1.6rem;max-width:100%;object-fit:cover;width:100%;border-radius:6px}@media (max-width:767px){.gb-media-6c5f6b92{height:auto}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3-768x576.png","title":"image-4-3"},"mediaId":46292} -->
    <img class="gb-media-6c5f6b92" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3-768x576.png" title="image-4-3"/>
    <!-- wp:generateblocks/text {"uniqueId":"9229a7e3","tagName":"p","styles":{"fontSize":"0.9rem","position":"absolute","top":"1rem","left":"1rem","paddingTop":"2px","paddingBottom":"2px","paddingLeft":"10px","paddingRight":"10px","backgroundColor":"var(\u002d\u002daccent)","borderTopLeftRadius":"3px","borderTopRightRadius":"3px","borderBottomLeftRadius":"3px","borderBottomRightRadius":"3px","color":"var(\u002d\u002dbase-3)"},"css":".gb-text-9229a7e3{background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-3);font-size:0.9rem;left:1rem;position:absolute;top:1rem;border-radius:3px;padding:2px 10px}"} -->
    <p class="gb-text gb-text-9229a7e3">Program</p>
    <!-- wp:generateblocks/element {"uniqueId":"df94e3bc","tagName":"div","styles":{"display":"flex","columnGap":"0.3em","rowGap":"0.3em","flexWrap":"wrap","marginBottom":"1rem"},"css":".gb-element-df94e3bc{column-gap:0.3em;display:flex;flex-wrap:wrap;margin-bottom:1rem;row-gap:0.3em}"} -->
    <div class="gb-element-df94e3bc"><!-- wp:generateblocks/element {"uniqueId":"6457a76c","tagName":"div","styles":{"display":"flex"},"css":".gb-element-6457a76c{display:flex}"} -->
    <div class="gb-element-6457a76c"><!-- wp:generateblocks/text {"uniqueId":"a6f6b422","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-a6f6b422{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-a6f6b422 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-a6f6b422"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- /wp:generateblocks/text -->
    <!-- wp:generateblocks/text {"uniqueId":"a1f81bd6","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-a1f81bd6{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-a1f81bd6 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-a1f81bd6"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"82ccbd6a","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-82ccbd6a{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-82ccbd6a .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-82ccbd6a"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"95f93ab1","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-95f93ab1{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-95f93ab1 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-95f93ab1"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"2f2163d0","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0"},"css":".gb-text-2f2163d0{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0}.gb-text-2f2163d0 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-2f2163d0"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- /wp:generateblocks/text --></div>
    <!-- wp:generateblocks/text {"uniqueId":"828a891d","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","marginBottom":"0px","fontWeight":"600"},"css":".gb-text-828a891d{color:var(\u002d\u002daccent);font-weight:600;margin-bottom:0px}"} -->
    <p class="gb-text gb-text-828a891d">(22 Reviews)</p>
    <!-- wp:generateblocks/text {"uniqueId":"b1da3999","tagName":"h3","styles":{"marginBottom":"0.2rem"},"css":".gb-text-b1da3999{margin-bottom:0.2rem}","globalClasses":["gbp-card__title"]} -->
    <h3 class="gb-text gbp-card__title gb-text-b1da3999">Course 2</h3>
    <!-- wp:generateblocks/text {"uniqueId":"43b72f38","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","fontWeight":"500","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"fontSize":"1rem","marginBottom":"0px"},"css":".gb-text-43b72f38{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:inline-flex;font-size:1rem;font-weight:500;margin-bottom:0px}.gb-text-43b72f38 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-43b72f38"><span class="gb-shape"><svg viewBox="0 0 685.7 645.8" xmlns="http://www.w3.org/2000/svg"><path style="fill:currentColor" d="M657.1 623.2c5.5 0 10.8-2.5 14.2-6.8 3.5-4.3 4.8-9.9 3.7-15.3l-11.6-54.7c6.6-6.4 10.7-15.2 10.7-25.1s-4.6-19.6-11.8-26V305.5L616 334.2v161.2c-7.2 6.4-11.8 15.6-11.8 26s4.1 18.8 10.7 25.1l-11.6 54.7c-1.1 5.4.2 11 3.7 15.3 3.5 4.3 8.7 6.8 14.2 6.8h35.7Zm15.7-428.6L371.5 8.2C362.7 2.8 352.7 0 342.8 0s-19.9 2.7-28.7 8.2L12.9 194.6c-8 5-12.9 13.8-12.9 23.2s4.9 18.3 12.9 23.2l301.2 186.5c8.8 5.4 18.7 8.2 28.7 8.2s19.9-2.7 28.7-8.2L672.7 241c8-5 12.9-13.8 12.9-23.2s-4.9-18.3-12.9-23.2ZM342.8 482c-18.8 0-37.1-5.2-53-15.1L114.1 358.1v187.3c0 55.4 102.5 100.3 228.8 100.3s228.8-44.9 228.8-100.3V358.1L396 466.9c-16 9.9-34.3 15.1-53.1 15.1Z"></path></svg></span><span class="gb-text">12 Lessons</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"c505e6db","tagName":"p","styles":[],"globalClasses":["gbp-card__text"]} -->
    <!-- wp:generateblocks/element {"uniqueId":"a0a41822","tagName":"div","styles":{"display":"flex","flexDirection":"row","alignItems":"center","justifyContent":"flex-start","rowGap":"0.5rem","textAlign":"left","columnGap":"0.8em","marginBottom":"1em","paddingBottom":"0.8rem"},"css":".gb-element-a0a41822{align-items:center;column-gap:0.8em;display:flex;flex-direction:row;justify-content:flex-start;margin-bottom:1em;padding-bottom:0.8rem;row-gap:0.5rem;text-align:left}","htmlAttributes":[],"metadata":{"name":"Meta Byline"}} -->
    <div class="gb-element-a0a41822"><!-- wp:generateblocks/media {"uniqueId":"5e6e0322","tagName":"img","styles":{"width":"50px","height":"50px","borderTopLeftRadius":"100%","borderTopRightRadius":"100%","borderBottomLeftRadius":"100%","borderBottomRightRadius":"100%","display":"block"},"css":".gb-media-5e6e0322{display:block;height:50px;width:50px;border-radius:100%}","globalClasses":["gbp\u002d\u002dborder"],"htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/user-150x150.png","title":"user"},"mediaId":46293,"linkHtmlAttributes":[],"metadata":[]} -->
    <img class="gbp--border gb-media-5e6e0322" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/user-150x150.png" title="user"/>
    <!-- wp:generateblocks/text {"uniqueId":"ba32baf9","tagName":"div","styles":[],"globalClasses":["gbp-card__meta-text"],"htmlAttributes":[],"metadata":[]} -->
    <!-- wp:generateblocks/element {"uniqueId":"0ef10322","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem"},"css":".gb-element-0ef10322{column-gap:1rem;display:flex;margin-top:2rem}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-0ef10322"><!-- wp:generateblocks/text {"uniqueId":"685b19b4","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-685b19b4{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-685b19b4:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-685b19b4:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-685b19b4 .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-685b19b4 span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dtertiary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--tertiary gb-text-685b19b4" href="#"><span class="gb-text">Discover course</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- wp:generateblocks/element {"uniqueId":"18f20a0b","tagName":"div","styles":{"\u0026:hover":{"transform":"scale(1.05)"}},"css":".gb-element-18f20a0b:hover{transform:scale(1.05)}","globalClasses":["gbp-card"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-card gb-element-18f20a0b"><!-- wp:generateblocks/element {"uniqueId":"636580cf","tagName":"div","styles":{"position":"relative"},"css":".gb-element-636580cf{position:relative}"} -->
    <div class="gb-element-636580cf"><!-- wp:generateblocks/media {"uniqueId":"80292d4f","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","marginBottom":"1.6rem","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","@media (max-width:767px)":{"height":"auto"}},"css":".gb-media-80292d4f{display:block;height:250px;margin-bottom:1.6rem;max-width:100%;object-fit:cover;width:100%;border-radius:6px}@media (max-width:767px){.gb-media-80292d4f{height:auto}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3-768x576.png","title":"image-4-3"},"mediaId":46292} -->
    <img class="gb-media-80292d4f" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3-768x576.png" title="image-4-3"/>
    <!-- wp:generateblocks/text {"uniqueId":"99356476","tagName":"p","styles":{"fontSize":"0.9rem","position":"absolute","top":"1rem","left":"1rem","paddingTop":"2px","paddingBottom":"2px","paddingLeft":"10px","paddingRight":"10px","backgroundColor":"var(\u002d\u002daccent)","borderTopLeftRadius":"3px","borderTopRightRadius":"3px","borderBottomLeftRadius":"3px","borderBottomRightRadius":"3px","color":"var(\u002d\u002dbase-3)"},"css":".gb-text-99356476{background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-3);font-size:0.9rem;left:1rem;position:absolute;top:1rem;border-radius:3px;padding:2px 10px}"} -->
    <p class="gb-text gb-text-99356476">Program</p>
    <!-- wp:generateblocks/element {"uniqueId":"dac54f84","tagName":"div","styles":{"display":"flex","columnGap":"0.3em","rowGap":"0.3em","flexWrap":"wrap","marginBottom":"1rem"},"css":".gb-element-dac54f84{column-gap:0.3em;display:flex;flex-wrap:wrap;margin-bottom:1rem;row-gap:0.3em}"} -->
    <div class="gb-element-dac54f84"><!-- wp:generateblocks/element {"uniqueId":"c83d98ce","tagName":"div","styles":{"display":"flex"},"css":".gb-element-c83d98ce{display:flex}"} -->
    <div class="gb-element-c83d98ce"><!-- wp:generateblocks/text {"uniqueId":"a860baaa","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-a860baaa{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-a860baaa .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-a860baaa"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"3d45f216","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-3d45f216{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-3d45f216 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-3d45f216"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"56ee141a","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-56ee141a{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-56ee141a .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-56ee141a"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"f4ddf134","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-f4ddf134{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-f4ddf134 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-f4ddf134"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"ee9952ef","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0"},"css":".gb-text-ee9952ef{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0}.gb-text-ee9952ef .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-ee9952ef"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- /wp:generateblocks/element -->
    <!-- wp:generateblocks/text {"uniqueId":"f50908bf","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","marginBottom":"0px","fontWeight":"600"},"css":".gb-text-f50908bf{color:var(\u002d\u002daccent);font-weight:600;margin-bottom:0px}"} -->
    <p class="gb-text gb-text-f50908bf">(8 Reviews)</p>
    <!-- wp:generateblocks/text {"uniqueId":"bf8f0b34","tagName":"h3","styles":{"marginBottom":"0.2rem"},"css":".gb-text-bf8f0b34{margin-bottom:0.2rem}","globalClasses":["gbp-card__title"]} -->
    <h3 class="gb-text gbp-card__title gb-text-bf8f0b34">Course 3</h3>
    <!-- wp:generateblocks/text {"uniqueId":"58593f0f","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","fontWeight":"500","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"fontSize":"1rem","marginBottom":"0px"},"css":".gb-text-58593f0f{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:inline-flex;font-size:1rem;font-weight:500;margin-bottom:0px}.gb-text-58593f0f .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-58593f0f"><span class="gb-shape"><svg viewBox="0 0 685.7 645.8" xmlns="http://www.w3.org/2000/svg"><path style="fill:currentColor" d="M657.1 623.2c5.5 0 10.8-2.5 14.2-6.8 3.5-4.3 4.8-9.9 3.7-15.3l-11.6-54.7c6.6-6.4 10.7-15.2 10.7-25.1s-4.6-19.6-11.8-26V305.5L616 334.2v161.2c-7.2 6.4-11.8 15.6-11.8 26s4.1 18.8 10.7 25.1l-11.6 54.7c-1.1 5.4.2 11 3.7 15.3 3.5 4.3 8.7 6.8 14.2 6.8h35.7Zm15.7-428.6L371.5 8.2C362.7 2.8 352.7 0 342.8 0s-19.9 2.7-28.7 8.2L12.9 194.6c-8 5-12.9 13.8-12.9 23.2s4.9 18.3 12.9 23.2l301.2 186.5c8.8 5.4 18.7 8.2 28.7 8.2s19.9-2.7 28.7-8.2L672.7 241c8-5 12.9-13.8 12.9-23.2s-4.9-18.3-12.9-23.2ZM342.8 482c-18.8 0-37.1-5.2-53-15.1L114.1 358.1v187.3c0 55.4 102.5 100.3 228.8 100.3s228.8-44.9 228.8-100.3V358.1L396 466.9c-16 9.9-34.3 15.1-53.1 15.1Z"></path></svg></span><span class="gb-text">6 Lessons</span></p>
    <!-- wp:generateblocks/text {"uniqueId":"65d1cd39","tagName":"p","styles":[],"globalClasses":["gbp-card__text"]} -->
    <!-- wp:generateblocks/element {"uniqueId":"0ae4a6f7","tagName":"div","styles":{"display":"flex","flexDirection":"row","alignItems":"center","justifyContent":"flex-start","rowGap":"0.5rem","textAlign":"left","columnGap":"0.8em","marginBottom":"1em","paddingBottom":"0.8rem"},"css":".gb-element-0ae4a6f7{align-items:center;column-gap:0.8em;display:flex;flex-direction:row;justify-content:flex-start;margin-bottom:1em;padding-bottom:0.8rem;row-gap:0.5rem;text-align:left}","htmlAttributes":[],"metadata":{"name":"Meta Byline"}} -->
    <div class="gb-element-0ae4a6f7"><!-- wp:generateblocks/media {"uniqueId":"3bb7fd53","tagName":"img","styles":{"width":"50px","height":"50px","borderTopLeftRadius":"100%","borderTopRightRadius":"100%","borderBottomLeftRadius":"100%","borderBottomRightRadius":"100%","display":"block"},"css":".gb-media-3bb7fd53{display:block;height:50px;width:50px;border-radius:100%}","globalClasses":["gbp\u002d\u002dborder"],"htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/user-150x150.png","title":"user"},"mediaId":46293,"linkHtmlAttributes":[],"metadata":[]} -->
    <img class="gbp--border gb-media-3bb7fd53" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/user-150x150.png" title="user"/>
    <!-- /wp:generateblocks/media -->
    <!-- wp:generateblocks/text {"uniqueId":"9b1fbe33","tagName":"div","styles":[],"globalClasses":["gbp-card__meta-text"],"htmlAttributes":[],"metadata":[]} -->
    <!-- wp:generateblocks/element {"uniqueId":"26913129","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem"},"css":".gb-element-26913129{column-gap:1rem;display:flex;margin-top:2rem}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-26913129"><!-- wp:generateblocks/text {"uniqueId":"91581117","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-91581117{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-91581117:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-91581117:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-91581117 .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-91581117 span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dtertiary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--tertiary gb-text-91581117" href="#"><span class="gb-text">Discover course</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- /wp:generateblocks/element --></div>
    <!-- /wp:generateblocks/element --></section>
  • Great, thanks.
    The same goes for the archive (https://generatepress.com/site-library/) and the grid on the home page?
  • Do you mean Education’s archive?
    If so, you need to create a block element – loop template, set the location to blog and archives, then paste this code in:
    <!-- wp:generateblocks/element {"uniqueId":"6a8c98b7","tagName":"section","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <section class="gbp-section"><!-- wp:generateblocks/element {"uniqueId":"162fac59","tagName":"div","styles":{"maxWidth":"var(\u002d\u002dgb-container-width)"},"css":".gb-element-162fac59{max-width:var(\u002d\u002dgb-container-width)}","globalClasses":["gbp-section__inner"],"metadata":{"name":"Inner container max-width"}} -->
    <div class="gbp-section__inner gb-element-162fac59"><!-- wp:generateblocks/query {"uniqueId":"ace57213","tagName":"div","query":{"post_type":["post"],"posts_per_page":10},"inheritQuery":true} -->
    <div><!-- wp:generateblocks/looper {"uniqueId":"204eb07c","tagName":"div","styles":{"display":"grid","gridTemplateColumns":"repeat(3, minmax(0, 1fr))","@media (max-width:1024px)":{"gridTemplateColumns":"repeat(2, minmax(0, 1fr))"},"@media (max-width:767px)":{"gridTemplateColumns":"1fr"},"columnGap":"2rem","rowGap":"2rem","maxWidth":"var(\u002d\u002dgb-container-width)","marginLeft":"auto","marginRight":"auto"},"css":".gb-looper-204eb07c{column-gap:2rem;display:grid;grid-template-columns:repeat(3,minmax(0,1fr));margin-left:auto;margin-right:auto;max-width:var(\u002d\u002dgb-container-width);row-gap:2rem}@media (max-width:1024px){.gb-looper-204eb07c{grid-template-columns:repeat(2,minmax(0,1fr))}}@media (max-width:767px){.gb-looper-204eb07c{grid-template-columns:1fr}}"} -->
    <div class="gb-looper-204eb07c"><!-- wp:generateblocks/loop-item {"uniqueId":"3e92984e","tagName":"article","styles":{"boxShadow":"0px 5px 10px 6px rgba(68, 68, 87, 0.05)"},"css":".gb-loop-item-3e92984e{box-shadow:0px 5px 10px 6px rgba(68,68,87,0.05)}"} -->
    <article class="gb-loop-item gb-loop-item-3e92984e"><!-- wp:generateblocks/media {"uniqueId":"fdfa60a1","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px"},"css":".gb-media-fdfa60a1{border-top-left-radius:6px;border-top-right-radius:6px;display:block;height:250px;max-width:100%;object-fit:cover;width:100%}","htmlAttributes":{"src":"{{featured_image size:medium_large|key:url}}","alt":"Image placeholder"},"linkHtmlAttributes":{"href":"{{post_permalink}}"}} -->
    <a href="{{post_permalink}}"><img class="gb-media-fdfa60a1" src="{{featured_image size:medium_large|key:url}}" alt="Image placeholder"/></a>
    <!-- wp:generateblocks/element {"uniqueId":"d52aecc8","tagName":"div","styles":{"paddingTop":"2rem","paddingLeft":"2rem","paddingBottom":"2rem","paddingRight":"2rem"},"css":".gb-element-d52aecc8{padding:2rem}"} -->
    <div class="gb-element-d52aecc8"><!-- wp:generateblocks/text {"uniqueId":"ce207342","tagName":"h2","styles":{"fontSize":"clamp(1.375rem, 1.8vw + 0.7rem, 1.5em)"},"css":".gb-text-ce207342{font-size:clamp(1.375rem,1.8vw + 0.7rem,1.5em)}","globalClasses":["gbp-section__headline"]} -->
    <h2 class="gb-text gbp-section__headline gb-text-ce207342">{{post_title link:post}}</h2>
    <!-- wp:generateblocks/element {"uniqueId":"c3ed8265","tagName":"div","styles":{"display":"flex","columnGap":"2rem","rowGap":"2rem","flexWrap":"wrap","alignItems":"center","marginBottom":"1rem"},"css":".gb-element-c3ed8265{align-items:center;column-gap:2rem;display:flex;flex-wrap:wrap;margin-bottom:1rem;row-gap:2rem}"} -->
    <div class="gb-element-c3ed8265"><!-- wp:generateblocks/text {"uniqueId":"11b7f51e","tagName":"span","styles":{"color":"var(\u002d\u002dcontrast-3)","fontSize":"1rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"a:hover":{"color":"var(\u002d\u002daccent)"}},"css":".gb-text-11b7f51e{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;font-size:1rem}.gb-text-11b7f51e .gb-shape svg{width:1em;height:1em;fill:currentColor}.gb-text-11b7f51e a:hover{color:var(\u002d\u002daccent)}"} -->
    <span class="gb-text-11b7f51e"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 496 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M248 8C111 8 0 119 0 256s111 248 248 248 248-111 248-248S385 8 248 8zm0 96c48.6 0 88 39.4 88 88s-39.4 88-88 88-88-39.4-88-88 39.4-88 88-88zm0 344c-58.7 0-111.3-26.6-146.5-68.2 18.8-35.4 55.6-59.8 98.5-59.8 2.4 0 4.8.4 7.1 1.1 13 4.2 26.6 6.9 40.9 6.9 14.3 0 28-2.7 40.9-6.9 2.3-.7 4.7-1.1 7.1-1.1 42.9 0 79.7 24.4 98.5 59.8C359.3 421.4 306.7 448 248 448z"></path></svg></span><span class="gb-text">{{author_meta key:display_name|link:author_archive}}</span></span>
    <!-- wp:generateblocks/text {"uniqueId":"f73226c1","tagName":"span","styles":{"color":"var(\u002d\u002dcontrast-3)","fontSize":"1rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-f73226c1{align-items:center;color:var(\u002d\u002dcontrast-3);column-gap:0.5em;display:inline-flex;font-size:1rem}.gb-text-f73226c1 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <span class="gb-text-f73226c1"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 448 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M148 288h-40c-6.6 0-12-5.4-12-12v-40c0-6.6 5.4-12 12-12h40c6.6 0 12 5.4 12 12v40c0 6.6-5.4 12-12 12zm108-12v-40c0-6.6-5.4-12-12-12h-40c-6.6 0-12 5.4-12 12v40c0 6.6 5.4 12 12 12h40c6.6 0 12-5.4 12-12zm96 0v-40c0-6.6-5.4-12-12-12h-40c-6.6 0-12 5.4-12 12v40c0 6.6 5.4 12 12 12h40c6.6 0 12-5.4 12-12zm-96 96v-40c0-6.6-5.4-12-12-12h-40c-6.6 0-12 5.4-12 12v40c0 6.6 5.4 12 12 12h40c6.6 0 12-5.4 12-12zm-96 0v-40c0-6.6-5.4-12-12-12h-40c-6.6 0-12 5.4-12 12v40c0 6.6 5.4 12 12 12h40c6.6 0 12-5.4 12-12zm192 0v-40c0-6.6-5.4-12-12-12h-40c-6.6 0-12 5.4-12 12v40c0 6.6 5.4 12 12 12h40c6.6 0 12-5.4 12-12zm96-260v352c0 26.5-21.5 48-48 48H48c-26.5 0-48-21.5-48-48V112c0-26.5 21.5-48 48-48h48V12c0-6.6 5.4-12 12-12h40c6.6 0 12 5.4 12 12v52h128V12c0-6.6 5.4-12 12-12h40c6.6 0 12 5.4 12 12v52h48c26.5 0 48 21.5 48 48zm-48 346V160H48v298c0 3.3 2.7 6 6 6h340c3.3 0 6-2.7 6-6z"></path></svg></span><span class="gb-text">{{post_date}}</span></span>
    <!-- wp:generateblocks/text {"uniqueId":"36c256b2","tagName":"p","styles":{"color":"var(\u002d\u002dcontrast-3)","fontSize":"1rem","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-36c256b2{color:var(\u002d\u002dcontrast-3);column-gap:0.5em;font-size:1rem}.gb-text-36c256b2 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text gb-text-36c256b2">{{post_excerpt length:10}}</p>
    <!-- wp:generateblocks/text {"uniqueId":"4f881c3d","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-4f881c3d{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-4f881c3d:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-4f881c3d:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-4f881c3d .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-4f881c3d span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dtertiary"],"htmlAttributes":{"href":"{{post_permalink}}"},"iconLocation":"after"} -->
    <a class="gbp-button--tertiary gb-text-4f881c3d" href="{{post_permalink}}"><span class="gb-text">Read more</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- /wp:generateblocks/element --></article>
    <!-- /wp:generateblocks/loop-item --></div>
    <!-- /wp:generateblocks/looper -->
    <!-- wp:generateblocks/element {"uniqueId":"35cd0f37","tagName":"div","styles":{"display":"flex","justifyContent":"center","alignItems":"center","marginTop":"8rem","columnGap":"10px","rowGap":"10px"},"css":".gb-element-35cd0f37{align-items:center;column-gap:10px;display:flex;justify-content:center;margin-top:8rem;row-gap:10px}","className":"gb-query-loop-pagination"} -->
    <div class="gb-element-35cd0f37 gb-query-loop-pagination"><!-- wp:generateblocks/text {"uniqueId":"61cb3093","tagName":"a","styles":{"paddingTop":"1rem","paddingRight":"1rem","paddingBottom":"1rem","paddingLeft":"1rem","backgroundColor":"var(\u002d\u002dbase-2)","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","textDecoration":"none","lineHeight":"1","fontSize":"14px","borderTopLeftRadius":"3px","borderTopRightRadius":"3px","borderBottomLeftRadius":"3px","borderBottomRightRadius":"3px","\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dbase-3)","backgroundColor":"var(\u002d\u002daccent-2)"}},"css":".gb-text-61cb3093{background-color:var(\u002d\u002dbase-2);color:var(\u002d\u002dcontrast-3);display:inline-flex;font-size:14px;line-height:1;text-decoration:none;border-radius:3px;padding:1rem}.gb-text-61cb3093:is(:hover,:focus){color:var(\u002d\u002dbase-3);background-color:var(\u002d\u002daccent-2)}","htmlAttributes":{"href":"{{previous_posts_page_url}}"}} -->
    <a class="gb-text gb-text-61cb3093" href="{{previous_posts_page_url}}">Previous</a>
    <!-- wp:generateblocks/query-page-numbers {"uniqueId":"364d475b","tagName":"nav","styles":{"display":"flex","justifyContent":"center","alignItems":"center","columnGap":"5px","rowGap":"5px",".page-numbers":{"paddingTop":"1rem","paddingRight":"1rem","paddingBottom":"1rem","paddingLeft":"1rem","backgroundColor":"var(\u002d\u002dbase-2)","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","textDecoration":"none","lineHeight":"1","fontSize":"14px","borderTopLeftRadius":"3px","borderTopRightRadius":"3px","borderBottomLeftRadius":"3px","borderBottomRightRadius":"3px"},".page-numbers.dots":{"borderTopWidth":"0","borderRightWidth":"0","borderBottomWidth":"0","borderLeftWidth":"0"},".page-numbers.current":{"borderTopLeftRadius":"3px","borderTopRightRadius":"3px","borderBottomLeftRadius":"3px","borderBottomRightRadius":"3px","color":"var(\u002d\u002dbase-3)","backgroundColor":"var(\u002d\u002daccent)"},".page-numbers:is(:hover, :focus)":{"backgroundColor":"var(\u002d\u002daccent-2)","color":"var(\u002d\u002dbase-3)"}},"css":".gb-query-page-numbers-364d475b{align-items:center;column-gap:5px;display:flex;justify-content:center;row-gap:5px}.gb-query-page-numbers-364d475b .page-numbers{background-color:var(\u002d\u002dbase-2);color:var(\u002d\u002dcontrast-3);display:inline-flex;text-decoration:none;line-height:1;font-size:14px;border-radius:3px;padding:1rem}.gb-query-page-numbers-364d475b .page-numbers.current{color:var(\u002d\u002dbase-3);background-color:var(\u002d\u002daccent);border-radius:3px}.gb-query-page-numbers-364d475b .page-numbers.dots{border-top-width:0;border-right-width:0;border-bottom-width:0;border-left-width:0}.gb-query-page-numbers-364d475b .page-numbers:is(:hover,:focus){background-color:var(\u002d\u002daccent-2);color:var(\u002d\u002dbase-3)}"} -->
    <nav class="gb-query-page-numbers-364d475b"></nav>
    <!-- /wp:generateblocks/query-page-numbers -->
    <!-- wp:generateblocks/text {"uniqueId":"ff47e538","tagName":"a","styles":{"paddingTop":"1rem","paddingRight":"1rem","paddingBottom":"1rem","paddingLeft":"1rem","backgroundColor":"var(\u002d\u002dbase-2)","color":"var(\u002d\u002dcontrast-3)","display":"inline-flex","textDecoration":"none","lineHeight":"1","fontSize":"14px","borderTopLeftRadius":"3px","borderTopRightRadius":"3px","borderBottomLeftRadius":"3px","borderBottomRightRadius":"3px","\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dbase-3)","backgroundColor":"var(\u002d\u002daccent-2)"}},"css":".gb-text-ff47e538{background-color:var(\u002d\u002dbase-2);color:var(\u002d\u002dcontrast-3);display:inline-flex;font-size:14px;line-height:1;text-decoration:none;border-radius:3px;padding:1rem}.gb-text-ff47e538:is(:hover,:focus){color:var(\u002d\u002dbase-3);background-color:var(\u002d\u002daccent-2)}","htmlAttributes":{"href":"{{next_posts_page_url}}"}} -->
    <a class="gb-text gb-text-ff47e538" href="{{next_posts_page_url}}">Next</a>
    <!-- /wp:generateblocks/query --></div>
  • For the homepage grid,I’m not sure which one you are referring to, here’s the code for the entire homepage:
    <!-- wp:generateblocks/element {"uniqueId":"ef90b69c","tagName":"section","styles":{"backgroundColor":"var(\u002d\u002dbase-2)","backgroundImage":"linear-gradient(45deg, var(\u002d\u002dbase) 0%, var(\u002d\u002dbase-3) 100%)","backgroundSize":"cover","backgroundRepeat":"no-repeat","backgroundPosition":"center","backgroundBlendMode":"normal"},"css":".gb-element-ef90b69c{background-blend-mode:normal;background-color:var(\u002d\u002dbase-2);background-image:linear-gradient(45deg,var(\u002d\u002dbase) 0%,var(\u002d\u002dbase-3) 100%);background-position:center;background-repeat:no-repeat;background-size:cover}","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <section class="gbp-section gb-element-ef90b69c"><!-- wp:generateblocks/element {"uniqueId":"17b79652","tagName":"div","styles":{"marginLeft":"auto","marginRight":"auto","display":"grid","gridTemplateColumns":"repeat(2, minmax(0, 1fr))","columnGap":"5rem","@media (max-width:1024px)":{"display":"block"},"alignItems":"center"},"css":".gb-element-17b79652{align-items:center;column-gap:5rem;display:grid;grid-template-columns:repeat(2,minmax(0,1fr));margin-left:auto;margin-right:auto}@media (max-width:1024px){.gb-element-17b79652{display:block}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container max-width"}} -->
    <div class="gbp-section__inner gb-element-17b79652"><!-- wp:generateblocks/element {"uniqueId":"50fdeb35","tagName":"div","styles":{"marginBottom":"3rem"},"css":".gb-element-50fdeb35{margin-bottom:3rem}","metadata":{"name":"Content container"}} -->
    <div class="gb-element-50fdeb35"><!-- wp:generateblocks/text {"uniqueId":"d43820b0","tagName":"p","globalClasses":["gbp-section__tagline"]} -->
    <p class="gb-text gbp-section__tagline">Tagline</p>
    <!-- wp:generateblocks/text {"uniqueId":"6b7641af","tagName":"h1","globalClasses":["gbp-section__headline"]} -->
    <h1 class="gb-text gbp-section__headline">Headline stating how your courses impact the visitors learning</h1>
    <!-- wp:generateblocks/text {"uniqueId":"86f01f4a","tagName":"p","globalClasses":["gbp-section__text"]} -->
    <p class="gb-text gbp-section__text">Summarize how your courses can benefit the visitor and assure them that you are the right fit for them.</p>
    <!-- wp:generateblocks/element {"uniqueId":"6b724974","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem","rowGap":"1em","flexWrap":"wrap"},"css":".gb-element-6b724974{column-gap:1rem;display:flex;flex-wrap:wrap;margin-top:2rem;row-gap:1em}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-6b724974"><!-- wp:generateblocks/text {"uniqueId":"744189f7","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-744189f7{align-items:center;column-gap:0.5em;display:inline-flex}.gb-text-744189f7 .gb-shape svg{width:1em;height:1em;fill:currentColor}","globalClasses":["gbp-button\u002d\u002dprimary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--primary gb-text-744189f7" href="#"><span class="gb-text">Sign up now</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- wp:generateblocks/text {"uniqueId":"91bf37f3","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dbase-3)"},"\u0026:is(:hover, :focus) .gb-shape svg":{"color":"var(\u002d\u002dbase-3)"},".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-91bf37f3:is(:hover,:focus){color:var(\u002d\u002dbase-3)}.gb-text-91bf37f3:is(:hover,:focus) .gb-shape svg{color:var(\u002d\u002dbase-3)}.gb-text-91bf37f3 .gb-shape svg{width:1em;height:1em;fill:currentColor}","globalClasses":["gbp-button\u002d\u002dsecondary"],"htmlAttributes":{"href":"https://sites.generatepress.com/education/courses/"},"iconLocation":"after"} -->
    <a class="gb-text gbp-button--secondary gb-text-91bf37f3" href="https://sites.generatepress.com/education/courses/">Explore courses</a>
    <!-- wp:generateblocks/element {"uniqueId":"b515da73","tagName":"div","styles":{"position":"relative"},"css":".gb-element-b515da73{position:relative}","metadata":{"name":"Content container"}} -->
    <div class="gb-element-b515da73"><!-- wp:generateblocks/media {"uniqueId":"42743c18","tagName":"img","styles":{"height":"auto","maxWidth":"100%","objectFit":"cover","width":"auto","@media (max-width:1024px)":{"width":"100%"},"display":"block","zIndex":"1","position":"relative"},"css":".gb-media-42743c18{display:block;height:auto;max-width:100%;object-fit:cover;position:relative;width:auto;z-index:1}@media (max-width:1024px){.gb-media-42743c18{width:100%}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-1-1-768x768.png","title":"image-1-1","alt":"Image placeholder"},"mediaId":46291} -->
    <img class="gb-media-42743c18" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-1-1-768x768.png" title="image-1-1" alt="Image placeholder"/>
    <!-- wp:generateblocks/media {"uniqueId":"9a8ff3ec","tagName":"img","styles":{"position":"absolute","left":"-100px","width":"25%","top":"0px"},"css":".gb-media-9a8ff3ec{left:-100px;position:absolute;top:0px;width:25%}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/line-1.svg","title":"line-1","alt":"SVG shape"},"mediaId":47795} -->
    <img class="gb-media-9a8ff3ec" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/line-1.svg" title="line-1" alt="SVG shape"/>
    <!-- wp:generateblocks/media {"uniqueId":"a0776f46","tagName":"img","styles":{"position":"absolute","width":"25%","right":"100px","bottom":"-20px","opacity":"0.7"},"css":".gb-media-a0776f46{bottom:-20px;opacity:0.7;position:absolute;right:100px;width:25%}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/svg-shape-12.svg","title":"svg-shape-12","alt":"SVG shape"},"mediaId":47788} -->
    <img class="gb-media-a0776f46" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/svg-shape-12.svg" title="svg-shape-12" alt="SVG shape"/>
    <!-- wp:generateblocks/element {"uniqueId":"af7048d5","tagName":"div","styles":{"position":"relative","zIndex":"1"},"css":".gb-element-af7048d5{position:relative;z-index:1}"} -->
    <div class="gb-element-af7048d5"><!-- wp:generateblocks/element {"uniqueId":"e7bf95e1","tagName":"div","styles":{"flexDirection":"row","columnGap":".75rem","alignItems":"center","@media (max-width:767px)":{"flexDirection":"column","alignItems":"center","rowGap":".75rem","width":"100%","borderTopLeftRadius":"0px","borderTopRightRadius":"0px","borderBottomRightRadius":"0px","borderBottomLeftRadius":"0px","marginTop":"0px"},"paddingTop":"1.25rem","paddingLeft":"2rem","paddingRight":"2rem","paddingBottom":"1.25rem","justifyContent":"center","borderTopLeftRadius":".25rem","borderTopRightRadius":".25rem","borderBottomLeftRadius":".25rem","borderBottomRightRadius":".25rem","backgroundColor":"var(\u002d\u002dbase-3)","marginTop":"-3rem","width":"max-content"},"css":".gb-element-e7bf95e1{align-items:center;background-color:var(\u002d\u002dbase-3);column-gap:.75rem;flex-direction:row;justify-content:center;margin-top:-3rem;width:max-content;border-radius:.25rem;padding:1.25rem 2rem}@media (max-width:767px){.gb-element-e7bf95e1{align-items:center;flex-direction:column;margin-top:0px;row-gap:.75rem;width:100%;border-radius:0px}}"} -->
    <div class="gb-element-e7bf95e1"><!-- wp:generateblocks/text {"uniqueId":"71cc1ce5","tagName":"p","styles":{"fontWeight":"700","marginBottom":"10px"},"css":".gb-text-71cc1ce5{font-weight:700;margin-bottom:10px}"} -->
    <p class="gb-text gb-text-71cc1ce5">Name Surname</p>
    <!-- wp:generateblocks/element {"uniqueId":"7271bed3","tagName":"div","styles":{"display":"flex","columnGap":"0.3em","rowGap":"0.3em","flexWrap":"wrap"},"css":".gb-element-7271bed3{column-gap:0.3em;display:flex;flex-wrap:wrap;row-gap:0.3em}"} -->
    <div class="gb-element-7271bed3"><!-- wp:generateblocks/element {"uniqueId":"edfc461a","tagName":"div","styles":{"display":"flex"},"css":".gb-element-edfc461a{display:flex}"} -->
    <div class="gb-element-edfc461a"><!-- wp:generateblocks/text {"uniqueId":"7dfc69a8","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-7dfc69a8{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-7dfc69a8 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-7dfc69a8"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"b1f517c9","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-b1f517c9{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-b1f517c9 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-b1f517c9"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"b51375d6","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-b51375d6{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-b51375d6 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-b51375d6"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"23730c7a","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-23730c7a{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-23730c7a .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-23730c7a"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"c128acf1","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0"},"css":".gb-text-c128acf1{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0}.gb-text-c128acf1 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-c128acf1"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"18f6f58d","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","marginBottom":"0px","fontWeight":"600"},"css":".gb-text-18f6f58d{color:var(\u002d\u002daccent);font-weight:600;margin-bottom:0px}"} -->
    <p class="gb-text gb-text-18f6f58d">(Verified student)</p>
    <!-- wp:generateblocks/media {"uniqueId":"632f4443","tagName":"img","styles":{"height":"3.6rem","maxWidth":"100%","objectFit":"cover","width":"3.6rem","borderTopLeftRadius":"100%","borderTopRightRadius":"100%","borderBottomLeftRadius":"100%","borderBottomRightRadius":"100%","position":"absolute","top":"-27px","left":"-27px"},"css":".gb-media-632f4443{height:3.6rem;left:-27px;max-width:100%;object-fit:cover;position:absolute;top:-27px;width:3.6rem;border-radius:100%}","globalClasses":["gbp\u002d\u002dborder"],"htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/user-150x150.png","title":"user"},"mediaId":46293} -->
    <img class="gbp--border gb-media-632f4443" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/user-150x150.png" title="user"/>
    <!-- /wp:generateblocks/media --></div>
    <!-- wp:generateblocks/element {"uniqueId":"3b5dde91","tagName":"section","styles":[],"globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <section class="gbp-section"><!-- wp:generateblocks/element {"uniqueId":"5706cd50","tagName":"div","styles":{"@media (max-width:1024px)":{"marginBottom":"4rem"},"marginBottom":"5rem"},"css":".gb-element-5706cd50{margin-bottom:5rem}@media (max-width:1024px){.gb-element-5706cd50{margin-bottom:4rem}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container with max-width"}} -->
    <div class="gbp-section__inner gb-element-5706cd50"><!-- wp:generateblocks/element {"uniqueId":"acae8e5a","tagName":"div","styles":{"@media (max-width:1024px)":{"maxWidth":"100%"},"maxWidth":"66%","marginLeft":"auto","marginRight":"auto","textAlign":"center"},"css":".gb-element-acae8e5a{margin-left:auto;margin-right:auto;max-width:66%;text-align:center}@media (max-width:1024px){.gb-element-acae8e5a{max-width:100%}}","metadata":{"name":"Content container"}} -->
    <div class="gb-element-acae8e5a"><!-- wp:generateblocks/text {"uniqueId":"caba7a8f","tagName":"p","globalClasses":["gbp-section__tagline"]} -->
    <!-- wp:generateblocks/text {"uniqueId":"50de6661","tagName":"h2","styles":{"textTransform":"capitalize"},"css":".gb-text-50de6661{text-transform:capitalize}","globalClasses":["gbp-section__headline"]} -->
    <h2 class="gb-text gbp-section__headline gb-text-50de6661">Our courses</h2>
    <!-- wp:generateblocks/text {"uniqueId":"2dd4ab20","tagName":"p","globalClasses":["gbp-section__text"]} -->
    <p class="gb-text gbp-section__text">Lorem ipsum dolor sit amet, consectetur adipiscing elit. Suspendisse varius enim in eros elementum tristique. Duis cursus, mi quis viverra ornare, eros dolor interdum nulla, ut commodo diam libero vitae erat.</p>
    <!-- wp:generateblocks/element {"uniqueId":"073910d2","tagName":"div","styles":{"marginLeft":"auto","marginRight":"auto","display":"grid","gridTemplateColumns":"repeat(3, minmax(0, 1fr))","columnGap":"2.25rem","rowGap":"3rem","@media (max-width:1024px)":{"gridTemplateColumns":"repeat(2, minmax(0, 1fr))"},"@media (max-width:767px)":{"gridTemplateColumns":"1fr"}},"css":".gb-element-073910d2{column-gap:2.25rem;display:grid;grid-template-columns:repeat(3,minmax(0,1fr));margin-left:auto;margin-right:auto;row-gap:3rem}@media (max-width:1024px){.gb-element-073910d2{grid-template-columns:repeat(2,minmax(0,1fr))}}@media (max-width:767px){.gb-element-073910d2{grid-template-columns:1fr}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container max-width"}} -->
    <div class="gbp-section__inner gb-element-073910d2"><!-- wp:generateblocks/element {"uniqueId":"18d3861f","tagName":"div","styles":[],"globalClasses":["gbp-card"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-card"><!-- wp:generateblocks/media {"uniqueId":"0955a309","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","marginBottom":"1.4rem","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","@media (max-width:767px)":{"height":"auto"}},"css":".gb-media-0955a309{display:block;height:250px;margin-bottom:1.4rem;max-width:100%;object-fit:cover;width:100%;border-radius:6px}@media (max-width:767px){.gb-media-0955a309{height:auto}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png","title":"image-4-3","alt":"Image placeholder"},"mediaId":46292} -->
    <img class="gb-media-0955a309" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png" title="image-4-3" alt="Image placeholder"/>
    <!-- wp:generateblocks/text {"uniqueId":"fed82483","tagName":"h3","globalClasses":["gbp-card__title"]} -->
    <h3 class="gb-text gbp-card__title">Course 1</h3>
    <!-- wp:generateblocks/text {"uniqueId":"ac1d9002","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","fontWeight":"500","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"fontSize":"1.1rem"},"css":".gb-text-ac1d9002{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:inline-flex;font-size:1.1rem;font-weight:500}.gb-text-ac1d9002 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-ac1d9002"><span class="gb-shape"><svg viewBox="0 0 685.7 645.8" xmlns="http://www.w3.org/2000/svg"><path style="fill:currentColor" d="M657.1 623.2c5.5 0 10.8-2.5 14.2-6.8 3.5-4.3 4.8-9.9 3.7-15.3l-11.6-54.7c6.6-6.4 10.7-15.2 10.7-25.1s-4.6-19.6-11.8-26V305.5L616 334.2v161.2c-7.2 6.4-11.8 15.6-11.8 26s4.1 18.8 10.7 25.1l-11.6 54.7c-1.1 5.4.2 11 3.7 15.3 3.5 4.3 8.7 6.8 14.2 6.8h35.7Zm15.7-428.6L371.5 8.2C362.7 2.8 352.7 0 342.8 0s-19.9 2.7-28.7 8.2L12.9 194.6c-8 5-12.9 13.8-12.9 23.2s4.9 18.3 12.9 23.2l301.2 186.5c8.8 5.4 18.7 8.2 28.7 8.2s19.9-2.7 28.7-8.2L672.7 241c8-5 12.9-13.8 12.9-23.2s-4.9-18.3-12.9-23.2ZM342.8 482c-18.8 0-37.1-5.2-53-15.1L114.1 358.1v187.3c0 55.4 102.5 100.3 228.8 100.3s228.8-44.9 228.8-100.3V358.1L396 466.9c-16 9.9-34.3 15.1-53.1 15.1Z"></path></svg></span><span class="gb-text">4 Lessons</span></p>
    <!-- wp:generateblocks/element {"uniqueId":"514f6c98","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem"},"css":".gb-element-514f6c98{column-gap:1rem;display:flex;margin-top:2rem}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-514f6c98"><!-- wp:generateblocks/text {"uniqueId":"94a2520b","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-94a2520b{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-94a2520b:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-94a2520b:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-94a2520b .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-94a2520b span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dprimary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--primary gb-text-94a2520b" href="#"><span class="gb-text">Read more</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- wp:generateblocks/element {"uniqueId":"844ba167","tagName":"div","styles":[],"globalClasses":["gbp-card"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-card"><!-- wp:generateblocks/media {"uniqueId":"40d639d8","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","marginBottom":"1.4rem","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","@media (max-width:767px)":{"height":"auto"}},"css":".gb-media-40d639d8{display:block;height:250px;margin-bottom:1.4rem;max-width:100%;object-fit:cover;width:100%;border-radius:6px}@media (max-width:767px){.gb-media-40d639d8{height:auto}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png","title":"image-4-3","alt":"Image placeholder"},"mediaId":46292} -->
    <img class="gb-media-40d639d8" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png" title="image-4-3" alt="Image placeholder"/>
    <!-- wp:generateblocks/text {"uniqueId":"75a41512","tagName":"h3","globalClasses":["gbp-card__title"]} -->
    <h3 class="gb-text gbp-card__title">Course 2</h3>
    <!-- wp:generateblocks/text {"uniqueId":"f793d060","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","fontWeight":"500","fontSize":"1.1rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-f793d060{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:inline-flex;font-size:1.1rem;font-weight:500}.gb-text-f793d060 .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-f793d060"><span class="gb-shape"><svg viewBox="0 0 685.7 645.8" xmlns="http://www.w3.org/2000/svg"><path style="fill:currentColor" d="M657.1 623.2c5.5 0 10.8-2.5 14.2-6.8 3.5-4.3 4.8-9.9 3.7-15.3l-11.6-54.7c6.6-6.4 10.7-15.2 10.7-25.1s-4.6-19.6-11.8-26V305.5L616 334.2v161.2c-7.2 6.4-11.8 15.6-11.8 26s4.1 18.8 10.7 25.1l-11.6 54.7c-1.1 5.4.2 11 3.7 15.3 3.5 4.3 8.7 6.8 14.2 6.8h35.7Zm15.7-428.6L371.5 8.2C362.7 2.8 352.7 0 342.8 0s-19.9 2.7-28.7 8.2L12.9 194.6c-8 5-12.9 13.8-12.9 23.2s4.9 18.3 12.9 23.2l301.2 186.5c8.8 5.4 18.7 8.2 28.7 8.2s19.9-2.7 28.7-8.2L672.7 241c8-5 12.9-13.8 12.9-23.2s-4.9-18.3-12.9-23.2ZM342.8 482c-18.8 0-37.1-5.2-53-15.1L114.1 358.1v187.3c0 55.4 102.5 100.3 228.8 100.3s228.8-44.9 228.8-100.3V358.1L396 466.9c-16 9.9-34.3 15.1-53.1 15.1Z"></path></svg></span><span class="gb-text">12 Lessons</span></p>
    <!-- wp:generateblocks/element {"uniqueId":"8c9c9c82","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem"},"css":".gb-element-8c9c9c82{column-gap:1rem;display:flex;margin-top:2rem}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-8c9c9c82"><!-- wp:generateblocks/text {"uniqueId":"21d6f016","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-21d6f016{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-21d6f016:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-21d6f016:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-21d6f016 .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-21d6f016 span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dprimary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--primary gb-text-21d6f016" href="#"><span class="gb-text">Read more</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- wp:generateblocks/element {"uniqueId":"c2e7b70b","tagName":"div","styles":[],"globalClasses":["gbp-card"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-card"><!-- wp:generateblocks/media {"uniqueId":"6d8dc930","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","marginBottom":"1.4rem","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","@media (max-width:767px)":{"height":"auto"}},"css":".gb-media-6d8dc930{display:block;height:250px;margin-bottom:1.4rem;max-width:100%;object-fit:cover;width:100%;border-radius:6px}@media (max-width:767px){.gb-media-6d8dc930{height:auto}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png","title":"image-4-3","alt":"Image placeholder"},"mediaId":46292} -->
    <img class="gb-media-6d8dc930" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png" title="image-4-3" alt="Image placeholder"/>
    <!-- wp:generateblocks/text {"uniqueId":"259f89d5","tagName":"h3","globalClasses":["gbp-card__title"]} -->
    <h3 class="gb-text gbp-card__title">Course 3</h3>
    <!-- wp:generateblocks/text {"uniqueId":"2e83d1df","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","fontWeight":"500","fontSize":"1.1rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-2e83d1df{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:inline-flex;font-size:1.1rem;font-weight:500}.gb-text-2e83d1df .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-2e83d1df"><span class="gb-shape"><svg viewBox="0 0 685.7 645.8" xmlns="http://www.w3.org/2000/svg"><path style="fill:currentColor" d="M657.1 623.2c5.5 0 10.8-2.5 14.2-6.8 3.5-4.3 4.8-9.9 3.7-15.3l-11.6-54.7c6.6-6.4 10.7-15.2 10.7-25.1s-4.6-19.6-11.8-26V305.5L616 334.2v161.2c-7.2 6.4-11.8 15.6-11.8 26s4.1 18.8 10.7 25.1l-11.6 54.7c-1.1 5.4.2 11 3.7 15.3 3.5 4.3 8.7 6.8 14.2 6.8h35.7Zm15.7-428.6L371.5 8.2C362.7 2.8 352.7 0 342.8 0s-19.9 2.7-28.7 8.2L12.9 194.6c-8 5-12.9 13.8-12.9 23.2s4.9 18.3 12.9 23.2l301.2 186.5c8.8 5.4 18.7 8.2 28.7 8.2s19.9-2.7 28.7-8.2L672.7 241c8-5 12.9-13.8 12.9-23.2s-4.9-18.3-12.9-23.2ZM342.8 482c-18.8 0-37.1-5.2-53-15.1L114.1 358.1v187.3c0 55.4 102.5 100.3 228.8 100.3s228.8-44.9 228.8-100.3V358.1L396 466.9c-16 9.9-34.3 15.1-53.1 15.1Z"></path></svg></span><span class="gb-text">6 Lessons</span></p>
    <!-- /wp:generateblocks/text -->
    <!-- wp:generateblocks/element {"uniqueId":"42aa8cdd","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem"},"css":".gb-element-42aa8cdd{column-gap:1rem;display:flex;margin-top:2rem}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-42aa8cdd"><!-- wp:generateblocks/text {"uniqueId":"527ec608","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-527ec608{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-527ec608:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-527ec608:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-527ec608 .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-527ec608 span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dprimary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--primary gb-text-527ec608" href="#"><span class="gb-text">Read more</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- /wp:generateblocks/text --></div>
    <!-- wp:generateblocks/element {"uniqueId":"9a1e2e25","tagName":"div","styles":[],"globalClasses":["gbp-card"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-card"><!-- wp:generateblocks/media {"uniqueId":"1b5c2f3d","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","marginBottom":"1.4rem","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","@media (max-width:767px)":{"height":"auto"}},"css":".gb-media-1b5c2f3d{display:block;height:250px;margin-bottom:1.4rem;max-width:100%;object-fit:cover;width:100%;border-radius:6px}@media (max-width:767px){.gb-media-1b5c2f3d{height:auto}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png","title":"image-4-3","alt":"Image placeholder"},"mediaId":46292} -->
    <img class="gb-media-1b5c2f3d" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png" title="image-4-3" alt="Image placeholder"/>
    <!-- wp:generateblocks/text {"uniqueId":"1dcf30ac","tagName":"h3","globalClasses":["gbp-card__title"]} -->
    <h3 class="gb-text gbp-card__title">Course 4</h3>
    <!-- wp:generateblocks/text {"uniqueId":"253eee5b","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","fontWeight":"500","fontSize":"1.1rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-253eee5b{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:inline-flex;font-size:1.1rem;font-weight:500}.gb-text-253eee5b .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-253eee5b"><span class="gb-shape"><svg viewBox="0 0 685.7 645.8" xmlns="http://www.w3.org/2000/svg"><path style="fill:currentColor" d="M657.1 623.2c5.5 0 10.8-2.5 14.2-6.8 3.5-4.3 4.8-9.9 3.7-15.3l-11.6-54.7c6.6-6.4 10.7-15.2 10.7-25.1s-4.6-19.6-11.8-26V305.5L616 334.2v161.2c-7.2 6.4-11.8 15.6-11.8 26s4.1 18.8 10.7 25.1l-11.6 54.7c-1.1 5.4.2 11 3.7 15.3 3.5 4.3 8.7 6.8 14.2 6.8h35.7Zm15.7-428.6L371.5 8.2C362.7 2.8 352.7 0 342.8 0s-19.9 2.7-28.7 8.2L12.9 194.6c-8 5-12.9 13.8-12.9 23.2s4.9 18.3 12.9 23.2l301.2 186.5c8.8 5.4 18.7 8.2 28.7 8.2s19.9-2.7 28.7-8.2L672.7 241c8-5 12.9-13.8 12.9-23.2s-4.9-18.3-12.9-23.2ZM342.8 482c-18.8 0-37.1-5.2-53-15.1L114.1 358.1v187.3c0 55.4 102.5 100.3 228.8 100.3s228.8-44.9 228.8-100.3V358.1L396 466.9c-16 9.9-34.3 15.1-53.1 15.1Z"></path></svg></span><span class="gb-text">12 Lessons</span></p>
    <!-- wp:generateblocks/element {"uniqueId":"bbef74ef","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem"},"css":".gb-element-bbef74ef{column-gap:1rem;display:flex;margin-top:2rem}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-bbef74ef"><!-- wp:generateblocks/text {"uniqueId":"9d360ec7","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-9d360ec7{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-9d360ec7:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-9d360ec7:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-9d360ec7 .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-9d360ec7 span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dprimary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--primary gb-text-9d360ec7" href="#"><span class="gb-text">Read more</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- wp:generateblocks/element {"uniqueId":"7df93228","tagName":"div","styles":[],"globalClasses":["gbp-card"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-card"><!-- wp:generateblocks/media {"uniqueId":"6d762813","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","marginBottom":"1.4rem","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","@media (max-width:767px)":{"height":"auto"}},"css":".gb-media-6d762813{display:block;height:250px;margin-bottom:1.4rem;max-width:100%;object-fit:cover;width:100%;border-radius:6px}@media (max-width:767px){.gb-media-6d762813{height:auto}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png","title":"image-4-3","alt":"Image placeholder"},"mediaId":46292} -->
    <img class="gb-media-6d762813" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png" title="image-4-3" alt="Image placeholder"/>
    <!-- wp:generateblocks/text {"uniqueId":"9146ba2a","tagName":"h3","globalClasses":["gbp-card__title"]} -->
    <h3 class="gb-text gbp-card__title">Course 5</h3>
    <!-- wp:generateblocks/text {"uniqueId":"e493ad0a","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","fontWeight":"500","fontSize":"1.1rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-e493ad0a{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:inline-flex;font-size:1.1rem;font-weight:500}.gb-text-e493ad0a .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-e493ad0a"><span class="gb-shape"><svg viewBox="0 0 685.7 645.8" xmlns="http://www.w3.org/2000/svg"><path style="fill:currentColor" d="M657.1 623.2c5.5 0 10.8-2.5 14.2-6.8 3.5-4.3 4.8-9.9 3.7-15.3l-11.6-54.7c6.6-6.4 10.7-15.2 10.7-25.1s-4.6-19.6-11.8-26V305.5L616 334.2v161.2c-7.2 6.4-11.8 15.6-11.8 26s4.1 18.8 10.7 25.1l-11.6 54.7c-1.1 5.4.2 11 3.7 15.3 3.5 4.3 8.7 6.8 14.2 6.8h35.7Zm15.7-428.6L371.5 8.2C362.7 2.8 352.7 0 342.8 0s-19.9 2.7-28.7 8.2L12.9 194.6c-8 5-12.9 13.8-12.9 23.2s4.9 18.3 12.9 23.2l301.2 186.5c8.8 5.4 18.7 8.2 28.7 8.2s19.9-2.7 28.7-8.2L672.7 241c8-5 12.9-13.8 12.9-23.2s-4.9-18.3-12.9-23.2ZM342.8 482c-18.8 0-37.1-5.2-53-15.1L114.1 358.1v187.3c0 55.4 102.5 100.3 228.8 100.3s228.8-44.9 228.8-100.3V358.1L396 466.9c-16 9.9-34.3 15.1-53.1 15.1Z"></path></svg></span><span class="gb-text">8 Lessons</span></p>
    <!-- wp:generateblocks/element {"uniqueId":"277cf045","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem"},"css":".gb-element-277cf045{column-gap:1rem;display:flex;margin-top:2rem}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-277cf045"><!-- wp:generateblocks/text {"uniqueId":"7282d60b","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-7282d60b{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-7282d60b:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-7282d60b:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-7282d60b .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-7282d60b span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dprimary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--primary gb-text-7282d60b" href="#"><span class="gb-text">Read more</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- wp:generateblocks/element {"uniqueId":"ce7d50e2","tagName":"div","styles":[],"globalClasses":["gbp-card"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-card"><!-- wp:generateblocks/media {"uniqueId":"48b79f1e","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","marginBottom":"1.4rem","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","@media (max-width:767px)":{"height":"auto"}},"css":".gb-media-48b79f1e{display:block;height:250px;margin-bottom:1.4rem;max-width:100%;object-fit:cover;width:100%;border-radius:6px}@media (max-width:767px){.gb-media-48b79f1e{height:auto}}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png","title":"image-4-3","alt":"Image placeholder"},"mediaId":46292} -->
    <img class="gb-media-48b79f1e" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png" title="image-4-3" alt="Image placeholder"/>
    <!-- wp:generateblocks/text {"uniqueId":"d7de0dce","tagName":"h3","globalClasses":["gbp-card__title"]} -->
    <h3 class="gb-text gbp-card__title">Course 6</h3>
    <!-- wp:generateblocks/text {"uniqueId":"645963df","tagName":"p","styles":{"color":"var(\u002d\u002daccent)","fontWeight":"500","fontSize":"1.1rem","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"}},"css":".gb-text-645963df{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:inline-flex;font-size:1.1rem;font-weight:500}.gb-text-645963df .gb-shape svg{width:1em;height:1em;fill:currentColor}"} -->
    <p class="gb-text-645963df"><span class="gb-shape"><svg viewBox="0 0 685.7 645.8" xmlns="http://www.w3.org/2000/svg"><path style="fill:currentColor" d="M657.1 623.2c5.5 0 10.8-2.5 14.2-6.8 3.5-4.3 4.8-9.9 3.7-15.3l-11.6-54.7c6.6-6.4 10.7-15.2 10.7-25.1s-4.6-19.6-11.8-26V305.5L616 334.2v161.2c-7.2 6.4-11.8 15.6-11.8 26s4.1 18.8 10.7 25.1l-11.6 54.7c-1.1 5.4.2 11 3.7 15.3 3.5 4.3 8.7 6.8 14.2 6.8h35.7Zm15.7-428.6L371.5 8.2C362.7 2.8 352.7 0 342.8 0s-19.9 2.7-28.7 8.2L12.9 194.6c-8 5-12.9 13.8-12.9 23.2s4.9 18.3 12.9 23.2l301.2 186.5c8.8 5.4 18.7 8.2 28.7 8.2s19.9-2.7 28.7-8.2L672.7 241c8-5 12.9-13.8 12.9-23.2s-4.9-18.3-12.9-23.2ZM342.8 482c-18.8 0-37.1-5.2-53-15.1L114.1 358.1v187.3c0 55.4 102.5 100.3 228.8 100.3s228.8-44.9 228.8-100.3V358.1L396 466.9c-16 9.9-34.3 15.1-53.1 15.1Z"></path></svg></span><span class="gb-text">10 Lessons</span></p>
    <!-- wp:generateblocks/element {"uniqueId":"744c5b94","tagName":"div","styles":{"marginTop":"2rem","display":"flex","columnGap":"1rem"},"css":".gb-element-744c5b94{column-gap:1rem;display:flex;margin-top:2rem}","metadata":{"name":"Button container"}} -->
    <div class="gb-element-744c5b94"><!-- wp:generateblocks/text {"uniqueId":"8532354e","tagName":"a","styles":{"textTransform":"capitalize","display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","opacity":"0","transform":"translate3d(-20px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"opacity":"1","transition":"all 0.5s ease 0s","transform":"translate3d(10px, 0px, 0px)"},"span:first-of-type":{"transform":"translate3d(10px, 0px, 0px)","transition":"all 0.5s ease 0s"},"\u0026:hover span:first-of-type":{"transform":"translate3d(-10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-8532354e{align-items:center;column-gap:0.5em;display:inline-flex;text-transform:capitalize}.gb-text-8532354e:hover span:first-of-type{transform:translate3d(-10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-8532354e:is(:hover,:focus) .gb-shape svg{opacity:1;transition:all 0.5s ease 0s;transform:translate3d(10px,0px,0px)}.gb-text-8532354e .gb-shape svg{width:1em;height:1em;fill:currentColor;opacity:0;transform:translate3d(-20px,0px,0px);transition:all 0.5s ease 0s}.gb-text-8532354e span:first-of-type{transform:translate3d(10px,0px,0px);transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dprimary"],"htmlAttributes":{"href":"#"},"iconLocation":"after"} -->
    <a class="gbp-button--primary gb-text-8532354e" href="#"><span class="gb-text">Read more</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- wp:generateblocks/element {"uniqueId":"78cc4287","tagName":"section","styles":{"backgroundImage":"linear-gradient(to left, rgba(16, 16, 20, 0.76) 0%, rgba(16, 16, 20, 0.76) 100%),url(https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png)","backgroundSize":"cover,cover","backgroundRepeat":"no-repeat,no-repeat","backgroundPosition":"center,center","backgroundBlendMode":"normal,normal"},"css":".gb-element-78cc4287{background-blend-mode:normal,normal;background:linear-gradient(to left,rgba(16,16,20,0.76) 0%,rgba(16,16,20,0.76) 100%),url(https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-4-3.png) center /cover no-repeat}","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <section class="gbp-section gb-element-78cc4287"><!-- wp:generateblocks/element {"uniqueId":"fdb9e807","tagName":"div","styles":{"marginLeft":"auto","marginRight":"auto","display":"grid","gridTemplateColumns":"repeat(2, minmax(0, 1fr))","columnGap":"2rem","@media (max-width:1024px)":{"gridTemplateColumns":"1fr","marginLeft":"auto","marginRight":"auto"},"paddingTop":"2rem","paddingLeft":"2rem","paddingBottom":"2rem","paddingRight":"2rem","alignItems":"center","rowGap":"2rem"},"css":".gb-element-fdb9e807{align-items:center;column-gap:2rem;display:grid;grid-template-columns:repeat(2,minmax(0,1fr));margin-left:auto;margin-right:auto;row-gap:2rem;padding:2rem}@media (max-width:1024px){.gb-element-fdb9e807{grid-template-columns:1fr;margin-left:auto;margin-right:auto}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container max-width"}} -->
    <div class="gbp-section__inner gb-element-fdb9e807"><!-- wp:generateblocks/element {"uniqueId":"3febce43","tagName":"div","metadata":{"name":"Content container"}} -->
    <div><!-- wp:generateblocks/text {"uniqueId":"9b7d15d3","tagName":"p","globalClasses":["gbp-section__tagline"]} -->
    <!-- wp:generateblocks/text {"uniqueId":"44522646","tagName":"h2","styles":{"fontWeight":"700","marginBottom":"2rem","color":"var(\u002d\u002dbase-3)"},"css":".gb-text-44522646{color:var(\u002d\u002dbase-3);font-weight:700;margin-bottom:2rem}"} -->
    <h2 class="gb-text gb-text-44522646">A variety of courses to choose from</h2>
    <!-- wp:generateblocks/text {"uniqueId":"692bf4a1","tagName":"p","styles":{"marginBottom":"0px","color":"var(\u002d\u002dbase-3)"},"css":".gb-text-692bf4a1{color:var(\u002d\u002dbase-3);margin-bottom:0px}","globalClasses":["gbp-section__text"]} -->
    <p class="gb-text gbp-section__text gb-text-692bf4a1">Lorem ipsum dolor sit amet, consectetur adipiscing elit. Suspendisse varius enim in eros elementum tristique.</p>
    <!-- wp:generateblocks/element {"uniqueId":"e26fe77f","tagName":"div","metadata":{"name":"Content container"}} -->
    <div><!-- wp:generateblocks/element {"uniqueId":"07676c9a","tagName":"div","styles":{"paddingTop":"2rem","paddingLeft":"2rem","paddingBottom":"2rem","paddingRight":"2rem","backgroundColor":"var(\u002d\u002dbase-2)","borderTopLeftRadius":".25rem","borderTopRightRadius":".25rem","borderBottomLeftRadius":".25rem","borderBottomRightRadius":".25rem"},"css":".gb-element-07676c9a{background-color:var(\u002d\u002dbase-2);border-radius:.25rem;padding:2rem}","metadata":{"name":"Mock Contact From"}} -->
    <div class="gb-element-07676c9a"><!-- wp:generateblocks/text {"uniqueId":"dcf0d577","tagName":"p","styles":{"fontWeight":"500","marginBottom":".5rem","fontSize":"1rem"},"css":".gb-text-dcf0d577{font-size:1rem;font-weight:500;margin-bottom:.5rem}"} -->
    <p class="gb-text gb-text-dcf0d577">Name</p>
    <!-- wp:generateblocks/element {"uniqueId":"109500b4","tagName":"div","styles":{"minHeight":"3rem","borderTopLeftRadius":"2px","borderTopRightRadius":"2px","borderBottomLeftRadius":"2px","borderBottomRightRadius":"2px","borderTopWidth":".5px","borderRightWidth":".5px","borderBottomWidth":".5px","borderLeftWidth":".5px","borderTopStyle":"solid","borderRightStyle":"solid","borderBottomStyle":"solid","borderLeftStyle":"solid","borderTopColor":"var(\u002d\u002dbase)","borderRightColor":"var(\u002d\u002dbase)","borderBottomColor":"var(\u002d\u002dbase)","borderLeftColor":"var(\u002d\u002dbase)","marginBottom":"1rem","backgroundColor":"var(\u002d\u002dbase-3)"},"css":".gb-element-109500b4{background-color:var(\u002d\u002dbase-3);margin-bottom:1rem;min-height:3rem;border:.5px solid var(\u002d\u002dbase);border-radius:2px}"} -->
    <div class="gb-element-109500b4"></div>
    <!-- wp:generateblocks/text {"uniqueId":"f9c85281","tagName":"p","styles":{"fontWeight":"500","marginBottom":".5rem","fontSize":"1rem"},"css":".gb-text-f9c85281{font-size:1rem;font-weight:500;margin-bottom:.5rem}"} -->
    <p class="gb-text gb-text-f9c85281">Email</p>
    <!-- wp:generateblocks/element {"uniqueId":"83790b58","tagName":"div","styles":{"minHeight":"3rem","borderTopLeftRadius":"2px","borderTopRightRadius":"2px","borderBottomLeftRadius":"2px","borderBottomRightRadius":"2px","borderTopWidth":".5px","borderRightWidth":".5px","borderBottomWidth":".5px","borderLeftWidth":".5px","borderTopStyle":"solid","borderRightStyle":"solid","borderBottomStyle":"solid","borderLeftStyle":"solid","borderTopColor":"var(\u002d\u002dbase)","borderRightColor":"var(\u002d\u002dbase)","borderBottomColor":"var(\u002d\u002dbase)","borderLeftColor":"var(\u002d\u002dbase)","marginBottom":"1rem","backgroundColor":"var(\u002d\u002dbase-3)"},"css":".gb-element-83790b58{background-color:var(\u002d\u002dbase-3);margin-bottom:1rem;min-height:3rem;border:.5px solid var(\u002d\u002dbase);border-radius:2px}"} -->
    <div class="gb-element-83790b58"></div>
    <!-- wp:generateblocks/text {"uniqueId":"04087285","tagName":"p","styles":{"fontWeight":"500","marginBottom":".5rem","fontSize":"1rem"},"css":".gb-text-04087285{font-size:1rem;font-weight:500;margin-bottom:.5rem}"} -->
    <p class="gb-text gb-text-04087285">Message</p>
    <!-- wp:generateblocks/element {"uniqueId":"df6ec521","tagName":"div","styles":{"minHeight":"6rem","borderTopLeftRadius":"2px","borderTopRightRadius":"2px","borderBottomLeftRadius":"2px","borderBottomRightRadius":"2px","borderTopWidth":".5px","borderRightWidth":".5px","borderBottomWidth":".5px","borderLeftWidth":".5px","borderTopStyle":"solid","borderRightStyle":"solid","borderBottomStyle":"solid","borderLeftStyle":"solid","borderTopColor":"var(\u002d\u002dbase)","borderRightColor":"var(\u002d\u002dbase)","borderBottomColor":"var(\u002d\u002dbase)","borderLeftColor":"var(\u002d\u002dbase)","marginBottom":"1rem","backgroundColor":"var(\u002d\u002dbase-3)"},"css":".gb-element-df6ec521{background-color:var(\u002d\u002dbase-3);margin-bottom:1rem;min-height:6rem;border:.5px solid var(\u002d\u002dbase);border-radius:2px}"} -->
    <div class="gb-element-df6ec521"></div>
    <!-- wp:generateblocks/text {"uniqueId":"28095be6","tagName":"a","styles":{"marginBottom":"1.5rem"},"css":".gb-text-28095be6{margin-bottom:1.5rem}","globalClasses":["gbp-button\u002d\u002dprimary"],"htmlAttributes":{"href":"#"}} -->
    <a class="gb-text gbp-button--primary gb-text-28095be6" href="#">Submit</a>
    <!-- wp:generateblocks/text {"uniqueId":"05ca5f18","tagName":"p","styles":{"marginBottom":".5rem","fontWeight":"500","fontSize":"1rem"},"css":".gb-text-05ca5f18{font-size:1rem;font-weight:500;margin-bottom:.5rem}"} -->
    <p class="gb-text gb-text-05ca5f18">*Replace this mock form with your preferred form plugin</p>
    <!-- /wp:generateblocks/element --></div>
    <!-- /wp:generateblocks/element --></section>
    <!-- wp:generateblocks/element {"uniqueId":"37bc2dd4","tagName":"section","styles":{"paddingBottom":"0px"},"css":".gb-element-37bc2dd4{padding-bottom:0px}","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <section class="gbp-section gb-element-37bc2dd4"><!-- wp:generateblocks/element {"uniqueId":"ca1cba38","tagName":"div","styles":{"@media (max-width:1024px)":{"marginBottom":"4rem"},"marginBottom":"5rem"},"css":".gb-element-ca1cba38{margin-bottom:5rem}@media (max-width:1024px){.gb-element-ca1cba38{margin-bottom:4rem}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container with max-width"}} -->
    <div class="gbp-section__inner gb-element-ca1cba38"><!-- wp:generateblocks/element {"uniqueId":"b24fecef","tagName":"div","styles":{"@media (max-width:1024px)":{"maxWidth":"100%"},"marginLeft":"auto","marginRight":"auto","textAlign":"center"},"css":".gb-element-b24fecef{margin-left:auto;margin-right:auto;text-align:center}@media (max-width:1024px){.gb-element-b24fecef{max-width:100%}}","metadata":{"name":"Content container"}} -->
    <div class="gb-element-b24fecef"><!-- wp:generateblocks/text {"uniqueId":"dade6f70","tagName":"p","globalClasses":["gbp-section__tagline"]} -->
    <!-- wp:generateblocks/text {"uniqueId":"cd1d17d6","tagName":"h2","styles":[],"globalClasses":["gbp-section__headline"]} -->
    <h2 class="gb-text gbp-section__headline">What our students say</h2>
    <!-- wp:generateblocks/element {"uniqueId":"ab6cc8ed","tagName":"div","styles":{"position":"relative","marginRight":"auto","marginLeft":"auto","display":"grid","columnGap":"2rem","rowGap":"3rem","gridTemplateColumns":"repeat(3, minmax(0, 1fr))","@media (max-width:1024px)":{"gridTemplateColumns":"1fr"},"paddingTop":"2em"},"css":".gb-element-ab6cc8ed{column-gap:2rem;display:grid;grid-template-columns:repeat(3,minmax(0,1fr));margin-left:auto;margin-right:auto;padding-top:2em;position:relative;row-gap:3rem}@media (max-width:1024px){.gb-element-ab6cc8ed{grid-template-columns:1fr}}","htmlAttributes":[],"metadata":{"name":"inner container max width"}} -->
    <div class="gb-element-ab6cc8ed"><!-- wp:generateblocks/element {"uniqueId":"5dc42862","tagName":"div","styles":{"textAlign":"left","paddingTop":"1.6em","paddingLeft":"1.6em","paddingBottom":"1.6em","paddingRight":"1.6em","backgroundColor":"var(\u002d\u002dbase-2)","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px"},"css":".gb-element-5dc42862{background-color:var(\u002d\u002dbase-2);text-align:left;border-radius:6px;padding:1.6em}"} -->
    <div class="gb-element-5dc42862"><!-- wp:generateblocks/element {"uniqueId":"ab37447b","tagName":"div","styles":{"display":"flex","flexDirection":"row","alignItems":"center","justifyContent":"flex-start","rowGap":"0.5rem","textAlign":"left","columnGap":"1em","borderBottomWidth":"2px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase-3)","paddingBottom":"1em","marginBottom":"1em"},"css":".gb-element-ab37447b{align-items:center;column-gap:1em;display:flex;flex-direction:row;justify-content:flex-start;margin-bottom:1em;padding-bottom:1em;row-gap:0.5rem;text-align:left;border-bottom:2px solid var(\u002d\u002dbase-3)}","htmlAttributes":[],"metadata":{"name":"Meta Byline"}} -->
    <div class="gb-element-ab37447b"><!-- wp:generateblocks/media {"uniqueId":"40f5d21a","tagName":"img","styles":{"width":"64px","height":"64px","borderTopLeftRadius":"100%","borderTopRightRadius":"100%","borderBottomLeftRadius":"100%","borderBottomRightRadius":"100%","display":"block"},"css":".gb-media-40f5d21a{display:block;height:64px;width:64px;border-radius:100%}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-1-1-150x150.png","title":"image-1-1","alt":"User avatar placeholder"},"mediaId":46291,"linkHtmlAttributes":[],"metadata":[]} -->
    <img class="gb-media-40f5d21a" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-1-1-150x150.png" title="image-1-1" alt="User avatar placeholder"/>
    <!-- wp:generateblocks/element {"uniqueId":"e3a9c07b","tagName":"div","styles":{"columnGap":"1rem"},"css":".gb-element-e3a9c07b{column-gap:1rem}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-element-e3a9c07b"><!-- wp:generateblocks/text {"uniqueId":"50b6eacd","tagName":"div","styles":{"fontWeight":"700"},"css":".gb-text-50b6eacd{font-weight:700}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-text gb-text-50b6eacd">Customer name</div>
    <!-- wp:generateblocks/text {"uniqueId":"4fe87c09","tagName":"div","styles":{"fontWeight":"400"},"css":".gb-text-4fe87c09{font-weight:400}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-text gb-text-4fe87c09">Student</div>
    <!-- wp:generateblocks/text {"uniqueId":"442bd4e8","tagName":"div","styles":{"@media (max-width:767px)":{"fontSize":"1.125rem","marginBottom":"1.5rem"},"marginBottom":"2rem"},"css":".gb-text-442bd4e8{margin-bottom:2rem}@media (max-width:767px){.gb-text-442bd4e8{font-size:1.125rem;margin-bottom:1.5rem}}","htmlAttributes":[],"metadata":[],"className":""} -->
    <div class="gb-text gb-text-442bd4e8">Lorem ipsum dolor sit amet, consectetur adipiscing elit. Suspendisse varius enim in eros elementum tristique.</div>
    <!-- wp:generateblocks/element {"uniqueId":"6021c982","tagName":"div","styles":{"display":"flex"},"css":".gb-element-6021c982{display:flex}"} -->
    <div class="gb-element-6021c982"><!-- wp:generateblocks/text {"uniqueId":"8d71ed41","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-8d71ed41{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-8d71ed41 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-8d71ed41"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"8e8fd63e","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-8e8fd63e{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-8e8fd63e .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-8e8fd63e"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"15467214","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-15467214{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-15467214 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-15467214"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"bf7f3b6e","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-bf7f3b6e{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-bf7f3b6e .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-bf7f3b6e"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"aa378ee4","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0"},"css":".gb-text-aa378ee4{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0}.gb-text-aa378ee4 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-aa378ee4"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"7057e66c","tagName":"div","styles":{"textAlign":"left","paddingTop":"1.6em","paddingLeft":"1.6em","paddingBottom":"1.6em","paddingRight":"1.6em","backgroundColor":"var(\u002d\u002dbase-2)","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px"},"css":".gb-element-7057e66c{background-color:var(\u002d\u002dbase-2);text-align:left;border-radius:6px;padding:1.6em}"} -->
    <div class="gb-element-7057e66c"><!-- wp:generateblocks/element {"uniqueId":"666fc0cf","tagName":"div","styles":{"display":"flex","flexDirection":"row","alignItems":"center","justifyContent":"flex-start","rowGap":"0.5rem","textAlign":"left","columnGap":"1em","borderBottomWidth":"2px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase-3)","paddingBottom":"1em","marginBottom":"1em"},"css":".gb-element-666fc0cf{align-items:center;column-gap:1em;display:flex;flex-direction:row;justify-content:flex-start;margin-bottom:1em;padding-bottom:1em;row-gap:0.5rem;text-align:left;border-bottom:2px solid var(\u002d\u002dbase-3)}","htmlAttributes":[],"metadata":{"name":"Meta Byline"}} -->
    <div class="gb-element-666fc0cf"><!-- wp:generateblocks/media {"uniqueId":"0e019ec9","tagName":"img","styles":{"width":"64px","height":"64px","borderTopLeftRadius":"100%","borderTopRightRadius":"100%","borderBottomLeftRadius":"100%","borderBottomRightRadius":"100%","display":"block"},"css":".gb-media-0e019ec9{display:block;height:64px;width:64px;border-radius:100%}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-1-1-150x150.png","title":"image-1-1","alt":"User avatar placeholder"},"mediaId":46291,"linkHtmlAttributes":[],"metadata":[]} -->
    <img class="gb-media-0e019ec9" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-1-1-150x150.png" title="image-1-1" alt="User avatar placeholder"/>
    <!-- wp:generateblocks/element {"uniqueId":"9d057690","tagName":"div","styles":{"columnGap":"1rem"},"css":".gb-element-9d057690{column-gap:1rem}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-element-9d057690"><!-- wp:generateblocks/text {"uniqueId":"40411bae","tagName":"div","styles":{"fontWeight":"700"},"css":".gb-text-40411bae{font-weight:700}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-text gb-text-40411bae">Customer name</div>
    <!-- wp:generateblocks/text {"uniqueId":"1034e121","tagName":"div","styles":{"fontWeight":"400"},"css":".gb-text-1034e121{font-weight:400}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-text gb-text-1034e121">Student</div>
    <!-- wp:generateblocks/text {"uniqueId":"6903d3cd","tagName":"div","styles":{"@media (max-width:767px)":{"fontSize":"1.125rem","marginBottom":"1.5rem"},"marginBottom":"2rem"},"css":".gb-text-6903d3cd{margin-bottom:2rem}@media (max-width:767px){.gb-text-6903d3cd{font-size:1.125rem;margin-bottom:1.5rem}}","htmlAttributes":[],"metadata":[],"className":""} -->
    <div class="gb-text gb-text-6903d3cd">Lorem ipsum dolor sit amet, consectetur adipiscing elit. Suspendisse varius enim in eros elementum tristique.</div>
    <!-- wp:generateblocks/element {"uniqueId":"5fc94fea","tagName":"div","styles":{"display":"flex"},"css":".gb-element-5fc94fea{display:flex}"} -->
    <div class="gb-element-5fc94fea"><!-- wp:generateblocks/text {"uniqueId":"4e001a45","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-4e001a45{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-4e001a45 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-4e001a45"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"6842b0b3","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-6842b0b3{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-6842b0b3 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-6842b0b3"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"0011011e","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-0011011e{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-0011011e .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-0011011e"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"c56fbc43","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-c56fbc43{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-c56fbc43 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-c56fbc43"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"c784f7d2","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0"},"css":".gb-text-c784f7d2{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0}.gb-text-c784f7d2 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-c784f7d2"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"c17545e2","tagName":"div","styles":{"textAlign":"left","paddingTop":"1.6em","paddingLeft":"1.6em","paddingBottom":"1.6em","paddingRight":"1.6em","backgroundColor":"var(\u002d\u002dbase-2)","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px"},"css":".gb-element-c17545e2{background-color:var(\u002d\u002dbase-2);text-align:left;border-radius:6px;padding:1.6em}"} -->
    <div class="gb-element-c17545e2"><!-- wp:generateblocks/element {"uniqueId":"4db3a79f","tagName":"div","styles":{"display":"flex","flexDirection":"row","alignItems":"center","justifyContent":"flex-start","rowGap":"0.5rem","textAlign":"left","columnGap":"1em","borderBottomWidth":"2px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase-3)","paddingBottom":"1em","marginBottom":"1em"},"css":".gb-element-4db3a79f{align-items:center;column-gap:1em;display:flex;flex-direction:row;justify-content:flex-start;margin-bottom:1em;padding-bottom:1em;row-gap:0.5rem;text-align:left;border-bottom:2px solid var(\u002d\u002dbase-3)}","htmlAttributes":[],"metadata":{"name":"Meta Byline"}} -->
    <div class="gb-element-4db3a79f"><!-- wp:generateblocks/media {"uniqueId":"cdd91e0a","tagName":"img","styles":{"width":"64px","height":"64px","borderTopLeftRadius":"100%","borderTopRightRadius":"100%","borderBottomLeftRadius":"100%","borderBottomRightRadius":"100%","display":"block"},"css":".gb-media-cdd91e0a{display:block;height:64px;width:64px;border-radius:100%}","htmlAttributes":{"src":"https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-1-1-150x150.png","title":"image-1-1","alt":"User avatar placeholder"},"mediaId":46291,"linkHtmlAttributes":[],"metadata":[]} -->
    <img class="gb-media-cdd91e0a" src="https://sites.generatepress.com/education/wp-content/uploads/sites/157/image-1-1-150x150.png" title="image-1-1" alt="User avatar placeholder"/>
    <!-- wp:generateblocks/element {"uniqueId":"d81fd0a1","tagName":"div","styles":{"columnGap":"1rem"},"css":".gb-element-d81fd0a1{column-gap:1rem}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-element-d81fd0a1"><!-- wp:generateblocks/text {"uniqueId":"a1e52ac3","tagName":"div","styles":{"fontWeight":"700"},"css":".gb-text-a1e52ac3{font-weight:700}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-text gb-text-a1e52ac3">Customer name</div>
    <!-- wp:generateblocks/text {"uniqueId":"72774ab6","tagName":"div","styles":{"fontWeight":"400"},"css":".gb-text-72774ab6{font-weight:400}","htmlAttributes":[],"metadata":[]} -->
    <div class="gb-text gb-text-72774ab6">Student</div>
    <!-- wp:generateblocks/text {"uniqueId":"53601369","tagName":"div","styles":{"@media (max-width:767px)":{"fontSize":"1.125rem","marginBottom":"1.5rem"},"marginBottom":"2rem"},"css":".gb-text-53601369{margin-bottom:2rem}@media (max-width:767px){.gb-text-53601369{font-size:1.125rem;margin-bottom:1.5rem}}","htmlAttributes":[],"metadata":[],"className":""} -->
    <div class="gb-text gb-text-53601369">Lorem ipsum dolor sit amet, consectetur adipiscing elit. Suspendisse varius enim in eros elementum tristique.</div>
    <!-- wp:generateblocks/element {"uniqueId":"05bcede8","tagName":"div","styles":{"display":"flex"},"css":".gb-element-05bcede8{display:flex}"} -->
    <div class="gb-element-05bcede8"><!-- wp:generateblocks/text {"uniqueId":"aad9661a","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-aad9661a{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-aad9661a .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-aad9661a"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"f6143f2d","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-f6143f2d{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-f6143f2d .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-f6143f2d"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"b6043850","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-b6043850{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-b6043850 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-b6043850"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"89241831","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0px"},"css":".gb-text-89241831{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0px}.gb-text-89241831 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-89241831"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/text {"uniqueId":"ed9329c0","tagName":"p","styles":{"display":"inline-flex","alignItems":"center","columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","color":"var(\u002d\u002daccent)"},"marginBottom":"0"},"css":".gb-text-ed9329c0{align-items:center;column-gap:0.5em;display:inline-flex;margin-bottom:0}.gb-text-ed9329c0 .gb-shape svg{width:1em;height:1em;fill:currentColor;color:var(\u002d\u002daccent)}","iconOnly":true} -->
    <p class="gb-text-ed9329c0"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span></p>
    <!-- wp:generateblocks/element {"uniqueId":"78790fcf","tagName":"section","styles":{"backgroundImage":"linear-gradient(180deg, var(\u002d\u002dbase-3) 0%, var(\u002d\u002dbase-2) 100%)","backgroundSize":"cover","backgroundRepeat":"no-repeat","backgroundPosition":"center","backgroundBlendMode":"normal"},"css":".gb-element-78790fcf{background-blend-mode:normal;background-image:linear-gradient(180deg,var(\u002d\u002dbase-3) 0%,var(\u002d\u002dbase-2) 100%);background-position:center;background-repeat:no-repeat;background-size:cover}","globalClasses":["gbp-section"],"metadata":{"name":"Section"}} -->
    <section class="gbp-section gb-element-78790fcf"><!-- wp:generateblocks/element {"uniqueId":"2bbce07c","tagName":"div","styles":{"@media (max-width:1024px)":{"marginBottom":"4rem"},"marginBottom":"5rem","display":"flex","flexDirection":"column","rowGap":"1em"},"css":".gb-element-2bbce07c{display:flex;flex-direction:column;margin-bottom:5rem;row-gap:1em}@media (max-width:1024px){.gb-element-2bbce07c{margin-bottom:4rem}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"inner container with max-width"}} -->
    <div class="gbp-section__inner gb-element-2bbce07c"><!-- wp:generateblocks/element {"uniqueId":"f0522f8e","tagName":"div","styles":{"@media (max-width:1024px)":{"maxWidth":"100%"},"marginLeft":"auto","marginRight":"auto","textAlign":"center"},"css":".gb-element-f0522f8e{margin-left:auto;margin-right:auto;text-align:center}@media (max-width:1024px){.gb-element-f0522f8e{max-width:100%}}","metadata":{"name":"Content container"}} -->
    <div class="gb-element-f0522f8e"><!-- wp:generateblocks/text {"uniqueId":"70edfa7d","tagName":"p","globalClasses":["gbp-section__tagline"]} -->
    <p class="gb-text gbp-section__tagline">Tagline</p>
    <!-- wp:generateblocks/text {"uniqueId":"12e0037f","tagName":"h2","styles":{"textTransform":"capitalize"},"css":".gb-text-12e0037f{text-transform:capitalize}","globalClasses":["gbp-section__headline"]} -->
    <h2 class="gb-text gbp-section__headline gb-text-12e0037f">Our latest News</h2>
    <!-- wp:generateblocks/text {"uniqueId":"c2ef0e07","tagName":"p","globalClasses":["gbp-section__text"]} -->
    <p class="gb-text gbp-section__text">Lorem ipsum dolor sit amet, consectetur adipiscing elit.</p>
    <!-- wp:generateblocks/element {"uniqueId":"f75d6f4b","tagName":"div","styles":{"marginLeft":"auto","marginRight":"auto","display":"block","@media (max-width:1024px)":{"gridTemplateColumns":"1fr"}},"css":".gb-element-f75d6f4b{display:block;margin-left:auto;margin-right:auto}@media (max-width:1024px){.gb-element-f75d6f4b{grid-template-columns:1fr}}","globalClasses":["gbp-section__inner"],"metadata":{"name":"Content container"}} -->
    <div class="gbp-section__inner gb-element-f75d6f4b"><!-- wp:generateblocks/query {"uniqueId":"047c9ea3","tagName":"div","query":{"post_type":["post"],"posts_per_page":"3"}} -->
    <div><!-- wp:generateblocks/looper {"uniqueId":"5569c298","tagName":"div","styles":{"display":"grid","columnGap":"1.6em","rowGap":"2em","gridTemplateColumns":"repeat(3, minmax(0, 1fr))","@media (max-width:1024px)":{"gridTemplateColumns":"repeat(2, minmax(0, 1fr))"},"@media (max-width:767px)":{"gridTemplateColumns":"1fr"},":last-child":{"@media (max-width:1024px)":{"gridColumn":"1 / -1","justifySelf":"center","maxWidth":"400px"},"@media (max-width:767px)":{"maxWidth":"100%"}},"alignItems":"center","justifyContent":"center"},"css":".gb-looper-5569c298{align-items:center;column-gap:1.6em;display:grid;grid-template-columns:repeat(3,minmax(0,1fr));justify-content:center;row-gap:2em}@media (max-width:1024px){.gb-looper-5569c298{grid-template-columns:repeat(2,minmax(0,1fr))}.gb-looper-5569c298 :last-child{grid-column:1/-1;justify-self:center;max-width:400px}}@media (max-width:767px){.gb-looper-5569c298{grid-template-columns:1fr}.gb-looper-5569c298 :last-child{max-width:100%}}"} -->
    <div class="gb-looper-5569c298"><!-- wp:generateblocks/loop-item {"uniqueId":"f9abb241","tagName":"article","styles":{"boxShadow":"0px 5px 10px 6px rgba(68, 68, 87, 0.05)","borderTopLeftRadius":"6px","borderTopRightRadius":"6px","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px","fontSize":"1rem","@media (max-width:767px)":{"maxWidth":"100%"}},"css":".gb-loop-item-f9abb241{box-shadow:0px 5px 10px 6px rgba(68,68,87,0.05);font-size:1rem;border-radius:6px}@media (max-width:767px){.gb-loop-item-f9abb241{max-width:100%}}"} -->
    <article class="gb-loop-item gb-loop-item-f9abb241"><!-- wp:generateblocks/media {"uniqueId":"f3d3e769","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","display":"block","borderTopLeftRadius":"6px","borderTopRightRadius":"6px"},"css":".gb-media-f3d3e769{border-top-left-radius:6px;border-top-right-radius:6px;display:block;height:250px;max-width:100%;object-fit:cover;width:100%}","htmlAttributes":{"src":"{{featured_image size:medium_large|key:url}}","alt":"Image placeholder"},"linkHtmlAttributes":{"href":"{{post_permalink}}"}} -->
    <a href="{{post_permalink}}"><img class="gb-media-f3d3e769" src="{{featured_image size:medium_large|key:url}}" alt="Image placeholder"/></a>
    <!-- /wp:generateblocks/media -->
    <!-- wp:generateblocks/element {"uniqueId":"7a75e9e8","tagName":"div","styles":{"backgroundColor":"var(\u002d\u002dbase-3)","paddingTop":"2.6em","paddingLeft":"2em","paddingBottom":"2.6em","paddingRight":"2em","borderBottomLeftRadius":"6px","borderBottomRightRadius":"6px"},"css":".gb-element-7a75e9e8{background-color:var(\u002d\u002dbase-3);border-bottom-left-radius:6px;border-bottom-right-radius:6px;padding:2.6em 2em}"} -->
    <div class="gb-element-7a75e9e8"><!-- wp:generateblocks/text {"uniqueId":"f5bf41df","tagName":"h3","styles":{"marginBottom":"0.5em"},"css":".gb-text-f5bf41df{margin-bottom:0.5em}"} -->
    <h3 class="gb-text gb-text-f5bf41df">{{post_title link:post}}</h3>
    <!-- wp:generateblocks/text {"uniqueId":"be25e6d2","tagName":"p","styles":{"color":"var(\u002d\u002dcontrast-3)"},"css":".gb-text-be25e6d2{color:var(\u002d\u002dcontrast-3)}"} -->
    <p class="gb-text gb-text-be25e6d2">{{post_excerpt length:10}}</p>
    <!-- wp:generateblocks/text {"uniqueId":"ad25b034","tagName":"a","styles":{"display":"inline-flex","alignItems":"center","color":"#ffffff","textDecoration":"none","\u0026:is(:hover, :focus)":{"color":"#ffffff"},"columnGap":"0.5em",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor","transition":"all 0.5s ease 0s"},"\u0026:is(:hover, :focus) .gb-shape svg":{"transform":"translate3d(10px, 0px, 0px)","transition":"transform 0.5s ease 0s"}},"css":".gb-text-ad25b034{align-items:center;color:#ffffff;column-gap:0.5em;display:inline-flex;text-decoration:none}.gb-text-ad25b034:is(:hover,:focus){color:#ffffff}.gb-text-ad25b034:is(:hover,:focus) .gb-shape svg{transform:translate3d(10px,0px,0px);transition:transform 0.5s ease 0s}.gb-text-ad25b034 .gb-shape svg{width:1em;height:1em;fill:currentColor;transition:all 0.5s ease 0s}","globalClasses":["gbp-button\u002d\u002dtertiary"],"htmlAttributes":{"href":"{{post_permalink}}"},"iconLocation":"after"} -->
    <a class="gbp-button--tertiary gb-text-ad25b034" href="{{post_permalink}}"><span class="gb-text">Read more</span><span class="gb-shape"><svg viewBox="0 0 256 256" height="32" width="32" xmlns="http://www.w3.org/2000/svg"><path d="M224.49,136.49l-72,72a12,12,0,0,1-17-17L187,140H40a12,12,0,0,1,0-24H187L135.51,64.48a12,12,0,0,1,17-17l72,72A12,12,0,0,1,224.49,136.49Z"></path></svg></span></a>
    <!-- /wp:generateblocks/element --></article>
    <!-- /wp:generateblocks/loop-item --></div>
    <!-- /wp:generateblocks/looper --></div>
    <!-- /wp:generateblocks/query --></div>
