apinajus
I want to retrieve posts based in Custom Fields values but I don’t know how to do it.
Can you be out of help?Thanks
You may need to use a snippet for that. Can you explain a bit further about how you want to achieve this and which plugin you are using for the custom field?
apinajus
I am not using any plugin, only the wordpress feature for that.
Essentially I have a given category of posts in which I tag the city for each of one of them (I am using the “tags” feature for another purpose).
therefore I would like to pull the info from this custom field in a query loop.Does it make sense?
Not sure if I’m getting this right, but from what I understand, you’ve added a custom field to each post, and now you want to display the posts based on a specific value of that custom field. Is that correct?
apinajus
Correct!
I am still not clear, are you talking about the wp tags or the custom field?
If it’s custom field, please check this article: https://docs.generateblocks.com/article/order-query-loop-by-custom-field/
apinajus
First, add a class to the Grid block inside of the Query Loop:
query-by-city
Then, try this:
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { // apply filter if loop has class: query-by-city if (! is_admin() && ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'query-by-city' ) !== false) { $query_args = array_merge( $query_args, array( 'meta_query' => array( array( 'key' => 'city', 'value' => 'Wielicka', 'compare' => '=', ) ), ) ); } return $query_args; }, 10, 2 );
Let me know if that works or not 🙂
apinajus
Hi Tom,
Thanks for this.
I understand that this function will work only when the value = ‘Wielicka’I do have a bunch of other cities so I was thinking in adding the option as a parameter in the Query Loop menu as shown here
Can it be done?
Not without it affecting the query, which we don’t want here.
One possibility is to use the Custom Attributes feature in the Grid block.
You could do something like this:
key:
data-city
value: Your ValueThen you could adjust your function:
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { // apply filter if loop has class: query-by-city if (! is_admin() && ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'query-by-city' ) !== false) { $html_attributes = $attributes['htmlAttributes']; $city = ''; foreach ( $html_attributes as $attribute ) { if ( 'data-city' === $attribute['attribute'] ) { $city = $attribute['value']; } } if ( ! $city ) { return $query_args; } $query_args = array_merge( $query_args, array( 'meta_query' => array( array( 'key' => 'city', 'value' => $city, 'compare' => '=', ) ), ) ); } return $query_args; }, 10, 2 );
