Stefanie
Hi team,
I would like to create some global styles (utility classes) that allow me to format an H3 like an H1, or an H2 like an H3, etc.
I would like to create these global styles in such a way that I can use them in all future projects.
Therefore I would prefer to define the font sizes via variables.Can I create a font-size as a variable within a global style?
e.g. something like this: font-size: var(- -h1) ?Thanks for help
Hi Stefanie,
Yes, you should be able to do so.
But it might not show in the editor unless you force the editor to load the font size CSS
:root {--h1:60px;} -
Stefanie
Hi Ying,
I have tried this, but unfortunately the variable is not accepted.
See URL… unless you force the editor to load the font size CSS
I don’t understand exactly what you mean here.
Did you define the variable
--h1somewhere?It shows it’s not defined.
https://app.screencast.com/FtrBdUX6Mp8g9 -
Stefanie
Did you define the variable –h1 somewhere?
Ahaa, I had thought that this would work in the same way as with the colors.
I defined the headlines h1 – h4 in the customizer. So I thought that this would automatically create variables, just like with the colors.
But maybe that doesn’t work for the font sizes? 🤔
Or maybe it’s because I set the font sizes via fluid typography?
questions about questions 😉
The customizer typography does not generate variables, so when you set a font-size for h1, the CSS is just:
h1 { font-size:60px; }not:
:root { --h1:60px; }However, you can use variables in the customizer typography, for example, set h1’s font-size to
var(--h1), and add this CSS to your CSS stylesheet::root { --h1:60px; } -
Stefanie
Ok, got it!
And it works perfectly 🙂Thank you!
